Help ! Supermax Super 6000 Ci Plus problem !Information exchange on receiver software, including updates, problems and fine tuning. | |
| Member Join Date: 22-12-2004
Hi ! I have big problem with my receiver Supermax Super 6000 Ci Plus ! I tried to made software update with (5512)_SSM3_BootMake_0029 . I received " upgrate successfuly " and after that I restored manually the receiver from power supply On / Off. On front panel on my STB, I have "Eend". After that the STB is block. I can't reboot the receiver. Please , help me ! I will appreciate all your sugestions ! Thank you very much ! | ||
| | #2 | |||
| Member Join Date: 07-02-2005
Turn receiver off and then on whilst holding the "Channel Up" button. (display should show "029") The loader will display the connection as "Disconnected", and will fail to connect if you try. This is OK. All instructions I have had state that you have to connect with loader at this point. When I got to this stage I thought that my receiver had got stuck and I started to panic. Just click the "lightbulb" icon on the Loader(still says disconnected) and load the file (5512_VEx_Boot_SSM3_SUPER-CI 6000 PLUS_FMB615c091804 MO00.25.hex). (It can take a short while for it to update) When complete receiver will display "Eend" Turn receiver off and back on with the power switch on receiver. Load in new CAS files as normal. Receiver should now be OK Hope this helps | |||
| 6000, problem, super, supermax |
Similar Threads | ||||
| NOW you can turn your receive super to ultra enter here | jack0 | Receiver software, international Section | 364 | 17-11-2008 12:26 PM |
| Have a problem MPEG2 DVD conversion | mgharbawy | Computer Discussion | 4 | 21-06-2004 10:02 PM |
| Have a problem with Vision Plus | mgharbawy | Satellite PC Card Receivers & Internet by Satellite | 1 | 15-02-2004 10:47 PM |
| is this a diseqc problem | doggy | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 14 | 05-09-2003 02:44 AM |
| Aston to Diseq poitioner problem | BazelAd | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 4 | 20-08-2003 07:21 PM |
