Any solution for MODEL ID IS NOT MATCHEDInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Regular Member Join Date: 06-01-2005
| Hi there, I am trying to update my receiver STARCOM SR-X120 D Plus almost for a month but without success. Before cleaning the old software it was version 7.00. Now when I plug it in the mains I can only read on receivers' display Er07. I cannot turn it ON/OFF on the boton, see anything on TV......... etc. Again, I cleaned it last night using EMUpgrade programme V 2.11 after which I could read on the computer UPGRADE COMPLETE but then when I try to download the software into the receiver through the cable RS 232 using the same program when I turn it OFF and then ON the message on the computer reads MODEL ID IS NOT MATCHED. I tried the same with softwere version V7, M2, M1 from website www.satsw.com but the result/message is always the same. Any suggestion why this is hapenning and advise if I can or how to solve this problem. Many thanks & best regards, | ||
| Problem solved with the new software: Jan_10_Starcom_FTA_V7 downloaded yesterday from the website www.satsw.com . Now everything is working MULTIVISION, TPS, POLSAT, ............. | ||
| | #3 | |||
| Member Join Date: 12-01-2005
and you r the greatest | |||
| Specialist Contributor Join Date: 01-01-2004 Location: Lebanon
My System: Starsat,Strong, Onyx, Omax, Astrasat, Condor, Starcom, Astrovox, JTAG. Laptop,Desktop. | Dear Bogbog2,this file is only used for the version 7.If your receiver's hardware version is 7 you can use it. | ||
| matched, model, solution |
Similar Threads | ||||
| Single Solution LNBF vs Dual Polarity LNBF | al_madhi | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 0 | 23-01-2006 12:30 AM |
| Find Solution for puppetmaster | el7 | Mobile phone/GSM chat | 43 | 06-08-2005 08:07 PM |
| Software solution for STARCOM SR X-120D Plus | Neki | Receiver software, international Section | 0 | 13-01-2005 04:52 PM |
| Cheap Solution Required | excellent | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 1 | 14-08-2004 11:48 PM |
| Closer a solution, but still problems! | pas | Viaccess | 1 | 02-01-2002 10:54 PM |
