Strong SRT4663X Keys
Information exchange on receiver software, including updates, problems and fine tuning.
Old 07-07-2009   #1
My System: Big Satellite Dish and Strong SRT 4663X box
hey,
how do i enter keys in to the Strong SRT4663X?
thanks
gkapoor is offline   Reply With Quote
Old 07-07-2009   #2
Amo Amas Amant Admin
Topper's Avatar
Ermm
Originally Posted by gkapoor View Post
hey,
thanks
What have you patched it with?
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Topper is online now   Reply With Quote
Old 09-07-2009   #3
I haven't patched it. How do i patch it what file do i use and everything can you please explain it to me and provide me with all files needed.
thanks
Old 09-07-2009   #4
Topper's Avatar
Well
thanks
The simple answer is I do not know the exact procedure you need to input keys or update your firmware as I do not possess your stb and there are thousands of makes and models all of which are slightly different incorporating different firmware loaders etc.
This is a self help forum, it is up to you to search the forum for the reference strong and see what threads appear. It is is not a case of ask and ye shall receive it is your responsibility to look for and find the required software possibly using the links section as a starting point or the threads as described earlier. Your main problem will be that if nobody is modifying firmware for your model you will not be able to do anything anyhow. Also there is the fact that flashing your stb can render it useless if the process is interrupted or you select the wrong firmware.
These two links will help you start your quest, but I doubt there is anything to open down under, the same as there is little open here
So you want receiver software patches (v2)
The Big Links List
Show Your Support
Thank you.
Old 09-07-2009   #5
Do you have the manual for use of the patch with M.O.S.C card please help ?
Albin NDIA is offline   Reply With Quote
keys, srt4663x, strong
[IMG] code is Off
