JTAG for Arion 1700E
Information exchange on receiver software, including updates, problems and fine tuning.
Old 17-03-2005   #1
Hi guys,
Does anyone know how to flash memory of Arion AF-1700E.
I need to reprogrammed my Arion due to "88:88" displays...
really appreciate for those who willing to give me any websites in english..
I need to ged rid out this problem..
many thanks.
Hary
harifoz is offline   Reply With Quote
Old 18-03-2005   #2
Rubyboy's Avatar
Talking
Originally Posted by harifoz
Hi guys,
many thanks.
Hary
dear,
you install real or true software in your receiver again.
you do not need jtag.arion receiver is that if you install fake software or other
software,you can install again,stb will be run.arion af -1700E latest software is this link: http://www.zotos.biz/download.html
Rubyboy is offline   Reply With Quote
Old 18-03-2005   #3
Originally Posted by Rubyboy
dear,
Thanks ruby,
but it was installed with startarck 2004 super
Old 18-03-2005   #4
rockchang's Avatar
My System: hp7800---perfect arion-1700 clone receiver! + coolsat 4000pro + pansat 2500a + starsat sr-x200ci + infinity usb+cas interface 2+matrix reloaded
Smile
have u got a jtag cabel?
1700-jtag
what causes the 88:88 problem? after a software upgrading?
rockchang is offline   Reply With Quote
Old 18-03-2005   #5
1700-jtag
Hi rockchang
What file it is? for reprogram the memory or anyelse?.
If someone has JKEYS, BIN file and firmware for ARION-1700E that'll be fine.
pls email me on fmrizal@gmail.com
thanks
Old 03-10-2005   #6
My System: Skystar 2 PCI, Powersky 1500, Arion 1700
Hi, will the jtag files given here work for AF-1700EC aswell?
MrMariusz is offline   Reply With Quote
Old 04-10-2005   #7
rockchang's Avatar
Talking
yes. it works!
Old 11-10-2005   #8
salvador's Avatar
My System: Ferguson Digibox & Mini dish - Arion AF-1700EC & 80 cm dish Computer Setup? a couple of PCs and a few Laptos
yes. it works!
Do you need a special cable for this?
Salvador
salvador is offline   Reply With Quote
Old 11-10-2005   #9
I haven't been able to flash with jkeys yet (it does tell me my device is Sti5518MVB-X and ID 0x1d405041) .. it tell me "flash codes not recognized" when I go into flash programming menu. Why is this?
Old 12-10-2005   #10
rockchang's Avatar
Talking
1. yes, jtag needs a special cable , you can find the schematics in 1700-jtag
2.the error message shows that maybe u didnt select the right flash type,
you can try the following software for jtag, it is much easier to use than jkeys.
http://dvb.nease.net/rock/skymax.rar
good luck!
Old 12-10-2005   #11
good luck!
Ok, I put it in the receiver, now what do I do? Where will I get a boot file that the receiver will accept?
Don't I need to put in a new EEPROM too?
edit: Could it be that my flash is write-protected?!
Old 13-10-2005   #12
Ok, I have a new definition file for jkeys, I can read the flash out full now, but when I attempt to erase I get "DQ6 stopped toggling" error. I assume this has to do with write-protection. I'm gonna try and bypass it, found a document on the web...
Old 14-10-2005   #13
rockchang's Avatar
Cool
1。flash write-protection is impossible for the stb. because when u scan channels, setting ur receiver, you are aslo writing the flash.
i think maybe u need to re-solder the flash on the mainboard.
2。how to use skymax to jtag ur receiver?
a.connect receiver and computer with jtag cable.
b.power on receiver.
c. run SKYMAX_up1.3, select 2MB
d.click START ,if no errors, then press erase, at last, press write and select 1700-BIN file. then wait patiently untill you get the successful message.
good luck!
Old 14-10-2005   #14
Ok I did that but the next step is sending through RS-232, right? do you have buc/auc files that will work 100% sure with arioner ?
However I do think there is a problem with the flash or the jtag cable... after I wrote the flash through skymax I tried to read it out and what I got was basically 2 MB of empty data FF...
Old 15-10-2005   #15
rockchang's Avatar
Cool
if u jtag ur receiver successfully, then u can upgrade your box through rs232 port.
you can find the loader .buc file in
http://dvb.nease.net/file/7800-sofware.rar
.auc file in
http://dvb.nease.net/file/HPZ6579.rar
good luck!
Old 17-10-2005   #16
salvador's Avatar
Can you buy this cable anywhere or you just have to build it yourself?
Salvador
Old 18-10-2005   #17
rockchang, do you have the EEPROM bin for the Arion aswell?
Old 19-10-2005   #18
rockchang's Avatar
Cool
Originally Posted by salvador
Salvador
hi,
I made it by myself , its not a difficult job,
you can search with the key word " jtag" on AL7BAR, you can find lots of topics about how to make a jtag cable!
Old 19-10-2005   #19
rockchang's Avatar
Cool
hi,MrMariusz
eeprom is used for saving channel data, channel volume, the last channel u watched, etc.
so it isnt necessary for u to get the eeprom bin file.
good luck!
Old 19-10-2005   #20
salvador's Avatar
hi,
Thanks for the info.
I know now what I will have to do if I ever need one
Salvador
Old 07-03-2006   #21
My System: Hi,
I was reading now yours in the topic and some of the links are broken, it would be possible you to send the files or the new links, I am posting that same message in the forum
hal_0 is offline   Reply With Quote
1700e, arion, jtag
[IMG] code is Off
Similar Threads
How to jtag Supermax Super 6000ci Plus gabrielbadea Receiver software, international Section 2 16-04-2007 08:54 AM
Jtag para 420SM Qual?????????? xonezinho FTE 1 22-05-2006 06:55 PM
Jtag 8005 S Phantom2010 Golden Interstar 0 14-05-2006 03:57 AM
need help with JTAG cable/powersky1900ci nr66 Receiver software, international Section 8 10-02-2006 09:29 PM
Repair Xtreme5690 with Jtag help needed falco2121 Receiver software, international Section 0 09-02-2006 10:21 AM
