S Model X/ XX/ X2
Information exchange on receiver software, including updates, problems and fine tuning.
Old 06-12-2005   #51
My System: skyx
skyx newpach want working polsat & multivsion
habeeb1815 is offline   Reply With Quote
Old 12-12-2005   #52
My System: HI, I have a sky-x (model s) digital satellite receiver. suddenly its software got cruppted. now i need help to update. is their any one who could help me out. Thanks Sherazi
hi,
could any one help me out.
i have a Sky-X STB, once i pulled out its power led and again connected then all the channles disappear. just only 8 channels shows in the list.
then after reset factory setting all the channels disappeared. i wrote E-mail to BOOT, and was suggested to upgrade its version. i did but couldnot fix the problem.
now could any one help me out
my E-mail Address: Email address removed Thanks
Sherazi
Sherazi is offline   Reply With Quote
Old 13-12-2005   #53
My System: 4.5 meters dish with motor 64 east to 43 west
Hi:
have you tried to make scan Auto
Ciao
sipione is offline   Reply With Quote
Old 13-12-2005   #54
boot_sectorz's Avatar
My System: Sky X2, Beausat 2004 FTA Plus, Echostar LT-730, twinhan Vision Plus DVB Card. 90cm Nokia Dish, 1.8m Also Manhattan 9650 Analogue
@ Sherazi,
Please reset your STB to factory settings. Upgrade to a stable version like I use 1.90. U can find this on h**p://www.skypatch.net or 1.92 (recommended) from h**p://www.anzwers.org/free/skyx/index.htm
After upgrade, switch it off (mains power-off). Is should now be in factory reset and then start channel search normally and see if that can help you.
boot_sectorz is offline   Reply With Quote
Old 31-12-2005   #55
Help me.
hi Mr. Shahin
with respect, i'm pakistani but working a living in Tehran.
if it is possible to help me out to over come the problem.
i have a sky-x stb with having the software. 1.76 patch.
when i do scanning on the hotbird, for the frequency starts 10*** there is no signal, but if you scann for the frequency 11*** it shows every thing. instead of many cannels like dubai pmc etc.
i also defined the specifications of lnb fequency ( 9.** to 12.**)
if it is possible for you to give me your telephone # so that i cold call you to help me. or you can call me 021-88708686
my complete name is " fazal hussain sherazi.
waiting for your prompt reply
thanks
Sherazi
Originally Posted by shahinsss
hello
the best web site for sky receivers (skyx-skyx2-sky 1-sky 1a- sky 1b ....) is
for download all software for sky receivers.
thanks
Edited to kill live link
Old 31-12-2005   #56
Sky-X (flash file)
Hi Mr. Shahin
with respect, could you please provide me the flash file for Sky-X Stb
Sherazi
hello dear elaminea
you should upgrade your receiver
you should download loader version 3 :
STB-SKYX
download new patch for sky xx receiver:
X_199p
download new softcam 21.09.2005:
Soft Cam 21-09-2005
after unzip files
please connect your receiver and cable
receiver is Stand by
you open loader and select Patch SkyX & select browse and select X_1.99p & select connect & click start
wait 2 minutes (2 times 100%)
after
open loader and select keys and select browse and select softcam 21.09.2005 and click conect and click start
wait 30 seconds
your receiver is now update by new firmware
now
turn on receiver and enter 69696969 code
and for biss channels enter 8280 code
and for manual code enter 8282 code
now you can see polsat - tps-tv cabo ,srg swiss,...... scrambled channels
Enjoy
all software for your receiver in this site:
www.skypatch.net
Old 02-01-2006   #57
For software please visit the sites given for downloads. We rarely have these files at hand to besending to you. Unless theres no site for you to download from will we be in a position to upload or send to you.
So get software from h**p://www.skypatch.net or h**p://www.anzwers.org/free/skyx/index.htm. They have plenty of patches for you and guides on how to do it. At the beginning of this thread are guides too. Please read and download from given sites.
Thanx
Old 04-03-2006   #58
My System: 200
Hello
How Do I Ask My Question In This Forum?
vahan is offline   Reply With Quote
Old 27-05-2006   #59
SkyX Receiver
Hello to all,
Please find updated who looking software and tool of skyx receiver.
www.skyx.mylivepage.com
anwarMEHDI is offline   Reply With Quote
Old 01-06-2006   #60
My System: AMT
Exclamation MaxPlus HTS 7300L
Hi everybody,
Can Anybody help explain the process by which one changes codes visa the receiver's RCU? But please only for the MaxPlus HTS 7300L model by Hub-Tech.
I have Looked at Hub-Tech's site http://www.hub-tech.com/ and found out that many of their activation buttons/links do not work!
Perhaps somebody has a tech manual for this particular model?
Thanks very much,
Verbis
Verbis is offline   Reply With Quote
Old 07-06-2006   #61
My System: Sky X2
Sky X2 Problem Encountered
Greetings to all!
I have encountered problem when updating the firmware of my X2 using ver. x_223, the power lost after it was updated 100%, i tried to power switch off and on again the receiver but it will display only the running green light for about 3 secs and power lost at all. I am regularly updating the firmware of X2 for more than a year and it was done succesfully, it was the first time i experienced the problem. Was it the problem of the firmware? or the reciever power circuit board? Kindly advise to solve the problem, or any idea/help is highly appreciated.
Thanks,
raucousv
raucousv is offline   Reply With Quote
Old 08-06-2006   #62
My System: SKY
Smile
Originally Posted by raucousv
Greetings to all!
Thanks,
raucousv
dear
you should use New loader v1.8.4 & BOOT file . then upgrade your receivers by Boot.stb & X_224 . when saw 4 green line on your receiver then press connect (IMMEDIATELY) . all files (new loader - patch - boot ) availaible in w*w.skypatch.net
skypatch is offline   Reply With Quote
Old 08-06-2006   #63
My System: Sky X2
Originally Posted by skypatch
dear
Thank you very much for the quick response, i'll try this when i reach home.
Old 11-06-2006   #64
My System: Sky X2
It works! Thanks again skypatch.
Old 11-06-2006   #65
slugworth's Avatar
My System: stm5105 based receivers
Question questions
Is there a newer boot file than 140 on that site?
How do they convert the boot.bin to boot.stb format?
slugworth is offline   Reply With Quote
Old 12-06-2006   #66
My System: Skyx (the best) Mediacom 930 i
Help on Skyx
Hello,
I've been using 224 Firm*ware in my receiv*er Skyx but it worked 1 day only. When I read message of our friend it looks working longer??
Should I follow the same prodcedure than for X2, enter a sky boot?
I've never did it.
Thanks for your usual help
alkiki is offline   Reply With Quote
Old 13-06-2006   #67
Infos needed
How to helped?
What procedure should we follow?
Old 17-10-2006   #68
SkyX new patch file 235p 08-10-2006
Please find new patch file of SkyX receiver and updated softcam
Old 17-10-2006   #69
All information and patch for SkyX Receiver
SkyX new patch and softcam and other information available on www.skyx.mylivepage.com
Regards
Anwar
Old 24-11-2006   #70
I find this site but I don't know from where is the original site.
http://npulc.com/ulc/ that have files for SkyX receiver
Home / Receiver / Sky&PHPSESSID=85f2ed40b082a853b9ec92c9e93f290a&PHPSESSID=85f2ed40b082a853b9ec92c9e93f290a" target="_blank">Sky
The last update is on Sky&PHPSESSID=85f2ed40b082a853b9ec92c9e93f290a" target="_blank">this page
The softcam work from 17 to 24 Nov 06
I wait for new update
Good Luck
israna18 is offline   Reply With Quote
Old 06-12-2006   #71
h**p://www.crosat.org/aploud/index.php?&direction=0&order=mod&directory=STRONG RECEIVERS has updates for Most Strong receivers and Sky X. You will find all you need here.
But I think free membership is a must for most downloads, unless those on the front page.
Old 12-12-2006   #72
My System: computer
hi i need patch for skyx 2 with cam please to open tps and other
flex is offline   Reply With Quote
Old 13-12-2006   #73
urmans's Avatar
Sky X
No new patch at the moment...
new link for sky x patch here: h**p://www.funfiles.ws/forumdisplay.php?f=895
need register to download files.
urmans is offline   Reply With Quote
Old 14-12-2006   #74
slugworth's Avatar
Exclamation x240p
X240p is the last version I know of,but 1 person claimed he couldn't load it to his receiver.
Old 15-03-2007   #75
thnx
this is very nice and very usefull links
thanks
sad85man is offline   Reply With Quote
model, x or, xx or
[IMG] code is Off
Similar Threads
Which model of same hardware as Startrack 2100CE starsatchina Receiver software, international Section 0 11-07-2006 10:19 AM
receiver with model no:sgm160000 georgekamal Receiver software, international Section 1 29-10-2005 02:55 PM
S model XX software and manufacturer ? kwaanwo Receiver software, international Section 6 05-05-2005 03:09 PM
is it possible to put firmware with different Model ID? reza82 Receiver software, international Section 1 23-01-2005 01:44 PM
soft ware upgrade for model xx5 digital receiver GMP Receiver software, international Section 0 22-12-2004 06:25 AM
