Please help me in my SR-X 120
Information exchange on receiver software, including updates, problems and fine tuning.
Old 15-02-2005   #1
Hi there
I have StarSat SR-X 120. Which is the latest software? And which is the latest codes file? I went to www.satsw.com
I found:
Jan_22_SR-X120_130_150_2000CH_1M
Jan_22_SR-X120_130_150_4000CH_2M
Jan_22_SR-X120_130_150_4000CH_V7
Which one of them is the latest?
Jan_22_keyscode_120_130_150_200, is it the latest codes file?
sw_ver_clean_for_SR-X120,150,200CI, What is it for?
Please help im new here. And i dont want to pay 10 $ to upgrade it.
generous is offline   Reply With Quote
Old 15-02-2005   #2
BGonaSTICK's Avatar
Hi m8.
Why do they call you 'generous'?
Only joking.
Maybe the $10 would buy you some peace of mind. A lot cheaper than a new receiver?
Old 15-02-2005   #3
Now u mean is this ur solution?
No one can help me?
Old 18-02-2005   #4
My System: Starsat,Strong, Onyx, Omax, Astrasat, Condor, Starcom, Astrovox, JTAG. Laptop,Desktop.
hello my friend,
In your receiver:
1- press on menu/stb status. A new screen will be appeard,it contains info about your receiver.write all info in order to remeber them later.
2- If your hardware verion is 2.1 so you can use http://www.satsw.com/Upload/Jan_22_S..._2000CH_1M.zip
3- http://www.satsw.com/Upload/sw_ver_c...,150,200CI.zip is a cleaner.It is used to erase the old software from your receiver.It's also used to change the hardware version if you want to install another file (it's a long story)
4-To know more about your receiver visit http://www.satellites.co.uk/php-bin/...ad.php?t=31734
5- forget about this key code.you can get a newer one at www.rdi-sat.com
6-you're always welcome.
nhfs49 is offline   Reply With Quote
Old 02-04-2005   #5
Readin, Askin & Learnin
Ar-Ey's Avatar
My System: I am using AD-9500 Alfa Box Digital Decoder and Currently I'm in Arabsat. 83cm dish and Universal KU LNB.
Old Receiver Upgrade
hi nfhs49!
i've been reading a lot of ur post...
and i found it all useful.
coz i have big problem and that
i can't get enough sleep.
here it goes, i have alfadigital AD-9500 receiver.
it has 1 CI with irdeto in it and smartcard slot.
can i upgrade my receiver with any s/w available
so that i can enter codes in it.
Im just a noob in satellite but im learning fast.
Thanks a lot to this forum and also to anyone
who will reply and read
Ar-Ey is offline   Reply With Quote
120, srx
[IMG] code is Off
Similar Threads
Starsat 120 help needed ajhan Receiver software, international Section 3 31-05-2006 01:30 PM
Duvida acerca do Fte 120 JpSp FTE 5 19-04-2006 10:08 AM
FTE IRD 120 problema stand-by HD2All FTE 1 07-04-2006 12:15 AM
Triax 120 cm? steffan_st DISH SETUP: Single sat, Multi-Sat & Motorised systems 18 14-01-2006 05:17 PM
