Strong srt4375 firmware LATEST!Information exchange on receiver software, including updates, problems and fine tuning. | |
| Guest
Posts: n/a
[updated:LAST EDITED ON 14-Oct-01 AT 07:49 PM (GMT)]Hi, I just received a new firmware upgrade for the strong srt4375 from a gentleman in the usa of all places!, he's been testing it on behalf of strong i believe along with a guy over here in the uk. I have just installed it no problems and can report its great- especially as it now has a software update via satellite (astra)!! So no more messing around with null modem cables! If anyone would like the file please e-mail me at: jamie@sirius-systems.co.uk i would post it here its 876kb's though. Would this be ok moderators? If so i will upload it. Thanks go to Robert from north america. Bug reports please to: nick@strong.com.ua regards, Jamie | ||
| Regular Member Join Date: 01-01-2000 Location: uh::
Hi, Can you please elaborate on the software working great, and also would it be possible to revert back to V1.02, if there is a problem with the software. I also try to upload the channel settings from the link you posted to my receiver, but keep getting error unable to upload file, even though I have used the same null modem cable previously when I upgrade to V1.02, have you got any suggestion on what I may be doing wrong. Regards Prince | ||
| ua:: | |||
| Guest
Posts: n/a
Hi, When i said the new firmware is working grat i meant that there was no apparent bugs, but also there is an update firmware via satellite feature in the new version (v1.02 october) you go to menu, select 'system set up' then select 'system upgrade' (make sure the dish is pointing at astra 19.2) then the receiver will check for upgrades and download them to your receiver via your dish. (takes around 15-30 minutes) as to whether it is possible to revert back to the previous v 1.02 thats no problem , but obviously you will need to do this via your null modem lead. I have successfully changed my firmware up and down between versions without any problem at all. Regarding uploading a channel file, this is how you do it: 1)plug the null cable into your pc and receiver 2)plug in your receiver and turn it on (Do not press in the menu and exit buttons like you do for firmware upgrades) 3)then run srtlink 4)go to the box marked upload from pc to receiver browse to your channel file (a .dat file) 5)Click on start 6) Thats it, it should work fine!! This method works for me, although there is absolutely nothing on the strong site with regards to doing this, i only managed to do it by trial and error .If you have any problems, try shutting down srtlink, unplugging the receiver and try again, but it does work. Get any problems prince, get back to me and ill be happy to help. Let me know if you want me to e-mail you the new firmware regards, | ||
Hi Jamie2000, Thanks for your detailed instruction, it seems I was going wrong by pressing the menu and exit button as instructed on the strong site, can you please send me the firmware, my email address is jasper33@hotmail.com Regards Prince | ||
| ua:: | |||
| | #5 | ||
| Guest
Posts: n/a
No problem mate, i'm glad you got it working!, i must admit strong dont exactly make it easy. I have e-mailed this to strong but have yet to receive a reply! (they are normally quite quick in replying!) Anyway the file is on its way. Regards, Jamie | ||
| | #7 | ||
Hi Jamie 2001, I installed the firmware and settings last night and it seems to be working great, the only exception is that it seems to describe all channel type as free, whereas the original version seems to recognise some as coded and it also got all this symbols beside some channel name which I haven't got a clue what they means,anyway thanks again I would email any feedback on it performance to the email address above. Regards Prince | ||
| ua:: | |||
| | #8 | ||
| Guest
Posts: n/a
Hi there, I dont know what has happened to the coded/free channel describer as mine is fine- correctly showing if a channel is coded or not. Maybe its worth trying to update it again?- use the update by satellite option, its so easy!! regards, jamie | ||
| | #10 | ||
| Honorary Admin Join Date: 01-01-1999 Location: Cloud Cuckoo Land
According to posts in the Dutch Satnerds Strong forum, the new firmware has already appeared at Strong's site. Don't know for sure it's the same though. http://www.satnerds.com/forums/showthread.php?s=&threadid=3346 2old | ||
| firmware, latest, srt4375, strong |
Similar Threads | ||||
| Channels that clear with the Techomate patches | Yeshi | Digital systems | 13 | 10-05-2009 05:53 PM |
| problems with latest snitch and progdvb | peter in the bus | Satellite PC Card Receivers & Internet by Satellite | 2 | 17-08-2005 08:30 PM |
| Updating Strong SRT4375 | inabsentia | Receiver software, international Section | 4 | 26-07-2005 11:03 PM |
| MR on Strong 4375 (& Hispasat) | Godzuki | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 5 | 04-05-2004 08:39 PM |
| LATEST!! Sky/ITV/Channel 4. in talks. | net1 | Sky Digital (BSkyB) and Astra 28.2 East General | 1 | 24-09-2003 07:03 PM |
