Traxis DB2500
Information exchange on receiver software, including updates, problems and fine tuning.
Old 17-12-2004   #1
Traxis DB2500
I have a Traxis DB2500 reciever and would like to find out more about how to get software downloads for it???
kowa is offline   Reply With Quote
Old 14-06-2005   #2
gnomo1's Avatar
My System: traxis dvb 2500
u need look in a google , and only the software for traxis run,
gnomo1 is offline   Reply With Quote
Old 14-06-2005   #3
rockchang's Avatar
My System: hp7800---perfect arion-1700 clone receiver! + coolsat 4000pro + pansat 2500a + starsat sr-x200ci + infinity usb+cas interface 2+matrix reloaded
1. http://dvb.nease.net
2. there is an emu software for this receiver, but u must make sure there is SHARP0184 TUNER inside ur receiver.
good luck!
rockchang is offline   Reply With Quote
Old 02-11-2005   #4
My System: traxis 2500
error flash it
good luck!
I tried to flash my traxis dbs2500 with the file 6800emu.rar from your website dvd.nease.net. After I flashed, I can't see the menu and picture from the receiver, I guess I got it wrong.
I tried to flash it back with my original firmware bin from factory? But it verified failed. I try somemany way,but I still can't fix the receiver.
anybody gave me any comments?
thank you!!
feliza is offline   Reply With Quote
Old 02-11-2005   #5
rockchang's Avatar
Talking
thank you!!
dont worry about it ,buddy,
follow the following steps:
1.download Upgrade tools and install SC-16M(cpupgrade1.0)
2. use cpupgrade1.0 to upgrade loader file loader103.bin
3. use cpupgrade1.0 to upgrade Usa-traxis2500(27 Dec 04)
good luck!
Old 02-11-2005   #6
rockchang's Avatar
Talking
btw, i am developing new N1 EMU sw for traxis2500,
would u like to help me to test it in america?
Old 02-11-2005   #7
good luck!
Thanks, bro. I tried it. It says verified fails. when i try to flash the receiver with loader103.bin and the Usa-traxis2500(27 Dec 04) files.
I doesn't work either.PLz help me!!Thanks again.
I really appreciate your help!
Old 02-11-2005   #8
Wink
Sure, my pleasure!
But I have to fix my receiver first in order to do that man...
Ur help will be greatly appreciated!!
Old 02-11-2005   #9
rockchang's Avatar
Talking
1.did u use cpupgrader1.0 to upgrade loader1.03 ?
2.is ur receiver's loader 1.07 now???
Old 02-11-2005   #10
Wink
yes,I did, I use cpupgrader1.0 to upgrade loader1.03 it transfered the file, but when it get to the verfying process it failed.
yes my receiver's loader verison is 1.07 after use 6800emu.rar
which contains loader_1.0.7-64k.bin, SW3.2.79-KEY-UPGRADE.bin,Upgrade 1.0.7
Btw, how do i determine that if i got an sharp tuner I open the receiver.I found samsung 419 chip, OMEGA sti5578dvc, tnv0304 etc,
don't know where to look at it. I saw samsung chips on it.
Thanks again!!
Old 02-11-2005   #11
Wink
btw, I tested the file Sun-create(14 Sep 05) before i try to flash 6800emu file.
Sun-create(14 Sep 05) worked!!
Old 02-11-2005   #12
rockchang,are u there? what's ur qq?
Old 02-11-2005   #13
rockchang's Avatar
Talking
sorry man,
i am working now, so i dont have plenty of time to talk with you ...
btw , my qq is 17785481
let's talk through qq later...
Old 02-11-2005   #14
ok man, thanks
Old 02-11-2005   #15
the label on chips are sc04tns202b stv0299b sl1935c0352n
Old 06-11-2005   #16
Wink how to degrade a 550d loader_1.07 to 1.06 is it possible?
hi! bro,kindly rockchang.
Is it possible to degrade a 550d loader_1.07 to loader_1.06?
Since traxis only allow higher loader version file to be upgraded!
My question is that the case that the bios software check the file verison to verify the upgrade.If I use hexeditor to modify the header of 1.06 loader to the version that higher than the 1.07, will it work?
Or what specific model of arion remote i can use?? where to buy it?
Thank You!!
Old 24-11-2005   #17
My System: Traxis 2500 30" KU dish
I may be willing to try it. My receiver is a Traxis 2500 with Sharp F7VZ0184 tuner.
jtobin is offline   Reply With Quote
Old 25-11-2005   #18
rockchang's Avatar
thanx, then u can try Er6800/8800-EMU(09 Nov 05)
its safe to ur receiver ,i have tested it carefully.
Old 25-11-2005   #19
hi, rockchang did u receive my email?
Old 27-11-2005   #20
My System: Different FTA units
Had and still have same exact problem but fixed it once.
I had the same situation on my traxis. I loaded the 1.07 loader and couldnt get anything to work on it. I figured a way out to get other software to load back on the unit even the original software. But I was in a hurry to free up some space one day and deleted every file I had edited originally and my original read from the traxis. I think the way I fixed it half way revolved around the original software read I did useN the origianl loader software. The other half involved useN the 6800 emu software SW3.2.79-KEY-UPGRADE.bin
If someone could hook me up with a original first time read of a traxis 1500 or 2500 I could make the file again and post it. What sucks is sure the unit work just like it was factory but it still has loader 1.07 on it after the flash.
Error420 is offline   Reply With Quote
Old 27-11-2005   #21
about taxis 2500
Thanks,man That would be great if you can do it, here is the link to file. original factory file is _http://dvb.nease.net/file/UPgrade%20tools.rar here is the factory bin _http://dvb.nease.net/file/TRAXIS-20041228-app.rar the 6800 emu file again is here emu6800 _http://dvb.nease.net/file/6800emu.rar The new emu 6800 one is _http://dvb.nease.net/file/6800emu%20%2020051109.rar Please let me know, If you succeed!! Happy holiday.
Old 27-11-2005   #22
can you explain in detail how u did it? Thanks
Old 27-11-2005   #23
Old 24-01-2006   #24
My System: Traxis, WindowsXP
Do you have NTSc version of the file? I was able to upload emu file. But could not work as it is meant only for PAL. Thanks!
Edit:
I tried to revert the recvr to original bin.. It said transfer failed midway and the dispaly shows 0000 and nothing works now.. any solution?
Computer does not communicate with receiver anymore!
Zero7 is offline   Reply With Quote
db2500, traxis
[IMG] code is Off
Similar Threads
Traxis DBS 2500 nicolae16 Keys and Key editing 1 21-03-2006 09:59 PM
So You Want Receiver Software Patches? Analoguesat Receiver software, international Section 438 08-02-2006 05:50 PM
