Humax IRCI-5400Information exchange on receiver software, including updates, problems and fine tuning. | |
| Long Term Contributor Join Date: 01-01-2000
Been using a technomate for the last 2 years having moth-balled one of the above receivers. I'm now reading about ToH and Hot 1.9 etc. Could anyone tell me what these upgrades provide and also can they be installed by a lay-user such as myself? thanks in advance..any help appreciated. | ||
| Regular Member Join Date: 27-07-2004
| ...first of all , you have to find out the loader version (the one that shows up in the display when the machine boots up) .. it schould be L 2.08 or H 2.o8 which means you can upgrade straight away , just using a null-modem cable. if the machine has been patched before itīs recommended to install original firm (matching with hardware id) then install toh 3.2 . then hot-emu 1.8 thereafter hot 1.9 at last you have do load the current key.bin while machine is switched on. caid select(menu toh config) has to be on emu+k and a smart-card has to be inserted (any ,even out of date or expired , the machine does accept) emu supports via , seca , irdeto , beta , nagra , conax ; unfortunately no AU yet (but the guys are working on it). a good thing to do is , downloading the "humax toolbox" which provides a collection of very helpful tools (definitely all you need to do a perfect job) normally you just need two programmes : the humax uploader for the hdf-files (firmware ; patches) and the s+humi edit to load the key.bin . ...thatīs it .. so good luck dishead | ||
| Regular Member Join Date: 23-08-2004
| | #5 | ||
| Member Join Date: 01-09-2004
| The beast receiver humax5400 and the lats patch for it:3.3 File removed by Admin, contains card emulator file can be obtained from http://www.hutsefruts.tv | ||
| humax, irci5400 |
Similar Threads | ||||
| Humax Irci 5400 Not Working | armarchant | The Work Bench and Soldering Station | 0 | 10-05-2006 08:24 PM |
| humax 5400, what will give me the most content | ez_livin | Receiver software, international Section | 3 | 07-03-2004 09:46 AM |
| Humax 5400 - TV Sport RO Blinking.. | wildfire2001 | Jimbo's Football and Sport | 1 | 29-02-2004 03:25 PM |
| Humax 5400 PSU OPT1 details? | ajtdmw2003 | Digital systems | 1 | 02-01-2004 01:00 AM |
| Humax 5400 v Manhattan/Technomate/Echostar | Ben Jaud | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 6 | 22-08-2003 11:12 PM |
