Digisat 2200/Arion 1700E/Head 1100Information exchange on receiver software, including updates, problems and fine tuning. | |
| Regular Member Join Date: 10-12-2004
hi, please can someone assist me on the above reciever if you can, but someone told me its an arion clone and its the same with Head 1100 but it can not accept arion software. below are its Information :- H/W Digi 2200 S/W $ASWE4668S150EC DataBase Version :- 00600009 Boot Version :- 0016.1 I try to use AUCHedit but failed please assist me with the procedures. Thanks. | ||
| | #4 | |||
| Regular Member Join Date: 10-07-2004
Is anything wrong with your line? I've been tryin' to call you, only landline keeps ringing but no answer. Try this and see what you get, defence on the patch you install. blockhead. ################################################## ## Hidden Function Codes The list of codes to activate hidden functions in Arion based receivers. For f/w with EMU function to activate : 1. Go to menu. By pressing menu on your remote 2. Key in : 19370 3. Key in pin: 2486 patch is activated. Now in menu > games, you shall see emu-keys section, should you wish to alter the keys manually, you need to enter pin 0000. If you forgot the pin you had entered, press 0786 to reset it and enter menu or blocked channels. * Other Codes to be entered when tuner is in stand by mode. 42114802500 : display Full information about your tuner (h/w & f/w) 24680 – Uploading keys (irk) or channels list to the receiver. 74621 – Downloading channels list from the receiver. 74623 – Downloading full set of keys from the receiver. 74620 – Downloading f/w from the receiver (AUC_HEDIT). 14802 – Downloading boot from the receiver (AUC_HEDIT) 14809 – Downloading full f/w with boot from the receiver using (AUC_HEDIT) this way you get “universal” f/w. Test codes: 42125 42126 42127 __________________________________________________ To connect your PC to the receiver, you'll need null modem RS 232 9-pin cable: 1+6---->4 2------>3 3------>2 4---->1+6 5------>5 7------>8 8------>7 __________________________________________________ How to receive the STB Data from the STB to PC. NOTE: Receive indicates that transfers the existing data (STB Data) from the STB to your PC; whereas, Send indicates that transfers the added or modified data from PC to the STB). 1. Choose the "Receive" menu from Main Menu or Toolbar. 2. Turn on the main power of STB. 3. Press special key-code "74621" in the STB stanby mode. 4. The STB Data will be transferred automatically, with a window indicating the process status. (If you wish to abort receiving process click 'CANCEL' button.) 5. When finished the receiving process, click the 'OK' button and then an active window will appear your received data. Please save the data with specific name using "Save As" menu. How to send the STB Data from PC to STB. 1. Choose the "Send" menu from Main Menu or Toolbar. 2. Turn on(reboot) the main power of STB. 3. The STB Data will be transferred automatically, with a window indicating the process status. If you wish to abort sending process click 'CANCEL' button. AF1018SE, AF2018SE, AF3018SE, AF4018SE AF5018CI s/w upgrade Upgrade procedure 1. Power off receiver. 2. Connect PC and receiver using a serial cable. Receiver should be power-off state. 3. Execute "ARIONER.EXE" First, Select proper PORT. ex) COM1 or COM2 4. Click the "Open" button and select "ADA2030SE.auc". Click the "Send program to IRD" button. Then, typically "Last status" shows message of "Waiting connect request ack". Now PC are ready to transfer. 5. Power on receiver upgrade process will be automatically done in a few seconds. You can see the progress with PC and/or receiver. NOTE When receiver shows "Saving" message, you have to be very careful. Never power off during this save time. It couldn't reboot and you have to send back the receiver to us. At the end of the process, small message window at PC will appear. Please don't care about the message. Click "OK" button to clear the message. Receiver reboot automatically. Check front display of receiver. If it shows "----" or any channel number "xxxx", then successful. AF8018UCI s/w upgrade 1. Press “24680” in standby Mode 2. You can see “AIT” on the front panel 3. Open the file “***.U01” by using PSLoader 4. Then you can see POPUP menu to ask to open another file 5. Then, select the file “***.U02” 6. The selection order of files must follow up. 7. S/W upgrade will be done automatically. 8. After completion of upgrade, the receiver will be rebooting automatically. regards, blockhead. ################################################## ##
| 1100, 1700e or head, 2200 or arion, digisat |
Similar Threads | ||||
| Plusat 1100 fta | neofito | HE@D | 5 | 02-09-2006 09:33 PM |
| canais para edision 1100 fte | marco75 | Edision | 1 | 10-05-2006 11:56 PM |
| Edision 1100 fta ou Head 1100 Fta Plus ( igual a teka 1000) | Pitong | Edision | 2 | 21-02-2006 04:06 AM |
| Clonar Edision 1100 a partir de 2100 - Ajuda | carocho | Edision | 3 | 23-01-2006 03:21 PM |
| ReelBox PVR 1100 future alternative to dreambox? | martinw01908 | Dreambox General | 5 | 24-04-2005 06:26 PM |
