Starsat SR X 3500 CUCIInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Member Join Date: 02-08-2004
| Dear Sir, I live in a place where every porn channel is banned ! I have Starsat SR X 3500 CUCI . I want to upgrade the software , so it would be able to get Multivision, XXL , and other viaccess .. ( I have the laptop and the cable ) . Excuse my ignorance, my message might sound stupid, but i am willing to learn. Can you help me by telling me where i can find teh software to upload it to my decoder ?? Thank you | ||
| Regular Member Join Date: 15-08-2004
| Check out www.satsw.com for latest software for ur receiver, same web site has the instruction for upgrading the receiver software and the cable connections too. Standard cable will not work with starsat receivers, need a cable with pin 2 & 3 twisted and 5 direct. BTW if U interested in Multivission XXL etc...... U can just enter the code via remote and it will open these channels. There R several sites which has these keys available, look for TPS keys and enter it in ur receiver and bravooo U got what U want. Let me know if U had any problems | ||
| | #3 | |||
| Hello , Let me express how happily surprised to get this very helpful email from you . to be honest , i did not even expect any answer ! I am new in Satellite cracking ... I live in an Arab country where everything is banned ! even porn sites on the net ! I have downloaded the upgrade for my STARSAT SRX 3500 CUCI . they have two files . first file is 1M and the 2nd is 2M . I could not know the difference and which one to use ! When i connected the serial cable , between the computer and the decoder, i ran the software. But it kept saying : WAITING FOR B00B ( something like that ! lol) , I clicked ok , but nothing happened ! - Is there anything specific i should do on my computer ?? or on my satellite at the time of upload ?? Where can i find a step by step instruction ??? - I have a serial cable Male/Female. on the male side , i have a gender changer, which turns it into a female. I read the pdf file about the connector cables, but i did not understand what should i do? ( I am sorry i am asking so many basic questions, but there is no one around me here who does such things so i can learn from him! you are my only source ! ) Also about getting the keys for multi vision and XXL . I searched the net ! i could not find them ! any web sites you can point out to ?? Please ?? I think i have asked so many questions, all what i hope is to have replies which will be able to make me crack the channels . Thank you so much .. Best regards TJ
| HI, Lets take ur questions 1 by 1 , 3500 CUCI comes in 2 versions, check ur receiver and if it says 3500 cuci plus then it has 1 MB RAM if its 3500 cuci super then its 2 MB RAM so use the correct file with 1 M or 2m. Next the cable, the standard cable will not work make sure U have a cable which has only 3 pins connected 2,3 & 5, pin 2 & 3 should be twisted means pin 2 from one side should be connected to pin 3 of other side and same should be done for the pin 2 of other side also, pin 5 connected directly to pin 5 on other end. Step by step instruction available on the same website I told U before, there is a file there "How to use eMUpgrade" download it and read it and U will know what to do. Sites from where U can find keys are www.rdi-sat.com http://byksat.kabel1.cz/ http://www.luxsat.be/ Look for the keys for TPS Package on these sites and enter the latest keys Lastly U forgot to ask how to enter keys in the receiver :P select MENU on ur remote then INSTALLATION then INPUT CODE then VIACCESS then TPS and then enter the keys Hope it helps | ||
| | #5 | ||
| Regular Member Join Date: 11-02-2005
My System: Starsat sr-x3500 CUCI Super 2M Dish 1,2m dualfeed | Hello friends, I have 2 problems with my Starsat 3500 1. I can bot receive the boquet Premiere on Astra 19.2Est? I can receive all the other channels. 2. TPS are closed from Friday, 25.02, is any new patch for this? | ||
| | #6 | ||
| The new patch is available at www.satsw.com with TPS fix. Cant say anything about premier as I am not receiving 19 degree, It working for me at hotbird though. | ||
| | #7 | ||
| Member Join Date: 26-02-2005
My System: ? | Hi! My cousine has the star sat srx 3500 cuci super receiver, but if you press Menu --> Intallation on the remote control, there is no Menu to input code. ( on the left side, there is a list of Sat´s on the right side there are some options you can change ( e.g. Tp frq ) He did not change anything on the receiver since he has bought it. Must he upgrade the receiver first, so he gains access to the input code Menu? | ||
| | #9 | ||
| Regular Member Join Date: 18-12-2004
| Hello for my starsat SR-X550D Super 2M the software is still not available on http://www.satsw.com/ May I use the software for SR-X550 PLUS 1M V140??? Thanks to answer. Fabrice | ||
| | #10 | ||
My System: Starsat sr-x3500 CUCI Super 2M Dish 1,2m dualfeed | Hi friends, yesterday i got V240super for 3500, and it works (tps). But also i got V240Ultra, and when I upgrade my stb, It change completly that display meny (very cool) but the stb after few sec. display in front panel a message "babo" and stb goes to stand by. to work again stb I have to upgrade to V240Super. Is any way to see on Eutelsat16Est the albanian boquet Albaniansat in Irdeto2, and Digitalb in conax? Thanks, for the great help. The world is more human with you | ||
| | #11 | ||
| Regular Member Join Date: 01-01-2000 Location: scotland and greece
My System: protek 9600ip echolink el888 starsat super 650ci 1.8m precision dish and standalone 36v positioner. | tghattas before you start the simple upload programme switch off the receiver at the back power switch. Start the progamme and when it tells you awaiting Boob click OK and then swich on power again. Good luck | ||
| Dreambox 500s, Protek 9600ip, echolink el888 (not used) precision 1.8m motorised dish. standalone positioner(in scotland)moteck 2100a(in greece) | |||
| | #12 | ||
My System: Starsat sr-x3500 CUCI Super 2M Dish 1,2m dualfeed | Hi friends, I have starsat3500CUCI super, three days ago Mediaset closed. I think I need new patch because the keys can not open. Can anyone help. Contact olssys@yahoo.com Thanks | ||
| | #13 | |||
| Specialist Contributor Join Date: 04-12-2004 Location: Mariana Trench - Pacific Ocean
My System: Vista- DreamBox 7020Si Nabilo Darkstar II -7025+ Black Hole 0.11 - DM8000 BlackHole 0.11 |
Let's wait and hope...... | |||
| | #15 | ||
My System: Starsat sr-x3500 CUCI Super 2M Dish 1,2m dualfeed | This night I saw in RaiUno the Australia GP Formula 1. I was surprise because the encryp. was S*ca and N*s. So I'm thinking that all italian ch. are going to N*s? And if is so, what is the future of stasat 3500? | ||
| | #16 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Same as any other receiver - if you don't have a NDS receiver/card you don't get to watch them. Llew | ||
| | #17 | ||
| Regular Member Join Date: 27-02-2005
My System: Starsat sr-x3500CUCI super | Hi friends, I have starsat sr-x3500CUCISuper, I have IRD tools. Is any other sw that I can manage the channels, my fav.list, satellites and transponders in my computer save in it, and after send to my receiver? Because with “edit” in receiver it takes a lot of time. And, it has happened twice, when I upgrade my receiver with any new batch intead to press “restore backup” I press “save backup” and all my work with channels and favorites goes lost!!!!!! Maybe the same has happen to the others and a sw that makes possible to save all this will be very usefull. Thanks, | ||
| | #18 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Theres certainly a good chance all the RAI's are going into NDS - this from Satkurier, although the info seems a little contradictory! Since 28th of April, three Italian channels RAI Uno, RAI Due and RAI Tre will stop analogue broadcast from Hot Bird 1 - 13E satellite. This situation will probably make more analogue receivers users to exchange it to digital. Most of the channels, which broadcast in analogue from Hot Bird 1 - 13E, have already informed about a date of its termination. Hot Bird 1 - 13E is finishing its service on this satellite position. It has been known earlier, that Polish analogue channels, TVN and TV4 available from Hot Bird 1 - 13E will terminate broadcast, the digital channels of this satellite will be mooved on Hot Bird 6. The Italian public television, RAI has announced, that on the 28th of April 2005 it is finishing broadcast its tree analouge channels from Hot Bird 1 satellite. The reminding channels broadcast in polarization V - RAI Uno - frequency 11.363 GHz, RAI Due - frequency 11.446 GHz and RAI Tre - frequency 11.532 GHz. In this way all RAI radio channels will also stop broadcast from these transponders. In order to be able to watch RAI channels, customer will have to buy FTA digital receiver. RAI Uno, RAI Due and RAI Tre are available in digital MPEG-2/DVB-S broadcast, from the Hot Bird-2 satellite, 13°E position, frequency of 11.766V (SR=27500, FEC=2/3). Unfortunately the Italian channels are to be encrypted in NDS-VideoGuard, the same, wich is in use by Sky Italia package. At the moment, channels will be temporarily encrypted in Seca-MediaGuard 1. RAI Uno is also available in clear from Astra 1 - 19,2E frequency 11.568V (SR=22000, FEC=5/6) | ||
| | #19 | ||
Hi friends, Can U tell me satsw.net is the same as satsw.com? TPS are closed where I have to check for new patch? | ||
| | #20 | |||
| Regular Member Join Date: 17-01-2004
Yes its the same..But no new software.Maybe tomorow | |||
| | #21 | ||
I think that the first site that will put the new p*tch can be consideret as the new SATSW... No one here is able to say why "satsw" is closed... | ||
| | #22 | ||
My System: ? | Hi! My cousine has the star sat srx 3500 cuci super, but he can not upgrade software, because he has no cable. Someone told him a secret code to enter codes via remote control ( enter the sat menu and press 1234, then the menu apears to enter codes ). All codes are input allready, but the screens are still black. Is there a secret code to activate the embeded decryption? ( the receiver is with its original software as it was bought )? Thank you in advance! | ||
| | #23 | ||
My System: Starsat sr-x3500 CUCI Super 2M Dish 1,2m dualfeed | nothing new yet in satsw.net for starsat. It seems that only for starsat hasnt be anything. Because all the others STB can see TPS | ||
| | #24 | ||
| Member Join Date: 19-12-2004
| Hi to you all I have starast 3100 Super and during the last upgrade of the receiver I uploaded it with the wrong software the receiver is blocked. After that I tried to upload the proper software but the receiver cannot be uploaded and the message “Invalid Protocolo” comes up.Could you please tell me if and how is possible to fix that? | ||
| | #25 | |||
| Member Join Date: 28-02-2005
My System: STARSAT DVB: SR-X 150D plus |
Hi, i am using Starsat SX 150D plus , three days ago ( 16 march 2005)i lost access to Multivision channel , i tried to access the site www.satsw.com to download the adequate software but i am always getting the following error : Problem Report The system detected an Unresolved Host Name while attempting to resolve the host specified in the requested URL. Message ID UNRESOLVED_HOSTNAME Problem Description DNS resolution failure encountered. Possible Problem Cause The host entered has a mistake, or the requested Web site is temporarily unavailable in DNS. Possible Solution Examine or correct any mistakes, or try again at a later time. could you please advise me of another available website to download the correpsondant softwrae or if possible to send me by email jacobbec@yahoo.com , if you have any working software for my receiver note please that the previuos working software was : Feb_26_v1266-SR-X120_130_150_4000CH_V7 Feb_26_v1266-SR-X120_130_150_ Regards, Jacob Zakhem4000CH_V7Feb_26_v1266-SR-X120_130_150_4000CH_V7Feb_26_v1266-SR-X120_130_150_4000CH_V7Feb_26_v1266-SR-X120_130_150_4000CH_V7Feb_26_v1266-SR-X120_130_150_4000CH_V7 Feb_26_v1266-SR-X120_130_150_4000CH_V7 Feb_26_v1266-SR-X120_130_150_4000CH_V7 Feb_Feb_26_v1266-SR-X120_130_150_4000CH_
| 3500, cuci, starsat |
Similar Threads | ||||
| Can receiver starsat open free X ??? | zrcom | Receiver software, international Section | 48 | 06-10-2009 07:25 PM |
| starsat 3500 NEW Patch have 6 digit number for MASTER Code | david hyter | Receiver software, international Section | 9 | 22-07-2006 04:09 PM |
| starsat 3500 super and ultra, | dooboryn | Receiver software, international Section | 1 | 29-03-2006 04:32 AM |
| starsat 3500 | ur4me | Receiver software, international Section | 0 | 14-04-2005 09:03 AM |
| Please help me with Starsat SRX 3500 CUCI Super | relaxo2 | Receiver software, international Section | 3 | 20-03-2005 04:47 PM |
