StrongSRT4620XInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Member Join Date: 30-12-2008 Location: saudi arabia
My System: satelite - hotbird Receiver - Daydream - DRM1000 | some one please explain how to connect strong SRT4620X receiver with pc ... and which program is to be used for communicating with the receiver (down loading /uploading data, programs etc...) Thanks .... | ||
| Regular Member Real name: Bob Join Date: 31-08-2008 Location: Weymouth,Dorset,UK
My System: 60cm SKY Dish with PACE Digital Digibox, 90cm PHILIPS (Fibo clone) Gregorian (started with all original features). MTI AP8-TW LNB. TECHNOMATE 5500 CIP PLUS Receiver, STRONG 4375(as Backup) | Hi Try this link _http://www.strong-technologies.com/frmRegionSoftwares.aspx?PID=167&RID=1 Hope this helps Bob | ||
hello I downloaded the uploader and instructions from the site you refered. But when I start the uploader and connect the receiver as per instructions , nothing happens ... 'connect your receiver and turn it on' message remains. I use a laptop and it has no com port I use usb to serial adaptor. my present port settings are as follows:- Prolific usb to serial common port(com4) bits per second - 9600 data bits - 8 parity - none stop bits - 1 flow control - none your help highly appreciated. | ||
My System: 60cm SKY Dish with PACE Digital Digibox, 90cm PHILIPS (Fibo clone) Gregorian (started with all original features). MTI AP8-TW LNB. TECHNOMATE 5500 CIP PLUS Receiver, STRONG 4375(as Backup) | Hi Have you downloaded the software as you dont mention it. It could be that your cable is not suitable or that your settings are incorrect. Have you a manual to look at as it might help Bob | ||
| | #5 | ||
This could indeed be your problem, I have a few years experience with these USB to serial adaptor cables and they often do not work for no particular reason at all. Try to get an old laptop from a friend and try again Are you trying with a serial cable or a null modem cable, there is a big difference | ||
| | #6 | ||
| Member Join Date: 18-10-2008 Location: Egypt
My System: STRONG 4620x | ٍSALAM I have the same receiver , and as Topper said the problem is located in the connection cable . you should make the connection with a (9 nine) pin cable RS-232C ( one end is male & the other end is Female cable ) and connect your PC to the receiver . that will solve your problem . It is not a big deal , this cable's type is available in the computer shops . But , you should ensure that the last manufacturer software version is SRT4620X_4651X_4654X_116_20081009.stb you can download it from the manufacturer official site (strong-technologies.com) along with the uploader program as Topper told you . if you need any further assistance please send a mesage , no problem Regards | ||
| | #8 | ||
My System: satelite - hotbird Receiver - Daydream - DRM1000 | salam the software version of my receiver shows - 1.41p(Feb 04 2008) i don't know whether it is the latest... and as you know i cannot upgrade it because of connection problem. my cable is 9pin both ends female. receiver side and pc com port side it is male .... so i have to use both end female cable in between bye | ||
| | #9 | ||
Check that your cable is wired as per the picture | ||
| | #10 | ||
SALAM I am so sorry , after checking the other end which is permenantly connected to my reciver I found it also Female , SO , BOTH ENDS ARE FEMALE The last version is SRT4620X_4651X_4654X_173p_20081230.stb I just receive it today , as you see the date is DEC. 30 ,2008 . through STRONG Technical support center in DUBAI , you may contact them and they will send it to you. Also as Topper said you have to check that your cable is wired as per the picture above. that to confirm your cable and ( 9 pin outlets are OK ) if you have any problem to contact them please let me know and I will send you their Email address ( if that be allowed from this site adminstrator) REGARDS | ||
| | #11 | ||
My System: satelite - hotbird Receiver - Daydream - DRM1000 | Thanks guys .... the problem was same as you all mentioned ... my null cable was not correct .... i changed it with a new one and it worked. i successfully downloaded to my receiver the latest software version from strong site which is dated Nov 03, 2008. i would like to thank everyone one more time .... Now i want to know the next step .... what scrambled channels i can open with my receiver and for that purpose what kinds of files i have to down load in to my receiver ..... and what is the procedure.... thanks again.... | ||
| | #12 | ||
Well there is almost nothing open these days to speak of and what is open i.e. 1 deg West Digi TV could go dark any day. If you have loaded firmware from the manufacturer I doubt that would open anything, you would need a patch to do that and I am not aware that unofficial firmware is still being made for the Strong stb's | ||
| | #13 | |||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue |
From your location in Saudi Arabia I very much doubt ANYTHING can currently be opened on that receiver. | |||
| strongsrt4620x |
