Please note how the ZENEGA STB Edit function will work.
Information exchange on receiver software, including updates, problems and fine tuning.
Old 24-08-2004   #1
Bandit Queen
Vivek's Avatar
My System: Satellite Blood
Thumbs up Please note how the ZENEGA STB Edit function will work.
Dear Friends,
Press Menu button & come to system information, select Software upgrade, press 9009, and now new window open. Come to Factory Data & press ok now wait for a minute and after come back to Installation, select the search setup & press ok, now select the TP & press GREEN Button for Edit or press Yellow Button for ADD. This system will work for only one time.
Cowboy....
Vivek is offline   Reply With Quote
Old 24-08-2004   #2
Hi Vivek
I appreciate for your observation of receiver behavior.But this also very short solution. You can select only listed satellites.And listed TPs only. You can't add your wished satellite and TPs.And I tried with other receiver which not supplied by Zee. In that receiver NSS 86 is not listed and not addable, so not
available.And you know always tuning your receiver to factory data and putting and selecting the TPs also cumborsome.Any your work should be apreciable.Thank you very much for your contribution.
Best regards
G.Markandeya
Originally Posted by Vivek
Dear Friends,
Cowboy....
markand is offline   Reply With Quote
Old 24-08-2004   #3
Bandit Queen
Vivek's Avatar
We are trying but you have any secret password please give us
Old 24-08-2004   #4
Hi Vivek
No, I didn't have any secret codes. If I got them I wiil deffinately share with all of you.
Best regards
G.Markandeya
Old 24-08-2004   #5
Bandit Queen
Vivek's Avatar
Originally Posted by markand
Hi Vivek
Best regards
G.Markandeya
Hi G Markendeya,
How can I download my zenega receiver program file to my computer?
Old 24-08-2004   #6
Bandit Queen
Vivek's Avatar
Cool download my zenega receiver program file
Hi Vivek
Best regards
G.Markandeya
Hi G Markendeya,
Old 24-08-2004   #7
Sorry vivek,
we are unable to to upload the program but data is possible.
markand
Hi G Markendeya,
Old 24-08-2004   #8
ok thats true.
but no need to go to software upgrade section. Just simply press menu and 9009 u will get the set-to-set download window. now do as directed by vivek.and thats all.
But I think this has been described earlier by Nictus34 too.
Dear Friends,
Cowboy....
lokesh is offline   Reply With Quote
Old 25-08-2004   #9
Hi Markand,
Can you pls explain how to download the software program Zenega to PC?
If this is possible through Hyperterminal, Then plz gimme the pin-outs for Rs-232 Cable.
Is there any method, how to STOP downloading the Software automatically from satellite & upgradation procedure which converts our Receiver into Decoder!
HellCrusher
Sorry vivek,
markand
HellCrusher is offline   Reply With Quote
Old 25-08-2004   #10
Bandit Queen
Vivek's Avatar
I know set-to-set download, but I want to know how to download software from my set to my pc.
Cowboy.......
Old 25-08-2004   #11
Bandit Queen
Vivek's Avatar
vek_ess
Originally Posted by lokesh
ok thats true.
However, lokesh new v1.20 they already delete edit function.
Old 25-08-2004   #12
HI Vivek
Please read and use this thread
"ZENEGA CD -1002S software needed for Dish TV India" instead of starting repitation of one question 100 times.
All your answers and questions are in detail in this thread : ZENEGA CD -1002S software needed for Dish TV India. So use it and write there
I hope you will never mind and avoid repitition again and again of one basic question repetitation in this thread
Tom Robert is offline   Reply With Quote
Old 26-08-2004   #13
Bandit Queen
Vivek's Avatar
Originally Posted by Tom Robert
HI Vivek
will you received my mail..............................?
Old 28-08-2004   #14
Bandit Queen
Vivek's Avatar
Dear All,
This to inform you that ZENEGA STB Model 1005 S is good for all the purposes. Its Installation function is really marbles.
Old 28-08-2004   #15
Bandit Queen
Vivek's Avatar
Thumbs up
Hi Vivek
Best regards
G.Markandeya
NO BOSS....
This is not truth , it can add or edit any TP & Sat. just checks it.
Cowboy..............
Old 02-09-2004   #16
I have need super laser software & till me about receiver software site thire new software thinks
habibbullah is offline   Reply With Quote
Old 07-09-2004   #17
Bandit Queen
Vivek's Avatar
Talking
Dear Habibbullah,
as to tom i think he has..........
Old 16-10-2004   #18
yes sir ur right i got ZENEGA 1005S. I CANT ABLE TO ADD TP & SYMBLE RATE ?
DOES ANYONE HAVE SOLUTION FOR THIS.
THANX
kajoor is offline   Reply With Quote
Old 19-10-2004   #19
Arrow
deleted because this is severely repeated in other thread of Zenega
Old 19-10-2004   #20
hello can u chat with me tom
iam online now.
Old 05-04-2005   #21
My System: SEUPER LASER
Hello to all
please help me how can i Upgrade my Super laser 10000 STB?
hmalzomati is offline   Reply With Quote
Old 06-04-2005   #22
My System: HI
hi vivek.
you cannot see any satellite other than nss6 and insat because they have made the revceiver to suite their requirements...( the software is developed for dish tv ) so if you can get the original software for zenega receiver then the problem will be solved (I guess)....i am in search of the software..if you get it please share....I will do the same...
cheers..
Hi Vivek
Best regards
G.Markandeya
touchmate is offline   Reply With Quote
Old 15-04-2005   #23
respected members,
can any one tell which mcu & flash ic are used in zenega receiver i can help you via jtag or loaders or universal programmer.i new in this forum
siva73 is offline   Reply With Quote
Old 19-04-2008   #24
My System: PINTIUM 4 256MB 40GB INTELCHIPSET
Originally Posted by Vivek View Post
Hi G Markendeya,
AMAN_MONA is offline   Reply With Quote
edit, function, note, stb, work, zenega
[IMG] code is Off
Similar Threads
Official TD Image Llew Triple Dragon 29 13-12-2007 04:56 PM
So You Want Receiver Software Patches? Analoguesat Receiver software, international Section 438 08-02-2006 05:50 PM
HDTV Primer spiney High Definition Receivers transmissions, satellite and Terrestrial 0 16-01-2006 12:42 PM
Matrix Reloaded How To by AHAC rolfw Matrix Reloaded, Revolutions and CAS interface 52 27-12-2005 12:02 PM
Will this cabling set up work?? cslogg Terrestrial Television, Digital and Analogue 8 11-02-2004 09:39 PM
