S Model X/ XX/ X2Information exchange on receiver software, including updates, problems and fine tuning. | |
| | #28 | ||
| Member Join Date: 19-04-2005
My System: INTEL P4, SKY X5 |
| Last edited by Analoguesat; 05-06-2005 at 11:29 AM. Reason: disable live link | |||
| | #29 | ||
| Regular Member Join Date: 30-10-2004 Location: Earth......... I hope!
My System: Sky X2, Beausat 2004 FTA Plus, Echostar LT-730, twinhan Vision Plus DVB Card. 90cm Nokia Dish, 1.8m Also Manhattan 9650 Analogue | | ||
| | #31 | ||
| Member Join Date: 01-05-2005
My System: TV watching |
| | #32 | ||
Do you mean the keys have stopped working? If that is the case. Could be the delay in making a patch and they time the keys change. solution if you can enter the keys manually, could be a lot fast. You just need to get a site with updated keys. Or call Doc Mohamed from anzers. His number is on the website. He will give you the latest patch as soon as it is available. Hope thats of help Thanx | ||
| | #33 | ||
Has anyone been able to buy the Strong 4640? Looks like Sky X. I want to find out if you have seen any difference. I think they have taken the same receiver and given it a name. | ||
| | #34 | ||
| Member Join Date: 04-06-2005 Location: Central Africa
My System: Sky X2 Nagravision Irdeto Pentium Centrino 512Kb memory 60Gb disk 128Mb memory, plasma screen | Hey Boot and Blockead. There are a couple of things that I do not understand. First of all the cabling on the Null modem. It should be 2 to 3, 3 to 2, and 5 to 5, Therefore, the softCAM etc link given by blockhead goes to a file used in the DreamBox. Can we use it also in the Sky S X2? Today very cleverly, to update the keys I also tried to reset the database, clever eh?.... well my RCU is in "coma". It gives 0000. Now, if I reload etc etc the patch I guess the 175 is a bit old. Can I use the 185? And is the 185 going to update automatically my Nagravision user 2D01? Your comments will be highly appreciated, ( I will probably remember you in my prayers). Ah I forgot the Flash sftw for X XX etc, (*.rar file) reported in h**p://www.anzwers.org/free/skyx/patch1.html does not exists any longer. Be good and kindly give me some interesting hint. Thanks | ||
| | #35 | ||
My System: Sky X2, Beausat 2004 FTA Plus, Echostar LT-730, twinhan Vision Plus DVB Card. 90cm Nokia Dish, 1.8m Also Manhattan 9650 Analogue | Hi, Sorry for a long delay in response. The null modem is as you have put down. Theres patch version 1.89 I think that can work. As for auto update, U can use any version above 1.79 I think. They should work. Just go for the latest patch from: h**P://www.anzwers.org/free/skyx/patch1.html all update will work. I had only one problem with one of them can't remember which one. I use 1.89 so that is a good goal. Holla for any help. Thanx. Keep us in those prayers! | ||
| | #36 | ||
| Member Join Date: 05-04-2005 Location: Ankara
My System: Sky X | hello the best web site for sky receivers (skyx-skyx2-sky 1-sky 1a- sky 1b ....) is h**p://www.skypatch.net for download all software for sky receivers. thanks Edited to kill live link | ||
| | #37 | ||
| Member Join Date: 05-08-2005 Location: iran
My System: sky1a new code for viaccess,irdeto,.....and new softwares | Hi I have sky1a reciever and recently i upgrade for new software. After that i have some viaccess chanel and fullx1,2. I want to know how can i upgrade my reciever for all of chanels. I want to upgrade my reciever by myself, how can i found all software about the last software about sky1a ,.........in fact all programs and files about this subject. If possible please send me complete information . best regards | ||
| | #38 | ||
My System: Sky X2, Beausat 2004 FTA Plus, Echostar LT-730, twinhan Vision Plus DVB Card. 90cm Nokia Dish, 1.8m Also Manhattan 9650 Analogue | h**p://www.skypatch.net is a good site I agree. And worth looking @. Has alot of files too. | ||
| | #40 | |||
My System: Sky X |
polsat & tv cabo fixxxx http://www.skypatch.net/skyx/X_197p_20050906.zip | |||
| | #41 | ||
| Member Join Date: 19-09-2005 Location: Switzerland
My System: Digital satellite receiver S Model XX & Pentium 4 PC | I bought S model XX digital satellite receiver. Each time I get a scrambled channel I enter the code 6969 by the remote control twice but no box appears. Even the code 8280 doesn't work as shown here http://www.anzwers.org/free/skyx/skyxx2.html Could any one tell me what to do to get the scrambled channels clear? Thanks. System Information: ------------------- Model : XX S/W Version: 1.74 (Feb 02 2005) H/W Version: 1.00 CH Version: A008 ------------------- | ||
| | #42 | |||
My System: Sky X |
you should upgrade your receiver you should download loader version 3 : STB-SKYX download new patch for sky xx receiver: X_199p download new softcam 21.09.2005: Soft Cam 21-09-2005 ----------------------- after unzip files please connect your receiver and cable receiver is Stand by you open loader and select Patch SkyX & select browse and select X_1.99p & select connect & click start wait 2 minutes (2 times 100%) after open loader and select keys and select browse and select softcam 21.09.2005 and click conect and click start wait 30 seconds your receiver is now update by new firmware now turn on receiver and enter 69696969 code and for biss channels enter 8280 code and for manual code enter 8282 code now you can see polsat - tps-tv cabo ,srg swiss,...... scrambled channels Enjoy all software for your receiver in this site: www.skypatch.net | |||
| | #43 | |||
Million thanks for the clear information, it was very easy, it didn’t take more than 5 minutes and my receiver was flying. Thanks again. Now I can see all the Multivision, TPS, Discovery and some others. These channels came out clear just after I typed 6969 and 6969 for the pin. But I have some questions: 1st: Why and when do I have to use the 8282 mode to edit keys and from where can I get them? 2nd: What does BISS channels mean and what are those codes or keys I see in the window when I type 8280? 3rd: I bought this receiver because I’m interested in viewing the scrambled channels on Nilesat 7°W (Irdeto crypting), Kiosque and Taquilla bouquet on AstraSat, but I can’t get any of those!! DO YOU HAVE AN IDEA? Thank you for your help | |||
| | #44 | |||
My System: Sky X |
| | #45 | |||
- I asked about where I can find them or if they exist or not; for example: A web link can take me there. - I asked about the meaning of BISS channels. - I asked about how I use the 8282 and 8280 | |||
| | #46 | |||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue |
| | #47 | ||
My System: Sky X | Hi dear Analoguesat I know not this I am read rules and no posting of Keys but dear elaminea I no allow explain about codes and 8282 ans 8280 and softcam I said about 8282 and 8280 in previous post and this is minor rules this site Thanks | ||
| | #48 | |||
You're talking about keys in my last post of mine which you removed! Which keys? I went through the history of my posting which are not a lot (I posted 3 times only) and this is the fourth one, I didn't find any thing similar. I didn’t post keys directly, like hex keys or others. I did ask about explanations and some information. That’s all. Is that not allowed? By the way, is it allowed to post my personal e-mail? Or this will lead to a new argument!! Thanks | |||
| | #49 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | There were strings of alpha numeric codes in there which looked like keys so I removed them. We have an absolute no tolerance policy on keys - so anything that looks anything like keys is zapped by any mod which sees them. As for private email addresses we discourage them. The forum is for a free and frank discusion of ideas and information. We dont want folks taking information private via email when it could benefit all the members. So we remove any email addresses we see. | ||
| | #50 | ||
| Member Join Date: 02-06-2005
My System: wINDOWS xp 2 | Hai Friends, for the latest patches of Sky X .. Please feel free to E-Mail Me Email address removed. If you want to leave your Email address complete the appropriate section of your membership profile for the latest news in VIACCESS make a visit to http://groups.yahoo.com/group/viaccess_keys/ Regards SLBPillai. | ||
| Last edited by Topper; 30-09-2005 at 08:49 PM. Reason: satellites.co.uk do not wish to accept any responsibilty for your Email address being harvested by web/bot crawlers resulting in spam and therefore will actively remove any Email addresses posted | |||
| model, x or, xx or |
Similar Threads | ||||
| Which model of same hardware as Startrack 2100CE | starsatchina | Receiver software, international Section | 0 | 11-07-2006 10:19 AM |
| receiver with model no:sgm160000 | georgekamal | Receiver software, international Section | 1 | 29-10-2005 02:55 PM |
| S model XX software and manufacturer ? | kwaanwo | Receiver software, international Section | 6 | 05-05-2005 03:09 PM |
| is it possible to put firmware with different Model ID? | reza82 | Receiver software, international Section | 1 | 23-01-2005 01:44 PM |
| soft ware upgrade for model xx5 digital receiver | GMP | Receiver software, international Section | 0 | 22-12-2004 06:25 AM |
