Help me for cable RS233CInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Specialist Contributor Join Date: 05-04-2004 Location: Manchester, UK
| I think you mean RS232. The site here http://www.arcelect.com/rs232.htm has lots of info - search it for "Cable pinning". You'll need to decide if you need a straight thru or null-modem cable to connect to your receiver. It's useful to have both types of cable really. | ||
| Regular Member Join Date: 20-09-2004
| M. reza63 if you need some cabel to make it you can go to the sit that down in the page. there is maney cable's you can find . I hope dat can helpe you........................................... http://www.null-modem.com/NullModem.htm | ||
| | #6 | ||
| Regular Member Join Date: 17-09-2004
| Yes thats correct for humax you need null modem cable: pins: 5 ---5 2---3 3---2 Thats it. But why you dont buy one m8 you have it any Computer store! Are you new in patching?? what kind of humax you wanna patch ? Zap. | ||
| cable, rs233c |
