Help connecting 2 sat boxes
Information exchange on receiver software, including updates, problems and fine tuning.
Old 18-09-2009   #1
My System: fujitsu siemans
Hi I have a lyngbox and a humax freesat box.they are connected to a 4 way disec switch which then goes to a smart priority switch then one cable to lyngbox and the other to humax.Both work fine but only when 1 is powered up and the other is instand by, I understood that both would work at the same time as long as they were on the same satellite in either v or h frequency Any advice please
scart is offline   Reply With Quote
Old 18-09-2009   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
No, you can only have one receiver working and one in standby with the priority switch. That's why it's called just that.
Llew is offline   Reply With Quote
Old 18-09-2009   #3
Toute Ronde Bon Oeuf
Tivù's Avatar
Real name: Gordon
If, instead, you Loop Through from one box to the other, it would work as you thought: ie The Box that has it's LNB power activated will control Band Switching and Polarity and the other Box would get Channels of the same Polarity and Band as the first.
The possible problem with this is that the Humax (If it is a Foxsat non-PVR) has no loop through, so you'd need to connect te dish to your Lyngbox and then loop out to the Foxy - and that assumes the Lyngbox has IF Out/Loop Out. Does it?
Edit: I've no knowledge of the Lyngbox, so have just run a cursory eye over some Googled specs - It appears it may not have IF Out/Loop Out so you are stuck with what you've got!
Tivù is online now   Reply With Quote
Old 18-09-2009   #4
Thanks for the replys guys, you are right tivu the lyngbox has no loopthru and the humax freesat pvr does have lnb out but for some reason it only outputs when it is powered on.
Old 18-09-2009   #5
Tivù's Avatar
Real name: Gordon
Ok - I had a vague idea the PVR version of the Foxsat had a Loop Through of sorts, but my own Foxsat is non-PVR and doesn't.
Ah well. We make the best of what we have!
boxes, connecting, sat
[IMG] code is Off
