ne patchInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Member Join Date: 27-11-2004
| <A target=_newDDRESS> ToH Humax5400 Firmwares 27/07/2003[img]icon.aspx?m=blank[/img] Description Status Secure ToH Links: +CAM ToH31 +CAM ToH31 +CAM ToH31 +CAM ToH31 +CAM ToH31 +CAM ToH31 +CAM ToH31 +CAM ToH31 +CAM ToH31 +CAM ToH31 +CAM ToH31 +CAM ToH31 +CAM ToH31 +CAM ToH31 +CAM ToH31 +CAM ToH31 +CAM ToH31 New release +CAM ToH 3.1 Look at readme ============= Have Fun With Our Stuff Planet_Hemp/us/Padawan/HUMI_USER/Undici77 Your TuningsOnHumax Team ========= Tested Humax Uploader 16/09/2002 Description Status Humax Uploader 1.5 Use this tool for flashing any ToH firmware. It will do a check for all +CAM ToH versions. ALL FIRMWARE VERSIONS Big thanx to QME5400 Tested Humax Macro Editor 16/09/2002 Description Status Humax Macro Editor 1.5 With this tool you make you can test and make durable macros for the +CAM ToH2.0 . Only for +CAM ToH2.0 Big thanx to QME5400 Tested Humax Remote Control 16/09/2002 Description Status Humax Remote Control 2.5 With this tool you can send IR commands thru a null-modem cable. TuxOnHumax Patch must be installed into your decoder. ALL FIRMWARE VERSIONS Version 2.5 is necessary for +CAM ToH2.0- Added Macros Definition and Macros Editor (F12).- Added GUI ShortCuts (F1,F10,F11,F12).- Added External Window control feature.- Added Half/Full/Macros buttons.- Added DD Sync button.- Added Run-Once feature.- Added PopUp Menu standard Windows activation key.- Improved HotKey minimize/restore/activate feature.- Enlarged HotKeyForm to show selected HotKey properly.- Restyled Help file.Big thanx to QME5400 Tested TuxOnHumax ITV Firmwares 15/11/2002 Description Status 5100_HCI10502+ToH12 Firmware with TuxOnHumax patch for 5100 + SettingsJEDI.zip for italian users only. Tested 5300_HVC10502+ToH12 Firmware with TuxOnHumax patch for 5300 + SettingsJEDI.zip for italian users only. Tested TuxOnHumax Firmwares 23/04/2002 Description Status 5100C_HQCI10303+ToH11 Firmware with TuxOnHumax patch for 5100C. Untested 5100_HCI10502+ToH11 Firmware with TuxOnHumax patch for 5100. Tested 5200_HVA10101+ToH11 Firmware with TuxOnHumax patch for 5200. Tested 5300_HVC10502+ToH11 Firmware with TuxOnHumax patch for 5300. Tested 5350_HOVC10007NP+ToH11 Firmware with TuxOnHumax patch for 5350 (without OpenTV). Tested 5500_HCC10500+ToH11 Firmware with TuxOnHumax patch for 5500. Tested 5600_FTV10502+ToH11 Firmware with TuxOnHumax patch for 5600 (without OpenTV). Tested 5700_HNC10300+ToH11 Firmware with TuxOnHumax patch for 5700. Untested VAFOX_QVA10104+ToH11 Firmware with TuxOnHumax patch for VA-FOX. Untested F1FOX_QFE10302+ToH11 Firmware with TuxOnHumax patch for F1-FOX. Untested Humax Settings Viewer 16/09/2002 Description Status Humax Settings Viewer 2.0 With this tool you can control your Humax and can change Settings online. TuxOnHumax Patch must be installed into your decoder.
Version 2.0 is necessary for +CAM ToH2.0 ALL FIRMWARE VERSIONS Big thanx to Padawan Tested Humax Icon Patcher 19/04/2002 Description Status Humax Icon Patcher 1.3 With this tool you can patch all icons stored into your firmware. ALL FIRMWARE VERSIONS Big thanx to QME5400 Tested Firmware Exploring 17/04/2002 Description Status HELP.zip Hi all, We need help to unpack/repack these packed helps! Big thanx to QME5400 Help Firmware Understanding 01/04/2002 Description Status source_boot_IDA1.1.asm Sourcecode from Loader H2.08 with comments. You can look inside and help to analyse. Big thanx to Phil242 Help Firmware Exploring 01/04/2002 Description Status HFE_ascii.zip All ascii found into binary raw files. Help HFE_icons.zip All icons found into binary raw files. Help HFE_anim.zip All animated icons found into binary raw files. Help Documentation 01/04/2002 Description Status IR_Remote_info.zip Discription of the Remote Controll Unit (German / English) Help Irremote_docu_ita.zip Description of Remote Control (Italia) Help OAKSERV.PDF Service Manual Humax 5.xxxx Help opr004P7.pdf Datasheet Set-top-box stb5680 (Referenzmodel for the Humax from Philips) Help IRDETOCAM.ZIP Schaltplan vom IRDETOCAM Help نواااF http://www.startimes2.com/icon.aspx?m=posticon 14:31 - 2003/11/29 http://www.startimes2.com/icon.aspx?m=profilehttp://www.startimes2.com/icon.aspx?m=reply_topic Echostar TPS Patches Firm TpsCrypt For Echostar - DSB1100_VIACCESS_V700_020424_W- DSB1200_TPS- DSB2110_2CI_Viaccess_Tpscrypt- DSB2200_2ci_via_V801_20020801w- DSB2200_2ci_via_V801_Bis- Flach Rom DSB 2200 V900 Canal+.zip <Non Testé>- AD3000IP_Viaccess_V804_040903_wtp- ad3000ip_viaccess_v800_020424_w- D2600IP_2ci_via_V501_20020814w- echo_ad-2000ip- echo_dsb-1000-2ci TPS Files Echostar - Pic2_Tikon echostar 2110-3000 tpscrypt- threemp_tps_echostar 2200 sauf tps- Pic2_Tikon_new_MàJ_Cle_09- Pic2-echostar2200_V900 Starcom http://de.geocities.com/abosara07/spacer.gifhttp://de.geocities.com/abosara07/spacer.gifSTARCOM PVRCI SEP. 16,2003http://de.geocities.com/abosara07/zip2.gif STARCOM FTA SEP. 16,2003http://de.geocities.com/abosara07/zip2.gif STARCOM CIP SEP. 16,2003http://de.geocities.com/abosara07/zip2.gif STARCOM CI SEP. 16,2003http://de.geocities.com/abosara07/zip2.gif OMAX FTA SEP. 16,2003http://de.geocities.com/abosara07/zip2.gif OMAX CI SEP 16, 2003.ziphttp://de.geocities.com/abosara07/zip2.gif نواااF http://www.startimes2.com/icon.aspx?m=posticon 14:35 - 2003/11/29 http://www.startimes2.com/icon.aspx?m=profilehttp://www.startimes2.com/icon.aspx?m=reply_topic Starsat Loader for: SR-X120D, SR-X150D PLUS, SR-X200CI PLUS[img]icon.aspx?m=blank[/img]SR-X1500 Super, SR-X1600Dhttp://de.geocities.com/abosara07/zip2.gifSR-X120D, SR-X150Dhttp://de.geocities.com/abosara07/zip2.gifSR-X550D PLUShttp://de.geocities.com/abosara07/zip2.gifSR-X200CI PLUShttp://de.geocities.com/abosara07/zip2.gifStar_sat-_com_Silver_550D_20031024http://de.geocities.com/abosara07/zip.gifStar_sat_com_Silver_650CI_20031024http://de.geocities.com/abosara07/zip.gifStar_sat_com_Silver_3500CUCI_20031024http://de.geocities.com/abosara07/zip.gifStar_sat_com_Silver_3200CU_20031024http://de.geocities.com/abosara07/zip.gifStar_sat_com_Silver_3100CU_20031024http://de.geocities.com/abosara07/zip.gifSOFTWARE_SR-X120D,_SR-X150D+http://de.geocities.com/abosara07/zip.gifSR-X200CI_Nov_5,2003http://de.geocities.com/abosara07/zip.gifSR-X1500D_SUPER_MK_II_SEP_12,2003http://de.geocities.com/abosara07/zip.gif Deltasat ver1.21.zipAllpatch for 1104 IRCI ver.121 EPG fixver1.14.zip Allpatch for 1104 IRCI ver.114ver1.18.zip Allpatch for 1104 IRCI ver.118 ver3.33.zipOriginal firm for 1104 IRCI ver. 3.33http://www.geocities.com/irpatch/download/Patches : DS 1106,1105,1105UCAS,1104 Tools for DeltaSat Chedit102.zipSettings editor SeteditDeltalinkexe.zipTool to upload firmware patch to your DeltaSatEurostar Model NameRemarkVersionFor HelpDownload InstructionsFile Name8110A+D-V4.29Click HereClick here8110ad.exe9700FTAOld RCUV2.92Click HereClick here9700fta_old.exe9700FTANew RCUV2.93Click HereClick here9700fta_new.exe9000 CIOld RCUV3.74Click HereClick here9000ci_old.exe9000 CINew RCUV3.75Click HereClick here9000ci_new.exe9900 V+CI-V1.30Click HereClick here9900v+ci.exe9900V+2CI38CC TunerV1.25Click HereClick here9900v+2ci_38cc.exe9000 2CI38CC TunerV1.33Click HereClick here9000_2ci_38cc.exe 9700FTA NoScart Without ScartV2.14Click HereClick here9700fta_noscart.exe9700FTA WithScartWith ScartV2.14Click HereClick here9700fta_scart.exe8800ADP+CI-V 3.03Click HereClick here8800adp+2ci.exe9000 2CISilicon TunerV 1.33Click HereClick here9000_2ci_Silicon.exe9000 2CINIM TunerV 1.33Click HereClick here9000_2ci_NIM.exe9000 2CI PlusSmall SizeV 1.32Click HereClick here90002ciPlus_ver132.exe9700 FTA PlusSmall SizeV 1.33Click HereClick here9700FTAPlus_ver139.exe9900V+2CINIM TunerV 1.25Click HereClick here9900v+2ci_NIM.exe9950HDD-V 1.38Click HereClick here9950hdd_ver146.exe | ||
| patch |
Similar Threads | ||||
| patch starsat | NBK64 | Receiver software, international Section | 25 | 13-06-2008 02:48 PM |
| Softwar patch problem | francesco24875 | Receiver software, international Section | 2 | 21-06-2005 01:27 PM |
| Can i patch my sammy with version 118? | giorgik | Receiver software, international Section | 2 | 11-01-2005 09:07 AM |
| Humax 5400 AllCAM patch | 2old4this | Receiver software, international Section | 4 | 04-05-2004 10:41 PM |
| need patch for Starsat SR-X650CI | tweek4444 | Receiver software, international Section | 4 | 30-03-2004 10:52 PM |
