Whats the difference b/w firmware and patch
Information exchange on receiver software, including updates, problems and fine tuning.
Old 13-04-2005   #1
Whats the difference b/w firmware and patch software and how can we distinguish b/w them.
wiseguy4u is offline   Reply With Quote
Old 13-04-2005   #2
A bit enthusiastic
My System: Giberini 100,Cut Interstar GI-201,CD-80 feedhorn,Humax 8100 PVR,Coship 2300a,18 meters of Antec Superflex 1.6/7.3
A patch is a firmware that has been altered so it can unlock scrambled channels.
steffan_st is offline   Reply With Quote
Old 13-04-2005   #3
My System: dtm box
Arrow
How we can install the patch ? is it diffrent sofware from reciver to reciver ?
method is offline   Reply With Quote
Old 13-04-2005   #4
A bit enthusiastic
You connect your receiver to your computer with a proper cable,then you upload the patch to the receiver.
And yes,the software is different from receiver to receiver,some models are the same though,like for example the Coship 2300 and the Strong 3680.
Old 13-04-2005   #5
My System: dtm box
Arrow
where i can get the patch for my DTM box 2004 ? I did a search on web could not find it . i be happy if u show me where i can get it. Thanks
Old 13-04-2005   #6
DeepDiver's Avatar
My System: Vista- DreamBox 7020Si Nabilo Darkstar II -7025+ Black Hole 0.11 - DM8000 BlackHole 0.11
Your box appears to be a rebadge of Startrack receivers, have a look at this link h**p://www.satellite-heaven.de/index.htm?jump=Receiver
DeepDiver is offline   Reply With Quote
Old 13-04-2005   #7
My System: dtm box
Arrow
Thanks for u reply. I found that my reciver is useing "Arion" but how i could find its version and where to downloads it!! looking forward to your reply.Thanks
Old 13-04-2005   #8
My receiver is a rebadged receiver
I have a receiver Echospace FTA7575 which has no code menu software available according to my knowledge. This receiver is a rebadged receiver according to h**p://www.satellite-heaven.de/index.htm?jump=Receiver/
of the following receivers specific models
Atlanta 9201 plus
Zodiac DZR- 3600
Citizen 200CI
Starvision 150
SanyoSat 1100
SanyoSat 5000
Fujiyama S-6800
Changhong
Can i use these receivers software in my receiver and is there any code menu software available for any of these receivers?
b or w, difference, firmware, patch
[IMG] code is Off
