I need help to upgrade my StarSat SR-X95USB !Information exchange on receiver software, including updates, problems and fine tuning. | |
| Member Join Date: 19-02-2008 Location: Albania
My System: nokia mediamaster 9800s hp compaq d330 |
Hello! I downloaded the last software update for my Starsat sr-x95usb ( ver 1.68 date 06.02.09 ) and I have done all that was said at readme file that was inside of winziped file that I downloaded but when I run easy upgrade and the rom file the booting dosn't start and the percent stay 0% always. What can I do to upgrade ? I must say that in my pc I run Vista Ultimate Sp2. Thank You ! | ||
Has this update procedure been performed successfully before with Vista SP2? | ||
My System: nokia mediamaster 9800s hp compaq d330 | Hello ! Thank you for your faster response ! Is the first time that i prove to update my star sat software so i can't say anything about any previous experience ? Can you tell me the steps one by one maybe I haven't done the steps at the right way or maybe this update dosen't run with vista sp2 ? Please someone help me as soon as possible ! Thank You All ! | ||
I am sorry I do not know your stb and therefore the required steps involved. Generally you connect a PC or laptop to your stb using either a null modem cable, standard serial cable or usb cable, then using the appropriate software backup your system, channels satellites etc. Then select the update software and load the flash firmware on the PC, then update usually by switching off the stb and switching on again and allowing the update to take place. Why not find instructions here | ||
| srx95usb, starsat, upgrade |
