Zenega CD1004iS Boot problemInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Member Join Date: 23-07-2008 Location: UAE
My System: ZENEGACD1004is,N70,XPS | Hello all, I am Dish TV user, using "Zenega CD1004iS". Past few days I am having trouble with booting this setup box. It starts with very dim and fast blinking orange light, slows down after sometime and and finally ends up with proper green light. This complete process takes about 5-10 minutes, which is quite frustrating. I consulted the experts and they advised me to re-install the software/firmware. Can anyone help me with it? Is it possible doing it at home and how can we do it step by step. Thank you for all those willing to help me. -Hsarp | ||
| Member Join Date: 11-09-2004
| Dear sir, I hope i was in U A E to help you with this problem, This problem has nothing got to with software or whatever the dish tv guys arre telling you to do.But this problem is with the SMPS (switch mode power supply).which is inside the receiver ,U should immediately change the power supply board.Now it is only blinking dimly and stabilising after 10 to 15 minutes,gradually it will deteriorate to hours and ultimately it will completely go dead.So please change the power supply or send the box to me .I will repair it and give it to you.iam in bangalore nomail@nomail.com | ||
| Member Join Date: 16-01-2006 Location: 91
My System: v | hi hsarp no needs to change power supply.only change power supply filter cap.25v 1000mf.[:P] | ||
| The Following 5 Users Say Thank You to ved For This Useful Post: | abhiG (4 Weeks Ago), daemonkane (24-04-2009), hsarp72 (25-07-2008), liveeverymoment (4 Weeks Ago), rightsameer (01-08-2008) |
| Member Join Date: 27-07-2008 Location: india
My System: zenega cd 1004is | hi, im from bombay, india.... thers a problem with my dish tv stb ( zenega cd 1004is) at the moment its flashing a very dim yellow/orange light continuously for the past 1-2 days. its blank on the tv screen-no dish tv channels or anything for that matter-totally blank. what can i do to fix this? why is this happening ? i think a couple of nights ago there was a power failure in my locality. PLS HELP !!! | ||
| | #5 | ||
My System: v | open your stb cover nd change power suppy filter cpa 25v 1000mf | ||
| The Following 3 Users Say Thank You to ved For This Useful Post: |
| | #7 | ||
My System: zenega cd 1004is | yes i have opened the stb, there is one capacitor which is bulging , but it is 10v 1000uF 105 degree C, V9A as instructed by you i got a capacitor 25v 1000uF SA + 85 degree C, V9 will this work ??? or should i get a 10v one ???? | ||
| | #8 | ||
My System: v | no problem u can use 25v its better then 10v. | ||
| The Following 2 Users Say Thank You to ved For This Useful Post: | abhiG (4 Weeks Ago), rightsameer (02-08-2008) |
| | #9 | ||
My System: zenega cd 1004is | thanks so much ved ! got it done on both my stbs, now they working fine, dish tv ppl are chors, they were asking for rs.650 each to repair,i got it done in 20 bucks thanx a million bro god bless | ||
| | #12 | ||
| Dear sir, its nothing but the capacitors they have used is under valued i.e instead of 16v or 25v they have used 10 v .using 25v caps will solve the problem permanently. | ||
| The Following User Says Thank You to shabeerpasha For This Useful Post: | abhiG (4 Weeks Ago) |
| | #14 | ||
| Member Join Date: 06-07-2008 Location: india
My System: zenega1004is | hi i want to convert my cd 1004is zenega settop box of dishtv to operate for dth(free to air) can anybody help me how to convert it in free to air in the market some technicians are doing it,but i want to do it myself please help me | ||
| | #15 | ||
My System: zenega cd 1004is | hey hsarp u get them easily in bombay, at lamington road or any roadside electrician will have them, for about 20 , 30 rupees they will solder it on for u aswel in dubai im not sure, may be ur local electrical store should have it | ||
| The Following User Says Thank You to rightsameer For This Useful Post: | hsarp72 (10-10-2008) |
| | #16 | ||
My System: zenega cd 1004is | and why it happens is , mostly coz of an overload of power, when thers disruption in power supply or voltage fluctuations | ||
| | #18 | ||
| Member Join Date: 13-10-2008 Location: India
My System: Dish TV, Zenega 1004iS | Hi VED I understand from your post that u hv idea about circuit of zenega 1004iS. please help me giving following data 1. the satellite tuner ic is used 2. the channel decoder is used 3. the micro controller is used 4. flash ROM ic is used 5. RAM ic is used Better if you put a circuit diagram if available. Secondly to convert the zenega 1004iS into a FTA stb hardware is to be changed at all or no or else. thanks | ||
| | #20 | ||
My System: Dish TV, Zenega 1004iS | hi i want to convert my cd 1004is zenega settop box of dishtv to operate for dth(free to air) can anybody help me how to convert it in free to air I want to do it myself please help me in detail step by step. Thanks | ||
| | #23 | ||
My System: v | hiiiii akdesarkar sorry for late reply ya its possible to watch free to air channels in any firmware . no need to change sofware . sorry but its my bussines we cant share here | ||
| | #24 | ||
| Member Join Date: 04-01-2009 Location: Dubai
My System: Zee Dish TV | There are 2 capacitors of 1000uf/10v. Both may not e faulty but just in case change them both to 16v or 25v. You can open the decoder and easily unplug the power supply board and take it to a local electrician. Thanks to all for the valuable information here.. saved me some bucks and the time.... | ||
| | #25 | ||
| Member Join Date: 15-07-2008 Location: india
My System: zanega-1004s | | ||
| boot, cd1004is, problem, zenega |
