Zenega CD1004iS Boot problemInformation exchange on receiver software, including updates, problems and fine tuning. | |
| | #26 | |||
| Member Real name: wasim shaikh Join Date: 12-02-2009 Location: india
My System: yes |
u r problem is boot file pls chang boot file | |||
| | #27 | ||
| Member Join Date: 13-10-2008 Location: India
My System: Dish TV, Zenega 1004iS |
I am still in search a circuit diagram so that I can change it to FTA. I contacted somebody who was talking about Jtag. Any way if anybody can provide me a circuit diagram I shall be happy to proceed. | ||
| | #30 | ||
| Member Join Date: 24-04-2009 Location: INDIA
My System: Dish TV , Zenega STB | Thanks Guys. The DishTV support was giving me the BS about software update. Your thread lead me to the correct solution and I got my STB fixed at a local electronics shop in 10 minutes. He changed the two condensers, I guess they had flunked when there was a sudden voltage fluctuation. The electrician said, he has put 2 condensers of 16v. Thanks a lot. | ||
| | #31 | ||
| Member Real name: prasad Join Date: 14-05-2009 Location: VADODARA
My System: DISHTV | | ||
| | #32 | ||
| Member Join Date: 21-07-2004
| you do not need any hardware modification. All u need to do is to re-orient dish to insat4 for ur geographic location. I have done it for Baroda. Very small change in angle was needed and just keep watching on tv while realigning the programs u get. All DDplus DTH channels are received in good quality. | ||
| | #34 | ||
My System: DISHTV | first remove dish in put cables then power switch turn on start channel 115 (free of air number) then connect to in put cable | ||
| | #36 | |||
| ASBO Club Member - Persona non grata Join Date: 04-07-2009 Location: dubai
My System: all aboyt dishtv |
| | #38 | ||
| Member Join Date: 06-08-2009 Location: Dubai
My System: DISH TV | Hi There, I am using the dish tv setup box. it initially start blinking a light orange and green light..and continues the whole time.. the tv screen remains blank. its not working for almost a month now, but suddendly a day beofre it worked for one complete day and again went off. I asked here at the local electrical shop if they could fix it, they are not able to do so, i cannot find a dish tv supplier here to fix it. can i fix it myself??? Can anyone please help me out of this!!! Thanks | ||
| | #39 | |||
| | #40 | ||
My System: all aboyt dishtv | for more about disth tv contect me at nomail@nomail.com | ||
| | #41 | ||||
| | #42 | |||
| Member Real name: deepak Join Date: 24-08-2009 Location: faridabad india
My System: dish tv dealer |
| | #44 | ||
| Member Real name: pralhad Join Date: 22-04-2009 Location: india
My System: i have dishtv stb zenega 1004is & hi hp 520 laptop | SIR I HAVE ZENEGA CD-1004IS IT'S GREEN LIGHT BLOWS BUT NO DISPLAY ON SCREEN ONLY PLANE RASTER, I TRY LOTS OF TIME FOR SET TO SET DOWNLOADING BUT NOT SUPPORT, ONLY THIS BOX DOSE NOT SUPPORT ON WHICH FLASH IC HAVE V1.61 TAG WITH RED MARKS, OTHER BOX SUPPORT WHICH FLASH IC HAVE V1.56 PLEASE POST HERE REPLY, ON email removed | ||
| | #45 | ||
| Member Real name: kaushik Join Date: 12-10-2009 Location: surat
My System: dishtv dealer | dear sir my zenega 1004is setbox problam dish alivation ok but 301 signal not found problam i am change power suplaiy but problam not solad so plz | ||
| | #47 | ||
| Member Real name: abhi Join Date: 23-10-2009 Location: Pune, India
My System: Dish TV | Hi, I have the same problem : LED blinks green/orange when I turn ON the STB. I changed the 2 capacitors from 10v to 25v as suggested earlier by Ved. Still the problem persists. Though I have found another way to make it work, it is not a convenient way. The other way I m using is, I switch off the STB by double clicking the ON/OFF switch on STB, after the LED turns red, I turn the STB ON. Then it becomes and remains green, on the TV screen I see a msg saying Unable to receive signal, but as I change the channel the things work! Kindly suggest me probable solution. Thanks. ..abhi.. | ||
| | #48 | ||
My System: Dish TV | For those who are new to capacitors like me. I bought them from a local electrical shop ( main electrical market). 1 capacitor for Rs 4 ( Four only) Got the soldering done for Rs 10 ( Ten only) for 1 capacitor. So if this works, it is the cheapest solution. ..abhi.. | ||
| | #50 | |||
| Member Real name: jeevankumar Join Date: 06-11-2009 Location: patiala
My System: NSS6 |
| boot, cd1004is, problem, zenega |
