Flash memory erase neotionbox3000
Information exchange on receiver software, including updates, problems and fine tuning.
Old 11-03-2005   #1
Please help
how can i erase flash memory of neotionbox 3000 or lazer 2003ci
thanks.
GIVARGIS is offline   Reply With Quote
Old 12-03-2005   #2
slugworth's Avatar
My System: stm5105 based receivers
jtag
20pin simple jtag and jkeys.exe with the correct jkeys.def file.
slugworth is offline   Reply With Quote
Old 12-03-2005   #3
slugworth's Avatar
neotion jkeys.def
//Neotion jkeys.def, which is the same for the lazer2003.
//Release, 1,0,3
//Microprocessor JTAG Identification Codes
// ST Micros
Micro, 1, 1, "STi5500", 0xd4c9041, 0xfffffff
Micro, 2, 1, "ST20-TP2", 0x5193041, 0xfffffff
Micro, 13, 1, "ST20-TP3", 0x5194041, 0xfffffff
Micro, 3, 1, "ST20-TP4", 0x5198041, 0xfffffff
Micro, 4, 1, "ST20-GP6", 0x5196041, 0xfffffff
Micro, 5, 1, "STi5505", 0xd4cb041, 0xfffffff
Micro, 6, 1, "STi5508", 0xd402041, 0xfffffff
Micro, 7, 1, "STi5518", 0xd502041, 0xfffffff
Micro, 8, 1, "STi5518MVB-X", 0xd405041, 0xfffffff
Micro, 9, 1, "STi5510", 0xd4cd041, 0xfffffff
Micro, 14, 1, "STi5516FWB-X", 0xD41D041, 0xfffffff
// LSI Micros
Micro, 11, 2, "LSI SC2000",0x400006d,0xfffffff
// Unknowns
Micro, 10, 1, "Unknown ST device", 0x041,0xfff
Micro, 12, 2, "Unknown LSI device", 0x06d, 0xfff
// IRD Defintions/IRD Flash Defintions
IRD, 1, "NB1000s", 1, 1, 1, 1, 2, 2, 0x7FFFFFC0, 0x7FFFFFC4, 0x7FFFFFA0, 0x7FFFFFA8, 0x7FFEFFC4, 0x7FFEFFC8, "10L", 1, 1
IRDFlash, 1, "Flash 1(29LV160)", 0x22C4, 0x7FE00000, 0x200000, 2, 2, 0
IRD, 2, "NB1000", 1, 1, 1, 1, 2, 2, 0x7FFFFFC0, 0x7FFFFFC4, 0x7FFFFFA0, 0x7FFFFFA8, 0x7FFEFFC4, 0x7FFEFFC8, "10L", 1, 1
IRDFlash, 2, "Flash 1(29LV160)", 0x22C4, 0x7FE00000, 0x200000, 2, 2, 0
IRD, 3, "NB2000", 1, 1, 1, 1, 2, 2, 0x7FFFFFC0, 0x7FFFFFC4, 0x7FFFFFA0, 0x7FFFFFA8, 0x7FFEFFC4, 0x7FFEFFC8, "10L", 1, 1
IRDFlash, 3, "Flash 1(29LV160)", 0x22C4, 0x7FE00000, 0x200000, 2, 2, 0
IRD, 4, "NB3000", 1, 1, 1, 1, 2, 2, 0x7FFFFFC0, 0x7FFFFFC4, 0x7FFFFFA0, 0x7FFFFFA8, 0x7FFEFFC4, 0x7FFEFFC8, "10L", 1, 1
IRDFlash, 4, "Flash 1(29LV160)", 0x22C4, 0x7FE00000, 0x200000, 2, 2, 0
// Flash Definitions/Flash Sector Definitions
Flash, 1, "29LV160TT", 0x22C4, 0x200000, 1, 1, 0, 1, 35, 1
Sector, 1, 31,0 , 0x10000
Sector, 1, 1, 0x1f0000, 0x8000
Sector, 1, 1, 0x1f8000, 0x2000
Sector, 1, 1, 0x1fa000, 0x2000
Sector, 1, 1, 0x1fc000, 0x4000
Flash, 2, "29LV160TT", 0x22C4, 0x200000, 1, 1, 0, 1, 35, 1
Sector, 2, 31,0 , 0x10000
Sector, 2, 1, 0x1f0000, 0x8000
Sector, 2, 1, 0x1f8000, 0x2000
Sector, 2, 1, 0x1fa000, 0x2000
Sector, 2, 1, 0x1fc000, 0x4000
Flash, 3, "29LV160TT", 0x22C4, 0x200000, 1, 1, 0, 1, 35, 1
Sector, 3, 31,0 , 0x10000
Sector, 3, 1, 0x1f0000, 0x8000
Sector, 3, 1, 0x1f8000, 0x2000
Sector, 3, 1, 0x1fa000, 0x2000
Sector, 3, 1, 0x1fc000, 0x4000
Flash, 4, "29LV160", 0x22C4, 0x200000, 1, 1, 0, 1, 35, 1
Sector, 4, 31,0 , 0x10000
Sector, 4, 1, 0x1f0000, 0x8000
Sector, 4, 1, 0x1f8000, 0x2000
Sector, 4, 1, 0x1fa000, 0x2000
Sector, 4, 1, 0x1fc000, 0x4000
// Flash Manufacturer Codes
FlashMfg, 0x01, "AMD"
FlashMfg, 0x20, "STMicro"
FlashMfg, 0x89, "Intel"
FlashMfg, 0xAD, "Hynix"
FlashMfg, 0xB0, "Intel"
FlashMfg, 0xBF, "SST"
Old 12-03-2005   #4
slugworth's Avatar
simple 20pin jtag pix
Simple 20pin jtag pinouts and wiring.
Use a db25 male connector and 100 ohm 1/4w resistors.
Keep the cable under 18 inches in length.
Temporarily ground pin 115 on the sti5518, then apply ac power
to put the receiver into BFR mode to erase/write the tsop.
As always, backup the firmware first, in case something goes
wrong.
Old 12-03-2005   #5
slugworth's Avatar
sti5518 jtag
Sti5518 jtag pinouts for receivers not having a 20pin jtag connector.
Add 100 ohm resistors inline with the signal lines between sti5518
and the db25.
DB25 pin2--------->TMS 110 \
DB25 pin3--------->TCK 113 \
DB25 pin4--------->TDI 112 --on Sti5518 processor
DB25 pin5--------->TRST 109 /
DB25 pin13-------->TDO 111 /
DB25 pin25-------->GND
The JTAG pinouts for STi5518 are as follows:
TRST: pin109
TMS : pin110
TDO : pin111
TDI : pin112
TCK : pin113
BFR : pin115 "ground this pin @ receiver ac powerup to put
processor into BFR mode".This will allow erase/writes of the
tsop with jkeys.
Slugworth
Old 21-03-2005   #6
thanks for your reply
please help me how can i download the jkeys.exe
and what is the db25 male connector is it the pc paralel port?
sorry for my bad english
thank you.
Old 22-03-2005   #7
slugworth's Avatar
neotion jkeys
This is the neotionbox version of jkeys, unzip to a folder on your hard drive.
The male db25 is the connector that plugs into the parallel port on the pc.
Either buy a connector, or cut an old printer cable short and use that.
It should also work with the lazer models.
Old 02-04-2005   #8
thanks
thanks for help
i am going to complet all of the above things and repair my receiver
i wish next week i send you a message about my receiver and its work
thank you.
Old 15-04-2005   #9
thank you slugworth thank you slugworth thank you slugworth
my receiver now work thanks for your help
i never forget your help
Old 21-09-2005   #10
My System: Neotion 3000 KAON 570 2CI
Originally Posted by slugworth
BFR : pin115 "ground this pin receiver ac powerup to put
tsop with jkeys.
Hello,
where can I find this pin (BFR, pin115) in a neotion3000?
I want to erase flash but I can't find it.
Thanks,
Choldi
choldi is offline   Reply With Quote
Old 21-09-2005   #11
slugworth's Avatar
Wink skymax jtag
I would use the skymax jtag program, you don't have to ground pin115
on the sti5518 using that one and you don't have to play with .def files.
Old 22-09-2005   #12
Hello,
I've downloaded skymax_up 2.2. Is this version correct?
When I click on Start, it gives to me Ok (at the third of four try).
And when I click on Erase, it starts, but after some time, it gives to me FAIL.
Any idea?
uuuuupppppppppps,
now It doesn't appears Err0 on display, but it doesn't load the firmware via pclink.
Whan can I do now?
Thanks again,
Choldi
Old 22-09-2005   #13
slugworth's Avatar
Post win98
Originally Posted by choldi
Hello,
Any idea?
uuuuupppppppppps,
Whan can I do now?
Thanks again,
Choldi
It works better in win98, I don't know what os you are using.
In win2k, it says erase failed but I still program the flash anyway.
Err0 you could have used the loader delta 1.0 to recover instead
of jtag.
Old 22-09-2005   #14
slugworth's Avatar
Angry rats?
Whats with the rats in my post?
Old 23-09-2005   #15
Amo Amas Amant Admin
Topper's Avatar
Nope
Those are not rats they are hamsters or to be more precise mamsters. There is nothing personal being aimed at anybody with this action, it is a ploy being used by the forum to dissuade people from posting Email addresses, which in certain sections of this forum has got out of control so the "at" will no longer display. Posting Email addresses defeats the very objective of a forum which should contain frank and open discussion not secret messages between members.
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 23-09-2005   #16
slugworth's Avatar
at
Originally Posted by michael dranfield
Not just sure about your comment about rats, but as you have not answered my question I assume this was aimed at me ?
If I have done anything to offend you then please do say so ,
I am quite aware that my request was placed in the wrong forum ,but the reason for putting in this forum was that you seem to have a good technical understanding of flash memory and here in the U.K getting any help is virtually impossible .
I never heard of that processor, so that's why I didn't respond.
I have had my posts censored at other sites, but I have never seen creatures
replace words before.
Old 23-09-2005   #17
slugworth's Avatar
Question model?
What brand receiver/model is it in?
Old 05-10-2005   #18
My System: Public computer
JTAG of Mediacom 910i
Hi Slugworth,
Kindly assist. Frm the way you have replied to my colleagues request i hope you are able to assist me with my dead Mediacom 910i.
I have been unable to erase the Chip using JTAG.
How do I boot this receiver in BFR mode?
Please HELP!
Regards
Morningstar
Morningstar is offline   Reply With Quote
Old 13-07-2006   #19
My System: 2,5 mts. dish, twinhan card
A question....
Hi, maybe is some dumb question, but i try to connect to my EuroBox 9700 plus with a STI5512 with Jtag and can't recognize the processor....any help is very welcome,,,
thanks
ElMEro is offline   Reply With Quote
Old 16-07-2006   #20
My System: satellite card
good work , thanks slugworth
i have
starvision ultra 5300
hd: St5518S
tuner: samsung
sw version: v2.3.9
loader: 1.0.9
what is the suitable loader and software to upgrad this system up to date ; and to autoupgrad the sport swiss channels, AB sat , etc.
thanks again for yours good efforts
redap is offline   Reply With Quote
Old 12-09-2006   #21
thanks for all those informations and discussion.....
hazim is offline   Reply With Quote
erase, flash, memory, neotionbox3000
[IMG] code is Off
Similar Threads
please help me upgrade one EUROSTAR Eurobox-9700 gsmsikar Receiver software, international Section 9 09-09-2006 04:27 PM
IRD120 mesmo com JTAG morreu (cont.) ilmc2001@SAPO.PT FTE 2 06-05-2006 04:22 PM
How can I earse receiver flash memory Ibrahim Samir Receiver software, international Section 5 13-04-2006 03:25 AM
wiped the int eeprom and flash memory doggy Cards & Programmers General 8 01-01-2004 07:47 PM
New antypiracy STMicroelectronics chip net1 Daily Satellite and Broadcast industry News 0 22-11-2003 10:21 PM
