help software for Mediastar Magic Fox Plus | |
| Regular Member Join Date: 02-04-2005 Location: evrywhere
My System: JDHJVHSJKV | does any one of you know how to use simple uploding.is has only port and start. but i don't know what file must be downloded yhe receiver is Mediastar Magic Fox Plus | ||
| | #2 | |||
| Regular Member Join Date: 12-12-2004
try http://p321.com/upload/ for the latest firmware. to upgrade the firmware do the following steps: 1. Get a null modem (cross over) cable (9 pins - both ends female) (I dont know which country u r now - try the electronic shops they probably will sell u the cable otherwise u will have to make one) for making a null modem cable use this link http://www.uoguelph.ca/~antoon/circ/nulmodem.htm 2. download the latest firmware from the site mentioned above and unzip the files. (it will contain the firmware and a simple upload executable program) 3.. connect 1 end of the cable to your pc/laptop (when u have unzipped the firmware update) and other end to the comm port in the receiver. 4. boot up your pc (make sure your receiver is switched off and unplug all the sat cables) 5. switch on the receiver 6. run the simple upload executable program 7. select the correct comm port (trial and error) 8. press START - after a few seconds a message will appear "waiting for bobb" - press OK 9. look at the display of the receiver - it will boot then the upload should start 1-100 10. after the upload is successfully complete switch off the receiver your receiver should now run with the updated firmware. NOTE - U WILL PROBABLY LOSE ALL YOUR SATELLITE SETTINGS AND WILL HAVE TO REPROGRAM THEM AGAIN. Best of luck, | |||
| fox, magic, mediastar, software |
Similar Threads | ||||
| NOW you can turn your receive super to ultra enter here | jack0 | Receiver software, international Section | 364 | 17-11-2008 12:26 PM |
| Microsoft Pre-release Software License Terms | Satdude | Daily Satellite and Broadcast industry News | 2 | 26-04-2006 03:56 PM |
| i have magic box and i need software | wegoo | Magic Module | 1 | 30-09-2003 05:41 PM |
| FAQ:Programming the Magic Module for the second time or more | Nickolai | Magic Module | 0 | 19-09-2002 12:44 AM |
| FAQ: Programming the Magic Module for the FIRST time | Nickolai | Magic Module | 0 | 19-09-2002 12:41 AM |
