Arion AF-1500?Information exchange on receiver software, including updates, problems and fine tuning. | |
| | #2 | |||
| Specialist Contributor Join Date: 01-09-2004 Location: china
My System: hp7800---perfect arion-1700 clone receiver! + coolsat 4000pro + pansat 2500a + starsat sr-x200ci + infinity usb+cas interface 2+matrix reloaded |
arion af1700=powersky 1700e=polaris 4018se=ferguson 4018se | |||
| | #3 | |||
| Regular Member Join Date: 07-02-2005
If so, can you pm me where I can search. thank you very much | |||
| | #4 | |||
| Member Join Date: 06-02-2005
Hi, Go to the Website Arion : http://www.arion.co.kr/frame_english.html but you need ID and Password to enter in the support tech. If you have the both pass please send me it to this e-mail adress : beurk_2003@yahoo.fr Thank you. N.B. : i can help you if i access to Arion support tech. | |||
| | #5 | |||
yes! try this website for polaris af-4018se http://polaris.dvhk.pl/?id=glowna good luck! | |||
| | #6 | |||
toke Th ferguson site seems not to be working. Can yu PM me the soft? thanks | |||
| | #7 | ||
| Member Join Date: 31-01-2005
| | #8 | ||
| | #9 | |||
| | #10 | |||
I still can not find any software and bootloader to upgrade. I cannot send you a mail either as it says that this option is not activated. When I click on the maillink it says that my account already is activated. Please helpm me out here | |||
| | #11 | |||
Send a private message to rockchang and give me ur email adress! btw, try this website : http://www.zotos.biz/download.html | |||
| | #13 | ||
| Hello, I found this software AF-4018SE_work16_20050117_LakiOnline.auc . Can anybody confirm that this will work in my arion af-1500 (1700)? Should I repack it or can I just upload it into my receiver thanks | ||
| | #14 | |||
i think it will work! good luck! | |||
| | #17 | |||
| | #18 | |||
| Regular Member Join Date: 05-01-2005
and then got ---- and LANG which mean successful. But, when I connect it to TV (the connection is 100% correct), there is no pictures on the screen. Does this mean a bad flash again (I got 8.8.8.8. before)? Please help. Also, would you please post a link to the correct s/w for Arion 1500E? Thanks in advance!
| | #20 | |||
| Regular Member Join Date: 03-03-2005
My System: OpenBox SKY+ Pioneer XED 50" Plasma B&W Surround Speaker DENON AV/DVD Player Rel Quake Sub | Hi G My Bootloader is 16.1 where can I get the patch for my Open Box which the same as AF1700E?
| af1500, arion |
Similar Threads | ||||
| Ajuda - ARION AF-2000e | portkaku | Arion | 3 | 19-04-2006 11:29 PM |
| ARION AF-2000e - HELP | portkaku | Arion | 2 | 12-04-2006 12:03 PM |
| Hidden Function Codes Of Arion Based Receivers | linax | Receiver software, international Section | 2 | 04-04-2006 11:48 AM |
| Arion AF | asagir | Receiver software, international Section | 3 | 07-03-2006 09:01 AM |
