Golden Interstar DVB-T/S 8700CRCI PremiumInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Member Join Date: 27-10-2008 Location: spain
My System: Golden Interstar sat box windows xp | I have the .bin update on my computer for this sat box & have connected relevent cables (serial port). When I go into System Setting & try to upgrade all I get is "Please unplug and then plug in the STB power cord" I do this & nothing happens. What am I doing wrong? My PC doesn't appear to be connected. Should I be doing something different? Many thanks | ||
Welcome to the forum aeb38 Perhaps you are using the wrong type of cable? i.e. is it a null modem cable? What software are you using on your PC? When you say system setting do you mean on the stb? If so that setting is normally used for OTA downloads over the air from the satellite not for flashing via a com port | ||
My System: Golden Interstar sat box windows xp | Hi See attachmentAttachment 18600 Didn't know had to use any sort of software for upgrade. Just got the zip bin file software upgrade from Golden Interstar site as software not been updated since 2006. Yes it is null modem cable. System setting yes, stb. As I am very, very new to all this; I'm probably doing it all wrong so can someone explain SLOWLY what software I need or what to do as why is it saying use serial cable? Thank you. | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | A straight serial cable is only needed for STB - STB transfers, which is what your menu shows. You need a null modem cable, but more importantly a software program for the transfer from PC to your STB. Where you get one from I have no idea, all searches I've done bring up Russian sites. Llew | ||
| | #5 | ||
They have a comprehensive website _http://golden-interstar.com/downloadcenter.php The download section is about as useful as a chocolate teapot perhaps the email address will get you some sort of response, on the other hand perhaps not unless your German is any good. You could of course use Google translation | ||
| 8700crci, dvbt or s, golden, interstar, premium |
