Arion Af-1500eInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Member Join Date: 25-09-2004
| Please if anybody can help me with this arion AF 1500E ? I flashed with the 1700file and it doesn't work.Does anybody now with wich file and transporter shoud I do.if anybody now please contact me: cborkovic@sympatico.ca. Thank you!!!!!!!!!!!!!!! | ||
| The Following User Says Thank You to JELENA For This Useful Post: | agourram (13-02-2008) |
| | #2 | |||
| Member Join Date: 21-10-2004
| Member Join Date: 11-10-2004 Location: Brussels , Belgium
Prvo pozdrav Jeleni i Lateku i pitanje dal radi fino risiver sa ovim firmware-om i sta se moze gledati (u Evropi)? i dali se i kako mogu ke*evi ubacivati? hvala unapred! ....and to translate :P how does reciever works with this firmware, because i bought some other reciever (Coship 2300A) and it works but sound is crap (different HW and SW so crap with firmwares wich doesent work proper) is here allso important that?, so if this is OK for any receiver with this number (arion 1500) i'd like to buy this one, so somebody please answer is everything OK and i didnt see nowhere explanation about ke*s , some file ( do i upload it with arioner_022) or remote instruction to do it...... thx in advance! Regards... | ||
| | #5 | ||
| Member Join Date: 15-04-2004
| The arion is much better than Coship. And the upgrade much easy. (to many différent version soft for the Coship). For the upgrade of the arion, you can use the same cable than the Coship. B. Regards. opposum | ||
| | #6 | |||
so u propose to buy this receiver? do it decode same like Coship (VA,IR,Nagra, Se*a) on hotbird and astra?(i'm interested in multi, tps,xxx,italian sky, and all others :P) because i dont see nowhere nothing about ke*s, just found on some forum how to do it with remote and nowhere some .b*n or its .a*c ke*s file? and on arioner 22 or 24 i dont see option to upload ke*s. so in few words pls explain to newbee what and how can i decode things on Hotbird and Astra to do not get again in trouble to put another 85€ in garbage (Coship) lol! thx!Regards. | |||
| | #7 | |||
| Member Join Date: 27-12-2004
thank you | |||
| af1500e, arion |
Similar Threads | ||||
| Ajuda - ARION AF-2000e | portkaku | Arion | 3 | 19-04-2006 11:29 PM |
| ARION AF-2000e - HELP | portkaku | Arion | 2 | 12-04-2006 12:03 PM |
| My Arion 1500E is dead - please help!! | she12126 | Receiver software, international Section | 3 | 10-03-2005 09:58 AM |
| Download AF1700e | Fly03 | Receiver software, international Section | 9 | 10-03-2005 09:44 AM |
| Arion | e0032169 | Receiver software, international Section | 0 | 05-03-2005 04:41 PM |
