Technomate 3100D Can't Load a PatchInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Member Join Date: 29-09-2008 Location: Lancashire
My System: I don't have any equipment. Looking for a full system |
Hi everyone, I have a Technomate 3100D and have been trying to load a patch. I am using Darkman v1.1.2 loader and 3000_P_Series_180908_216.bin firmware (but have tried others). I can communicate from my PC to the receiver but when I try and upload a new firmware it says "transfering...." but doesn't appear to do anything. If anyone has any ideas I would be grateful of the help. Thanks. Chris | ||
I have now sorted this problem. I was using a USB to COM Port adaptor but have now tried it on another PC with a proper COM Port and Hey Presto it loads. | ||
| | #3 | |||
Unfortunately all my experiences with these adaptors have been poor to say the least, glad you solved the problem, I suspect though that you have to alter the com port number used to one the software understands that is all. | |||
My System: I don't have any equipment. Looking for a full system | Thanks Topper but it was definitely the correct COM port number as I could see the boot messages when I rebooted the technomate which also means that the speed settings must have been right aswell. I use the COM port adaptor a lot for work and most of the time it's OK but can't understand why they don't put proper COM ports on laptops or even some PC's these days. | ||
| 3100d, load, patch, technomate |
