Help with updating Mivion 9090xInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
| Usually a null modem cable is used to update software on satellite STB. For the software, try the internet. May I ask why do you need to update the software? If you have experience, then this would help, but if this is the first time then please take into consideration that if you upload the wrong software or something goes wrong during the update, then your box might not work again. Tip: Disconnect all cables (especially the LNB coax cable) except the power cord and the the null modem cable when you are ready to install Good Luck | ||
| Member Join Date: 11-02-2006 Location: KSA
My System: SSS | thank you HB13DISH I have MIVION 9090X UPDATE FILE from http://www.arong-sat.com/ i use the null cable but when i turn off and on the receiver nothing happen can you help me whith that. | ||
| | #4 | |||
| Did you update with this file ALREADY or you are going to do it? If you did, then tell us how you did the update. What kind of PC and O/S does it have? | |||
| 9090x, mivion, updating |
