Receiver Flashing using USB to SERIAL adaptersInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Regular Member Join Date: 14-08-2004
| Thats incredibly annoying as it look as though i might have to use a USB/Serial adapter too. I had worried that it would not create the sufficient com port but as there was a derth of information on the subject i've taken the plunge and ordered one. I'll let you know how i get on and if i find a way to do it. Mark | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Which programmer have you ordered, apparently the Elvis USB works well in phoenix mode without a serial connection. | ||
| | #3 | |||
Sorry if i've taken over this post - wasn't my intention! | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Try this one - works for me:- | ||
| | #5 | ||
| That bit already works - its the actual patch that deosn't work, what the website calls the 'Patch Firm. Allcam for decoders Aston Simba'. I can download it fine, its just that the three files are corrupt and i can't do anything with them. DO you have them? | ||
| | #6 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Sorry - some time since I used it. I'll see what's on my other PC. | ||
| | #8 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Yes the file on Le Caf is corrupted as you say. I've zipped the original on my PC and you're welcome to use it. Not sure of the size limit we can upload, but here it is:- | ||
| | #9 | ||
| cheers-found a few different versions so i'll just check. I'm getting to a certain point in the flashing process then it doesn't work. i'm supposed to get a grey menu (http://www.la-cafetera.com/manualrj45.htm and you'll see which one i mean) after the first few yellow lines. any clues? i know it was a long time ago! | ||
| | #10 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Are all leds on in the receiver? If so it's ready for loading. Do you have a jumper between 6 &7 of the RJ45 on your interface? if so this must be in place before switching on receiver. | ||
| | #11 | ||
| Now my version of jumpers are the little black things that sit on pins, is that what i'm looking for? If so, the RJ45 interface i bought has one but its on two pins outside of the rj45 interface on the card. No interference with the pins themselves. | ||
| | #14 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | If you can bear with me, I'll set up my Simba and see how far I get... I'm sure I had this trouble when I first tried. Doing it again might reactivate my brain cells | ||
| | #16 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Hold the beer - You haven't got it going yet - Mine comes up immediately wih boot and flash ready.Your problem seems to be between PC and interface.The receiver will show 'boot ready' if you have the interface connected to the receiver regardless of whether you have communication between interface and PC. Check your serial connection. Llew | ||
| | #17 | ||
| aha, that may well be where the problem is. i've had to use two serial cables connected 2gether because of male/female issues. is that likely to cause a problem? also, where on the receiver should it say boot ready etc? i've got a simba 201 and there's no readout on the front panel. | ||
| | #18 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Ah yes - I've got an Simba 1.5. I'll spare you the gory details exept to say that I killed the processor in the Simba 2 checking a fault, managed to aquire a cheap Simba 1 and stuck the front of the 2 on it, which has a display. You'll be just concerned with the LEDS. The serial cable has to be straight through, not null,as you're working 'through' the interface, not terminated by it, as you would if you were connected directly to a receiver. However many cables you use, straight through it is. Llew | ||
| | #20 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Not sure myself about that one. If that's what you have to use, you can give it a try. | ||
| adapters, flashing, receiver, serial, usb |
Similar Threads | ||||
| Will USB - Serial Cable work? Which Reciever? | ViReN | Receiver software, international Section | 8 | 31-07-2006 08:45 PM |
| How do i UPDATE by USB to Serial on an Openbox_x800. | weddings | Receiver software, international Section | 0 | 28-02-2006 11:32 PM |
| Matrix Reloaded How To by AHAC | rolfw | Matrix Reloaded, Revolutions and CAS interface | 52 | 27-12-2005 12:02 PM |
| Freeview receiver spec will omit 7-day EPG | net1 | Terrestrial Television, Digital and Analogue | 0 | 27-06-2003 08:56 PM |
