Help...Humax patch problems
Information exchange on receiver software, including updates, problems and fine tuning.
Old 19-02-2003   #1
I have just updated the patch on my Humax 5400, Now it is reading invalid card on all encrypted channels (I am using a silver card with ds9 files),
I have upgraded to TOH23, The reason i did this in the first place was because my diseq motor stopped responding when i changed service (satellite) I would have to swich channel and then turn off/on the machine, However if i used the menu to change position the motor would respond without any problem.
Has anyone else heard of this? Thanks all.
pc::
ez_livin is offline   Reply With Quote
Old 20-02-2003   #2
something else
The machine says "smart card extracted" when i turn it on. when i change to some channels,l when i extract the card and also when i insert the card????????????
pc::
Old 20-02-2003   #3
rolfw's Avatar
Real name: Rolf
Don't know too much about this ez-livin, but try This Thread it may shed some light on your problems.
Rolf
Old 20-02-2003   #4
"Satellite Expert"
wolsty's Avatar
My System: Humax IRCI5400z, Sony Digibox, Digilogic Freeview box, 1.1m Triax, Manhattan DiSEqC mount, various cards, Season Interface
I patched my Hummie to ToH2.3 some days ago. It worked well for a time, but then the motor stopped responding. I jumped to the conclusion that the problem is in the motor (I've had problems with poor connections, dry joints and broken leads before), but I haven't been up on the roof to look because it's been too cold and windy over the past week. Your posting has prompted me to look at the software before exposing myself to the elements. Some time ago, if I remeber correctly, Planet Hemp deliberately bugged his patch to ensure that his work wasn't taken for granted. A new release solved the problem. If I find a non-mechanical solution, I'll post again.
wolsty
wolsty is offline   Reply With Quote
Old 20-02-2003   #5
"Satellite Expert"
wolsty's Avatar
I've just re-patched the Hummie with ToH2.3, updated the PMC table and put in the latest motor settings, but to no avail. My problem must be in the motor, so a trip to the garage roof is inescapable. Not this afternoon, though; it's still too cold and windy for my ageing frame.
wolsty
Old 20-02-2003   #6
psats's Avatar
Lightbulb humax motor
just a thought have you re enabled the motor in menu ??
psats is offline   Reply With Quote
Old 21-02-2003   #7
"Satellite Expert"
wolsty's Avatar
Yes, I checked the installation menu and all settings are correct. I think I'm clutching at straws by looking for a software solution. It's very significant that the system went down whilst I was channel hopping. I moved from 1 deg W to 28 deg E and the system stuck at that point. I'd put money on the fault being a bad connection between the DiSeqC controller and the motor. The weather's better now, so I'll jump up on the roof this weekend.
Thanks for the suggestion; it's just the sort of silly mistake I'd make.
wolsty
Old 27-02-2003   #8
"Satellite Expert"
wolsty's Avatar
System now up and running again. The fault was, as I suspected, a broken connection. There's no problem at all with the Hummie patch.
wolsty
Old 28-02-2003   #9
psats's Avatar
wolsty
glad to here you got it sorted
helphumax, patch, problems
[IMG] code is Off
Similar Threads
ne patch megabit800 Receiver software, international Section 2 13-12-2006 08:54 PM
Lists of Software upgrade sites jo_lb2002 Receiver software, international Section 17 23-11-2004 08:05 PM
Humax 5100 or Humax 5400z internetbasic2000 Digital systems 9 28-05-2004 03:04 PM
Humax targets UK DTT market net1 Terrestrial Television, Digital and Analogue 0 26-09-2003 07:19 PM
Few people seek help for sex problems net1 The Meeting Place 0 22-08-2003 08:11 PM
