Manhaten ST200 Box with Dragon Cam, What do you think?
Information exchange on receiver software, including updates, problems and fine tuning.
Old 11-03-2005   #1
My System: OpenBox SKY+ Pioneer XED 50" Plasma B&W Surround Speaker DENON AV/DVD Player Rel Quake Sub
Hi People
After finding out my current Box is a total S**t, I have decided to go for a new Box,
I asked about and a seller said the Manhaten ST200 with a Dragon Cam is as good as any.
Price for bOX IS £139.00
Price for Cam is £99.00
I only want this Box to watch Premiership Football that is on Sat 3:00pm and other times that is not covered by SKY
What is your opinion on this Box?
Is it User Friendly?
Can the software be easilty updated?
Would you say the price is fair and would you recoomend anything better?
Thank you
Mahdi007 is offline   Reply With Quote
Old 11-03-2005   #2
BGonaSTICK's Avatar
If the box has a CI slot, you won't need to update the receiver, but you will need a phoenix programmer and a loader card.
Old 11-03-2005   #3
Have you heard of the box mentioned above? is it any good and well known? Also isn't the Dragon Cam the CI?
Old 11-03-2005   #4
BGonaSTICK's Avatar
Don't know anything about it, but the CI (Common Interface) is a slot in the box into which you would plug the CAM (if it has one). No slot, no CAM.
The CAM would be 'loaded' by a loader card which you would need to program with a programmer connected to your PC.
Old 12-03-2005   #5
Irregular Member
My System: Plaza ST550 Dragon 4.1, Cas2 + Add on. Mastera card progger. Lots of Ice Scrapers :-)
Hey Mahdi007,
Read about your Plaza ST200 here: -
h**p://www.manhattan-receivers.com/modules/articles/article.php?id=10
I have it's big brother, the ST550, and am well impressed with it. Both are upgradeable OTA, and yours has twin CI, so should be OK for your Saturdays (A Matrix Cam may be cheaper and will do what you want also)
Oh, and yes......it is very user friendly
daveenty is offline   Reply With Quote
Old 12-03-2005   #6
Hi, and thanks for the advice, is there a major deifference in price between the ST200 and the Matrix that you are suggesting?
Also is £139.00 a fair price?
Originally Posted by daveenty
Hey Mahdi007,
Old 12-03-2005   #7
Irregular Member
The price on the Plaza seems quite good, though there are cheaper CI receivers around. As for the Matrix, it's a cam, not a receiver. I meant as a replacement for the Dragon cam you mentioned earlier. You can pick them up for around £35-40.
Matrix Revolutions is the one of choice at the moment, though things change quite quickly in this game.
Incidentally, the dragon cam seemed expensive at £99....try a search around, or try h**p://www.hisat.com (not a recommendation, merely a suggestion)
Old 12-03-2005   #8
Thanks daveenty, I willl look for the CAM that you have suggested, by the sound of thing I could get a CAM and next day it goes all pear shape and I need to obtain a new one. Have you or any on else on here spent a lot of money on CAMS? I know you can never say how long it will last, but surly it must be more than a couple of months?
Old 12-03-2005   #9
BGonaSTICK's Avatar
I'm afraid that if you go the CAM route, then it could (and probably will) cost you a lot of money in the long run. Most folks that use CAMs have a drawer full of them (and cards) gathering dust!
That's not to say that it's not a good idea. This isn't a cheap hobby full-stop.
It's just something that you have to accept when you start out.
box, cam, dragon, manhaten, st200
[IMG] code is Off
Similar Threads
any hope for ma useless Irdeto CAM yet sat_freak Irdeto system 7 10-05-2006 04:32 PM
Dragon Cam 4.1 Should i get one trashmanlfc X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex 3 15-10-2005 02:32 PM
Questions for the Cam experts Samba65 Cams and decoders General 14 13-05-2004 03:00 PM
AXAS2 CAM decrypts limited channels petchletch Matrix Reloaded, Revolutions and CAS interface 0 25-02-2004 10:47 AM
axas cam allnighta Magic Module 2 21-01-2004 06:34 PM
