Input Codes By Remote ControlInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Regular Member Join Date: 07-12-2004
Hi, My STB menu looks as a STARSAT SR-650. How can i save hex keys when i finish puting them by remote control. Is there a secret thing to do ??? How to edit Provider ID ? and type of CAS ? (S*ca, Viac,...) Thanks a loooooooooooooooooot. | ||
| | #2 | |||
| Specialist Contributor Join Date: 04-12-2004 Location: Mariana Trench - Pacific Ocean
My System: Vista- DreamBox 7020Si Nabilo Darkstar II -7025+ Black Hole 0.11 - DM8000 BlackHole 0.11 |
Press Menu Press Installation Press Input Code With the up/down buttons choose the encryption system (S*ca,Via...) Press OK With the up/down buttons choose the newtwork (TPS, SRG....) Press OK With the up/down buttons choose the key index Press OK An input mask will appear to edit the keys Choose letter/numbers with up/down left/right buttons When done, press MENU If correct, the new key will now appear on the chosen index. Hope it helps. | |||
| | #3 | |||
| Member Join Date: 13-12-2004
| | #4 | |||
In my STB menu, there is : 1- Installation, Ok, and i go to input code, : 2- Input Code, Ok : Here, a box appear, with alphanumeric buttons whitch is the same used to rename a channel (0...9, A...Z, +,-,*,',Space, Delete, Enter, Caps). But nothing about encryption systems. Usely, i enter codes and press "Enter" button, in the same box. But nothing happens...I only get the previous sub-menu "Input code" in installation Menu. What do you think about ??? Learn you soon.... | |||
| | #5 | |||
My STB is a HOUSTON brand, model: RH-9000C. I don't know what is its original brand. I need to know on whats brand it is based in order to be able to upgrade it. I give you here an illustration of its loader as shown on the owner's manuel. Thank you very match...alex2005 | |||
| | #6 | |||
| | #7 | ||
| I had tryed all s/w versions that site countains, but no one has been uplowded bu my STB. There is no communication between Loders and my receiver. I don't know why. I finish to say that my STB isn't compa | ||
| | #8 | ||
| Recently, i have tryed to upgrade my STB from STWS site, but no more Loaders or Softwares were able to communicate with my STB. I finished to say that my STB isn't Starsat Based...What do you thik about this conclusion DeepDiver ? | ||
| | #9 | |||
..... should I find anything more on the web, I'll post back in this thread. | |||
| | #10 | |||
THERE IS NO LEDS ON FRONT PANAL. I's OUT now.... Thanks for helps. Now i have to do i right choice to buye a other STB. aNY SUGGESTION ??? | |||
| | #11 | |||
| | #12 | |||
| Member Join Date: 16-10-2004
i have a frend from algeria he said that houston rh-9000c is a condor dsr5000c or starsat 650 1M (an ather freind said 550d 1M but the test dame the reciever) if any one have information of houston rh-9000c email me to balamjed*chez.com with subject "ela lba houston rh-9000c" + .... if else the server delete it automaticly | |||
| | #13 | |||
Press Menu Press Installation Press Input Code An input mask will appear to edit the keys Choose letter/numbers with up/down left/right buttons then : put :code newtwork exemple absat :007000 then the key :0A 1....C finaly chose enter that's all | |||
| codes, control, input, remote |
Similar Threads | ||||
| The Ultimate Idiot Guide! For Idiots by Idiots!Answers,Questions,Tips + Tricks: RTFM! | T_G | Dreambox Guides, Stickies and FAQs | 51 | 11-07-2009 01:14 PM |
| Signals, noise, digital errors ... all that stuff. | spiney | Members' input on FAQ and How To's | 0 | 02-04-2006 04:41 PM |
| ZENEGA CD -1002S software needed for Dish TV India- Part II | Tom Robert | Indian Subcontinent General Section | 467 | 02-08-2005 12:55 PM |
| Input Codes By Remote Control | linax | Receiver software, international Section | 0 | 16-12-2004 10:56 PM |
| Echostar remote control protocol? | easysat | Digital systems | 0 | 10-10-2003 10:16 AM |
