Fortecstar FSCI-9800V2...please help!Information exchange on receiver software, including updates, problems and fine tuning. | |
| Regular Member Join Date: 16-05-2004
| A friend is in trouble as while trying to upgrade an FSCI-9800V2 something unknown happened that resulted to a half-dead set. Does anyone know of any codes that could be useful in reviving a set in this condition? Thank you. | ||
| | #2 | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed |
What version of software was he using and from which site? What do you mean by 'half dead set'? - Can't access menus? Remote not functioning? Anything on screen at all? | |||
| The receiver shows nothing on the screen and the only light on the panel is the dot in the center. Remote control is recognized as indicator on the far left of the panel blinks each time a button is pressed. The receiver does not switch on. The software was downloaded from fortecstar's website! | ||
| | #5 | |||
Perhaps you have used the wrong application? If this is so, you may have corrupted the flash memory. Try sherrit's file above. | |||
| fortecstar, fsciplease |
Similar Threads | ||||
| patch for fortecstar 9800v2 | abu | Receiver software, international Section | 0 | 12-12-2004 07:52 PM |
| FortecStar 9800V2 patch | hassenos | Receiver software, international Section | 2 | 14-10-2004 01:09 PM |
| Fortecstar Fsci 9800 Code Menu Software | zafarjoia | Receiver software, international Section | 1 | 19-09-2004 02:04 PM |
| Fortecstar 9800V2 | nazir1970 | Receiver software, international Section | 0 | 18-09-2004 09:14 PM |
| Searche for fortecstar 9800v2 patch | adaroubala | Receiver software, international Section | 0 | 26-04-2004 08:58 PM |
