can anyone help me for software upgrade coship 2300A?
Information exchange on receiver software, including updates, problems and fine tuning.
Old 30-10-2004   #1
Thumbs up can anyone help me for software upgrade coship 2300A?
I want to know wich cable you need to use uptool V3.0 ,i always get message "connection error" i tryed cross cable and straight cable on com1 ,i followed all instructions..when boot is displayed connecting ....and i wanted to know if anyone could send me the new codes for 13° hotbird channels (all codes are welcome ...thank you for helping...
Bjorn.
bjorn69 is offline   Reply With Quote
Old 30-10-2004   #2
A bit enthusiastic
My System: Giberini 100,Cut Interstar GI-201,CD-80 feedhorn,Humax 8100 PVR,Coship 2300a,18 meters of Antec Superflex 1.6/7.3
Bjorn.
The cable your supposed to use is soldered like this
pins 2-3
3-2
5-5
Try having the upload tool running while you switch on the main switch on the back of your reciever.
You can use fresh "softcam keys" to get the p*y channels working and don't be too lazy reading the info about the Coship in this forum,lot's of posts about it here!
steffan_st is offline   Reply With Quote
Old 30-10-2004   #3
i tryed that one already ....
that is the standard pin connection of a rs232...when I put on the the tool to upgrade software it gives a message board "connecting....." then I put on my coship and it keeps going booting and normal..bootingand normal...and on and on...and i will look furder for "softkeys" thank you I think that today I passed 4H searching in forum ....
but I am glad that I got an answer that quick thank you !!!and hope you can guide me a little more...
Bjorn.
Old 31-10-2004   #4
A bit enthusiastic
Bjorn.
Sorry Bjorn,can't help you when the reciever is behaving like that,there used to be a lot of coship j-tag talk at AL7BAR.CA,but link seems to be dead.
Old 31-10-2004   #5
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
Bjorn.
Try Albar.tk. Some stuff for Coships there.
Llew is offline   Reply With Quote
Old 31-10-2004   #6
tryed to go on site
can't go on site says it doesn't exists....is it www.alar.tk ?
Thank you,
Bjorn.
Old 31-10-2004   #7
Llew's Avatar
Thank you,
Bjorn.
Sorry bjorn. My typo. This is the site:-
http://www.al7bar.tk/forums/index.php?
Old 01-11-2004   #8
i am have problem in my digitall world reciever plz help me i download new software in my reciver (sc1-190m)when i complete software and i did factory reset and again chanel scan all chanell there but when i turn off my reciever and on again it leave all chanels and show no chanel list i did again and agian scan but it all time do that i am very worried plz help me
jeemeher is offline   Reply With Quote
Old 02-11-2004   #9
Cool I found the way to upgrade thanks to all
But now my problem is ...I loaded old software in it can anybody tell me were i can find the newest software?
Thank you all!!!!
Bjorn.
Old 02-11-2004   #10
A bit enthusiastic
Thank you all!!!!
Bjorn.
Please tell us how you solved the problems to help others!
Didn't get which version of the Coship you have.If you have the first version
I can help you with the best software available (patch).I think that I also have the stock Coship somewhere in my puter if you want that.
Old 02-11-2004   #11
Red face resolved like this...
I saw that on the pins of my coship at the back the pins are not on the same place ....pin 1=5 pin2=4 and so on ..so i switched my cable and everything went fine...i can use for coship CDVB2300A (don't know where i can get more information i looked on the receiver) so if you can give me that software i would be verry thankfull (looked all over the web)...only found old versions...
my e-mail is drachmanb@skynet.be
thank you again ,(to all of you)
Bjorn
Old 03-11-2004   #12
hi there
i see that steffan_st is still active inhere and i dont know did he read one of my posts where i asked ke*s for HRT ( 12520V on Hotbird) and all other ex-yu channels (pink12577H Hotbird , hayat 12303V Hotbird, albaniaSat 11449H EutelsatW2 16°E...) so if him or someone ellse can help me please write and send ke*s on ljaljo_2884@msn.com , subject:ke*s ex-yu. thx in advance!
Regards...
ljaljo is offline   Reply With Quote
Old 04-11-2004   #13
A bit enthusiastic
Regards...
Sorry m8,HRT has never worked for me either!
Old 04-11-2004   #14
A bit enthusiastic
Bjorn
Sorry Bjorn but your mailbox didn't accept the software I tried sending you,too big file?
Old 05-11-2004   #15
Talking i did receive software
I received the old patch of coship and the old uptool (01/12/03)you have send me ,I found the good way for my coship for having almost al channels,now I use strong technologie and is working fine thnx for all you're help,
Bjorn.
2300a, coship, software, upgrade
[IMG] code is Off
Similar Threads
Coship 2300A and ERR3 kiss Receiver software, international Section 3 26-07-2005 08:25 PM
Need Upgrade "Pace DVR 500 digital integrated reciever decoder" logger17 Receiver software, international Section 3 01-04-2005 07:01 PM
Coship cdvb2300a, h/ware upgrade? GeorgiePie Receiver software, international Section 16 03-12-2004 08:07 AM
Key upgrading error : Upgrade 3.2 with COship 2300A jckfun Receiver software, international Section 1 16-09-2004 11:52 AM
Largest ever over-the-air upgrade for UK digital TV net1 Terrestrial Television, Digital and Analogue 0 07-08-2003 07:30 PM
