Manhattan DSR 5500CI-IR HELPInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Member Join Date: 07-08-2004
I use the following: Receiver: Manhattan DSR 5500 CI-IR Firmware: V. 3.15.11ECI_F 6 in 1 fun card and Mach 1 files: Mickey6in1_V4.4Flash.hex Eprom 26.9.2004 humax nokia eurocam.hex Until a couple of months ago i could received Multivision, Polsat and AB Sat, but now I receive only part of AB Sat Channels. What should I do. Grateful for your assistance. Best Regards ev1964 | ||
| mandu34 Join Date: 02-04-2005 Location: africa
My System: BB | please do you the type of CAM that goes with yours iam loocking one for my Manhattan dsr 2500 cip thanks issa.seye@laposte.net | ||
| | #3 | |||
| Member Join Date: 10-03-2009 Location: england
My System: humax 5100ci manhattan dsr-5500ci-ir |
Hi, It is probably a long shot as it's been a long time since you posted this message, but I will try. I hace the same receiver and 6in1. My ir*eto was patched to Alphac*ypt 1.0 from Mascom gmbh. I can see 6in1 card name in ci config menu but nothing else. I tryied V. 3.15.11ECI_F firmware and audioman 0.98 and al7bar321 but no luck. Does your configuration still work? Can you receive any encrypted channels with this receiver? Did you have to patch your embedded ir*eto? with what software? I would appreciate some feedback. Thanks, Rob
| 5500ciir, dsr, manhattan |
Similar Threads | ||||
| manhattan 5500 magic module | wopla | Magic Module | 12 | 28-08-2004 06:51 PM |
| Manhattan DSR 5500 CI Manual needed | Juni0r123 | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 0 | 30-07-2004 03:25 PM |
| Diseqc problem with Manhattan DSR 2500 APCI | moordown66 | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 5 | 12-06-2004 04:19 PM |
| Problem with Manhattan DSR2500APCI | zarf99 | Digital systems | 6 | 19-09-2003 01:47 AM |
| 1.1m, manhattan 3000 + cam. Is it OK??? | satel | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 3 | 05-08-2003 08:37 PM |
