S Model X/ XX/ X2
Information exchange on receiver software, including updates, problems and fine tuning.
Old 24-12-2004   #1
boot_sectorz's Avatar
My System: Sky X2, Beausat 2004 FTA Plus, Echostar LT-730, twinhan Vision Plus DVB Card. 90cm Nokia Dish, 1.8m Also Manhattan 9650 Analogue
Smile S Model X/ XX/ X2
Please post all your links and software links related to "S" Model X and XX. I know there are some of us here who have been looking for that for sometime. So take time out to help us.
Thanx
Boot
boot_sectorz is offline   Reply With Quote
Old 28-12-2004   #2
S Model X
Special thanx to Sani for this. Hope someone finds it useful.
Visit this cool like for goodies: http://groups.yahoo.com/group/all-digisoft
Bootly yours
The Following User Says Thank You to boot_sectorz For This Useful Post:
peter111 (24-11-2007)
Old 03-01-2005   #3
Channel Editor
I have the channel editor. Email me if you want it. I couldn't upload it at this time.
Boot
Old 07-01-2005   #4
I think S model X is Actaully Technomate TM1500 CI
Full name is Sky model X, was made by technomate I have no doubt. link for all you need is on http://www.anzwers.org/free/skyx/index.htm. U will see that all software used have the technomate on them. Maybe it is a clone.
Have fun but be careful
Old 08-01-2005   #5
Been trying to update this receiver but fun enough the software I have seem not to work. Maybe I have a wrong cable/ software/ operating system (Win XP - I trust Win98 for serial connections but had no PC with it at the time) or somehting.
Confirmed as Sky model X and uses mostly software from technomate. I assumme the upgrades from there should work too. So I try to connect to the receiver to backup the info I have and see if I can upgrade it. I get nowhere.
Now questions pop in my mind: Has anyone actually upgraded this receiver? If so, what was the environment? The OS, software, cable, etc. It could do good to me I thought I had a way out.
Later
Old 12-01-2005   #6
I think this site should be added for people interested in finding out about Sky model X/XX. _http://www.parstech.org/skyX.htm
Old 14-01-2005   #7
Confusing Digital Receiver SkyX /S /Hubtech /Maxplus
Been reseraching of this tool and believe me it is confusing. Anyway, here are the other links to the software on these models:- They include all these,
Hub Tech or hubtech Digital receiver
S model X/XX/X2 Digital receiver
Sky System X/XX/X2 Digital receiver
Sky model X/XX/X2 or SkyX Digital receiver
MaxPlus or Max+ 9300 (I think) Digital receiver anyway somewhre there.
These would help you:
_http://www.hub-tech.com/
_http://www.hub-tech.com/eng/product/product-sat.htm
_http://www.sandroses.com/abbs/showt...64&page=5&pp=15
_http://www.mavitunasat.com/index.ph...ILIMLARI/TERMAL
_http://www.anzwers.org/free/skyx/
_http://www.maimouni.net/modules.php...download&cid=17
_http://www.satellite-heaven.de/inde...ver/hubtech.htm
_http://www.maxplus.8k.com/download.htm
_http://www.satthai.net/download.htm
Please let me know if it helps you
Old 17-01-2005   #8
SKY X, S MODEL X/XX/X2, MAX PLUS and HUB TECH HTS 9300+ UPDATING GUIDE
SKY X, S MODEL X/XX/X2, MAX PLUS and HUB TECH HTS 9300+, GUIDE ON UPDATING SOFTWARE
I finally found out the problem I was facing with updating the Sky X (S model X) digital receiver. So I have made this little guide to help those you face a similar problem.
To begin working with this, you will need the following (For software I have included the sites you can find them from. But if you still wont find them there, email me and I will send the files to you. boot_sectorz*yahoo.com):
1. The downloader (I suggest you use one form: http://www.anzwers.org/free/skyx/index.htm. Or from http://groups.yahoo.com/group/all-digisoft STB-SKYXLoader ver 2.0 is fine)
2. Rs232 cable ( I got one with straight connection, that was my problem. So make sure it is wired in this way: 2=3, 2=3 and 5=5. The wire form pin 2 should connect to pin 3. Null modem cable.)
3. Patches, files, keys, firmware, channels data you want to update with. (You get these from the two sites above also.)
And this is how you do it:
1. Connect RS 232C cable between PC and STB
2. Run STB Loader.exe
3. Browse the new software in your file directory
4. Check COM port
5. Power on your Satellite receiver
6. Click on Connect, and it begins downloading. (It shows downloading status on STB Loader and front panel display of the receiver)
7. After downloading is completed, STB will reset automatically
8. Go to System Information, check the version of your software or channel data. Make sure you power off the receiver.
9. Thank the people you spend time working on these things and email them to make them know it worked for you so they can do better things, and you are done.
If you need to download software on more units, you just leave STB Loader on and turn on the power of the next STB that you wish to download, it will begin downloading automatically.
Warning : Downloading inappropriate software does not accord with model no. of STB may create problem. Make sure correct software name and STB model no. and proceed downloading.
P.S. You can download the file attached (on top of this page). It should have all you need to update.
Old 05-02-2005   #9
abbatimyaro's Avatar
Which one ?
HEY boot,
Looks like you're confuse and also want compuse other people about
the skyx. Try to understand hardware compatibility/fixing software to match another hardw' then you can start talking yourself out.
You gonna make newbies kill their rcxs, if you really researched as you said then come out with something genuine not thinkin'-thinking as you think.
blockhead
abbatimyaro is offline   Reply With Quote
Old 05-02-2005   #10
Site administrator
Analoguesat's Avatar
To be honest, any newby who doesnt really know what hes doing should not be trying to flash their receiver in the first place
Analoguesat is online now   Reply With Quote
Old 16-02-2005   #11
Well I help out those who need help. Frankly speaking, I don't do Dad Day Care arrangements, I'm not a kids teacher.
So the infor is for those who asked me a few questions. And most of them are happy. It is always a problem to find software for a Receiver that is mostly unknown.
Old 16-02-2005   #12
X5 Reciever
Yes we are very thankful toSani A. Sani for the Help. PLease did you know anything about a reciever named X5 Model it looks like S X but they are not thesame model please assist.
ibrahim alkali is offline   Reply With Quote
Old 16-02-2005   #13
Thumbs up Here patch for x5
To alkali + others even boot, here is the latest for skyx5, and skyx stbs are not mde by tm, cs or mp.
Alkali, does the patch for beausat works ok?
Originally Posted by ibrahim alkali
Receiver software removed please put such things on a web site, and provide a link to it instead. Analoguesat
Old 16-02-2005   #14
Thumbs up Skyx new ver:175
Too busy, I can't get all channels tested but shall work taquallas+others, try it yourself but the soft is tested ok works 100% Skyx (S Model X)
How to - MODEL X
- The main software is "SkyX_175p.Zip". Use the program
"STBTool.Zip" to download main software or channel data "SoftCAMKey"
file to the receiver.
*The code to open a scrambled channel on model X is 6969 two times.
Please enter this code two times each time your receiver comes from
main power OFF.
*To edit the key code via RCU please enter the number 8282 once.
Edit the key always on the right bouquet name and don't misplace the
code. Or you can updated key code the receiver by using PC.
select "keys" and open the file name "softCAMkey" and download it to
the receiver.
The file "softCAMkey" is available under hackers site
(FUN card files)Just click below link to download this file..
h**p://www.rdi-sat.com/uploadshow.php?id=6
This software version has Auto Update key code for Nagra-Vision &
Viaccess channels.It Can open S*ca 2 channels
(Sky Italia & Taquila channels).
Regards
blockhead.
Old 17-02-2005   #15
Thanx alot for that! Been busy too. Tested software and works well.
I use this STB tool (Ver. 2) and works well too. Download it here h**p://www.bishahealth.com/STB-SKYX.zip
As for Sky X5, you can download the latest patch from here: h**p://www.satcentrum.com/upload/?action=dl&code=88abbd1f9f8df77a67c9 I don't have the X5 so did not test it. Can someone please test these and confirm if it is working?
Old 28-02-2005   #16
My System: the recever
Cool
176 sky x 26/2/2005
huma is offline   Reply With Quote
Old 28-02-2005   #17
skyx 176-x-26/02/2005
h**p://www.bishahealth.com/X_176_20050225.zip
Old 18-03-2005   #18
urmans's Avatar
Smile Sky X Firmware
any new keys or firmware please for Sky X receiver
please...please
thanks.
urmans is offline   Reply With Quote
Old 18-03-2005   #19
Urmans,
Go to this site: h**p://www.anzwers.org/free/skyx/index.htm,
You will find the latest firmware, keys and all that you need for the Sky X and even sky X5. Even the software to help you update it.
Thanx
Old 18-03-2005   #20
Sky X 1.77 Patch
New Patch for Sky X available on: _http://www.anzwers.org/free/skyx/patch1.html. Download software and loader from the same site too.
Thanx
Boot
Old 25-03-2005   #21
urmans's Avatar
Talking Thanks
Thanks a million Boot now I know where i can get sky x firmware
thanks,
urmans
Old 28-03-2005   #22
You welcome Urmans
Old 20-04-2005   #23
Patch 1.81 Available
The new Patch for Sky Model X is available. Get it from: h**p://www.anzwers.org/free/skyx/patch1.html
Old 20-04-2005   #24
My System: i dunno
evry time my skyx goes on standby and get on its get formated
maximusevc is offline   Reply With Quote
Old 20-04-2005   #25
Lightbulb Try this
Reinstall the software or upgrade the soft to last version 1.81. You can get it in my site at g*ocities.c*m/starcomft. If you can't get it fix to namal mode then your flash RAM is corrupted it need to be replace.
Goodluck and regards,
blockhead.
model, x or, xx or
[IMG] code is Off
Similar Threads
Which model of same hardware as Startrack 2100CE starsatchina Receiver software, international Section 0 11-07-2006 10:19 AM
receiver with model no:sgm160000 georgekamal Receiver software, international Section 1 29-10-2005 02:55 PM
S model XX software and manufacturer ? kwaanwo Receiver software, international Section 6 05-05-2005 03:09 PM
is it possible to put firmware with different Model ID? reza82 Receiver software, international Section 1 23-01-2005 01:44 PM
soft ware upgrade for model xx5 digital receiver GMP Receiver software, international Section 0 22-12-2004 06:25 AM
