After Uploading Firmware...?
Information exchange on receiver software, including updates, problems and fine tuning.
Old 21-12-2004   #1
Hi..
I M Confused Just A Little Help.
After Download Toh3* Do I Have To Upload The Keys???? If Yes Where And What Is File Name. This Is The Second Week I Have Not Get The Answer Yet Now Im Trying In Plz Can Someone Help.
I Have Humax 5400z With Cam +2.1
As I Said After Uploding The Firmware Do I Have To Upload The So Called Keys Or Bin Files?? If Yes Where And Is The File Names??
Im Eager Waiting For The Answer..plzzzz Guys
Foru
foru is offline   Reply With Quote
Old 21-12-2004   #2
Hi foru,
Personally I don't have a Humax receiver, but I did come across this site that might be of some use:
_http://www.sat-key.org/
Click on the Receivers files link in the left hand pane, and then on the Humax link, there you will find a lot of useful files including a how to file.
Hopefully this will open all the channels available.
Merry Christmas
Mickha
Mickha is online now   Reply With Quote
Old 22-12-2004   #3
Thanks Mikha But What I Want To Know If You Upload The Firmware Is It A Must You Upload The Key Binfiles?? And What Are These Key Binfiles?? Here Im Confuse I Read Alot But Still This Is Not Clear To Me.
Can You Elaborate In Detail ?
Foru
Old 22-12-2004   #4
Hi foru,
as I said I don't personally have a Humax receiver, but from what I've read you require some extra software to upload your keybin file, obtainable from:
_http://sat-key.org/forum/download.php?id=739
The rest of this is taken from the guide to how to load your keybin file, as Conax has gone off there should be a new updated file available soon.
Well, let’s start! There are HoT firmware updates (to install them, ToH 3.2 has to be already installed in your 5400-z) and ToH 3.2 firmware’s with HoT embedded ! You can download them into your receiver with the usual way (which I won't describe it here) using Hu15 or Wdn4oak+ (Can be found in our Humax section)!
So you managed so far to install HoT emu in your receiver and you are ready for the next step! After reboot is finished use your 'menu' remote button and follow ToH Config and change 'CAID Preselect ' option to 'EMU-c*rd' ! Now we are ready to send k*ys to Humax k*y buffer! We are going to need SammyHummyEdit (see file download above, as the k*y downloading software) and k*y.bin file (as the file to be downloaded)! Consider k*y.bin file as your funcard 6in1 file but with more features as you will find out later Updated k*y.bin file can be found in our files section! So open SammyHummyEdit and load your latest k*y.bin file! Press Write Data button and wait until the whole downloading procedure is finished! Wait a few seconds and reboot your humax! That’s it , your receiver is now ToH HoT patched and ready to rumble
Remember that a c*rd that returns Irdet ATR should always be placed into receiver’s smartcard slot which you don't have to update it every time k*ys change ! k*y.bin is the file that you have to update whenever is needed 6in1 funcards return irdet ATR in case you didn't know it! I used a Nova Hellas ird2 c*rd and Bulsat ird2 c*rd with absolutely no problems for ATR return! I was able to descramble ird2 from the c*rd and all the HoT supported encryptions, from the emu!!!
In case you decide to download channel settings after there above procedure, your CAID preselect option will return to c*rd ! You have to changed again to EMU-c*rd and probably load k*y.bin again
If I forgot something , feel free to add it in this topic with detailed description so all of our members , experienced or not , will be able to understand it
If you are still experiencing problems it might be best to ask the source of this document, XL at
If you register at this site, you can PM him and I'm sure he will be happy to help.
Hopefully it is just a case of doing it once and then it all becomes clear.
Best wishes
Mickha
Old 22-12-2004   #5
Thanks Alot Mickha What A Help.. I Realy Aprriciate Your Concern Im Going To Read It Carefuly.
Also Can Tell Me What Is Tps And Also I Heard Switch To One Of Fta? What Are These Terms Means?
Last If I Upload The Firmware And It Failed For Whatever The Reason What Will Happen To Humax5400z? The Old Firmwate Will Get Lost? Is It Going To Work With Out Re-upload The Firmware Again?
Thanks In Advance Mickha
Foru
Old 22-12-2004   #6
Hi foru,
FTA simply stands for Free to Air, meaning it's a channel that's not encrypted so any one can view it.
TPS is an encrypted satellite package that is quite often hacked, explanation taken from a web site:
VIACCESS - Used by TPS (Television Par Satellit), French Bouquet which can be found on Hotbird 2 (13 degrees east). Also AB-Sat on the same satellite. I believe rights are owned by France Telecomm as it was developed in their CCETT research centre.
Usually before uploading any new firmware to any equipment, you can make a back up to your computer, in case anything goes wrong, I've not read of anyone experiencing problems, but as I haven't got one of these receivers it might be wise to post a question about it on a Humax board.
There is a lot of support for these receivers from enthusiatic owners, who believe it to be on a par with the dreambox, I'm sure once you learn how to do it you'll enjoy what the Humax can do.
Try some of these sites:
_http://www.oslink.org/index.htm?humax_download.htm&2
_http://home.tiscali.nl/humaxdreamsettings/
_http://satellite.stophier.nl/index.php?
Hopefully you'll have it all working for Christmas.
Best wishes
Mickha
Just came across this thread that might be of help:
http://www.satellites.co.uk/php-bin/...ad.php?t=24891
Old 23-12-2004   #7
Yes Mickha Thanks Again I Under Statnd Many Small But Very Value Information Due To Your Help Now I Know What Is The Firmware And How To Upload Via Hu15 Also I Understand How To Configure After Upload.
Also I Came To Know What Is The Binfile And The Software To Upload It Using Samy_hamy Or Emu9**** You See These Thing Was Giving Me Headache.
I Have Not Try Them Yet But I Under Statnd Waht And How They Work.
Now My Next Taks Is.....very Important..
1) How To Take A Backup Of My Receiver And Which Programe To Use And How To Restore When Failed Or My Humax Stop Runing Again??
Yet I Know That You Dont Own Humax But You Gave Me A Big Push By Giving Me Very Useful Info Im Sure You Will Not Leave Me Alone On This Stage
Happy And Chrismass And And Prospourus New Year
Foru
firmware, uploading
[IMG] code is Off
Similar Threads
Humax BTCI-5900 firmware DaNileKnight Receiver software, international Section 6 02-02-2008 04:01 PM
How can i backup my receiver firmware or software to PC wongul Receiver software, international Section 6 11-02-2007 02:45 PM
Viaccess Red Cam V484 firmware. ANTMAL Viaccess 3 11-04-2004 12:56 PM
I need TF3000CIPPRO firmware October 2003 ikuwara2000 Receiver software, international Section 1 04-03-2004 09:03 AM
firmware for my elvis programmer tipsygent Cards & Programmers General 3 24-01-2004 08:23 PM
