MY Small Open Box 5, will not turn on/CREP, please HELPInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Regular Member Join Date: 03-03-2005
My System: OpenBox SKY+ Pioneer XED 50" Plasma B&W Surround Speaker DENON AV/DVD Player Rel Quake Sub |
Hi I tried to upgrade the firmware on my box, I used AUC_HEditv and Arion.exe to upload the file. After doing so the Box game me the 88-88 and I keep getting CREP on the display. I spoke to someone and he said it was a bad firmware. He advised me to get a 10pin J-Tag Cable. Any how what do I need to do to get the BOX Up and running again. Please help as it is completely useless at them moment. Thanks in advance Below is PIC of the Reciver Board Ebay | ||
| Specialist Contributor Join Date: 01-09-2004 Location: china
My System: hp7800---perfect arion-1700 clone receiver! + coolsat 4000pro + pansat 2500a + starsat sr-x200ci + infinity usb+cas interface 2+matrix reloaded | hi, buddy, i am sorry to hear that~~ CPER means "compare error", it means u didnt download the right firmware.and i often meet this problem. jtag isnt a necessary job. if u can find the right software(*.auc) , u will be able to fix it just with a com port download. just call u dealer and let him send u the right upgrade software! good luck!! | ||
My System: hp7800---perfect arion-1700 clone receiver! + coolsat 4000pro + pansat 2500a + starsat sr-x200ci + infinity usb+cas interface 2+matrix reloaded | | ||
| | #4 | |||
My System: OpenBox SKY+ Pioneer XED 50" Plasma B&W Surround Speaker DENON AV/DVD Player Rel Quake Sub | Thanks Rock, you are always willing to help. Will download and try it, will let you know hwo it goes
| | #5 | ||
My System: OpenBox SKY+ Pioneer XED 50" Plasma B&W Surround Speaker DENON AV/DVD Player Rel Quake Sub | Ok, managed to get it.. however I do not have channels like TPS and Multi.Vision, thanks for helpping me get up and running again. Please keep an eye out for the latest firmware fo ths BOX | ||
| | #6 | ||
| Regular Member Join Date: 20-09-2004
| Mahdi mate. My friend has the same receiver as you and everything works fine. Firstly try and check the keys then edit for multivision. press menu then 19370 then enter 2486. Go to the games option and open the editor and check if you have correct keys (assuming your receiver doesn't autoupdate). Alternatively, my friend uses startrack world-in-box (FTA) software in his receiver and it works well, but you have to use the new autoarioner to load the software. You can also go here _h**p://w*w.af1700.nm.ru/ang/index.htm and use openbox af1700 software dated 25.03.05. Again use autoarioner. It installs software pretty slowly so be patient and wait until you get message the download was successful. Both these softwares work, guaranteed. Also ensure that when you open autoarioner that your receiver isn't plugged in. Open the file you want then plug in receiver. There is no 'send' button. Good luck | ||
| | #7 | |||
Thanks | |||
| | #8 | |||
| | #9 | ||
| The website works fine mate. Try to fill in the missing letters where u see *. That should solve the problem. i put a * so as not to create a live link to that website The startrack site is starsw.com. Use world in box I software if you continue to have problems connecting to the above site, but all should be o.k | ||
| | #10 | |||
| Regular Member Join Date: 22-03-2005
My System: satellite |
| | #11 | ||
| Member Join Date: 30-03-2006 Location: Lebanon
My System: - | I have a problem with my receiver openbox f100. All the spanish channels of hispasat where open until 26/march/06. Is there a new code or is it my receiver? Please help | ||
| box, on or crep, open, small, turn |
Similar Threads | ||||
| Brand new box problem | bollywood | Sky Digital (BSkyB) and Astra 28.2 East General | 26 | 15-03-2004 09:21 AM |
| sky amstrad drx 400 .digi box | sting | Sky Digital (BSkyB) and Astra 28.2 East General | 0 | 04-03-2004 09:08 PM |
| Does Sky digital box pick up channels after subscription is cancelled? | Rajitha | Sky Digital (BSkyB) and Astra 28.2 East General | 4 | 07-02-2004 07:54 PM |
| New box advice | cjgall | Sky+ (Plus) and PVR Systems | 15 | 18-11-2003 04:15 PM |
| Hauppauge launches new satellite box | net1 | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 0 | 10-10-2003 07:35 PM |
