Where to buy RS232/serial cable (for Fortec)
Information exchange on receiver software, including updates, problems and fine tuning.
Old 16-04-2005   #1
My System: 28e, 19e, 13e, 30w
I've done the searches and read tons of threads but I can't find an online retailer mentioned (other than one that requires you to fax/post in your order. Most of the advice is to go to a computer shop, well I've done that (Staples and PCWorld were useless and that only leaves The Computer Shop - and, in the useless stakes, they're just as bad as the previous two!).
So can anyone suggest an online retailer that sells 'em. I'm not fussed if they're a PC shop or a satellite one - just as long as they're reliable, honestly priced. At the moment I'm looking at Vision Satellite via Ebay but £15.50 inc P&P seems a tad too much (albeit with a CD and details/help - but then I can get that for nada online!).
BTW it's for a Fortec Star Lifetime Diamond (which means it should be a female to female straight through cable - according to the manual!!).
Cheers
Skip Channel is offline   Reply With Quote
Old 16-04-2005   #2
rolfw's Avatar
Real name: Rolf
Have you tried one of our advertisers?
http://www.cableuniverse.co.uk/catal...ord=null+modem
http://www.cableuniverse.co.uk/catalog/index.php?main_page=product_info&products_id=686
PS. Supporting our advertisers helps to keep the site up and running.
Rolf
Old 17-04-2005   #3
I hadn't noticed advertisers other than the 'ads by Google' (which I usually blank as Google has a habit of being irrelevant!).
Cheers for the links, I had gone to that site the other day (via a bargain hunting forum!) but was uncertain of what cable would/might be right and their shipping seemed steep. But seeing as they're a sponsor and they're £6 cheaper than that Ebay option, I might be tempted!
I think SL-444 would be the right one, but I'm not 100% certain. What d'you reckon?
Old 17-04-2005   #4
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
Try Maplin's.
9-way serial RS232 serial cable Code VD73Q £4.99
Gender changer (needed for the Fortec) JW58N £4.99
Unless you can find a female-female straight RS232 cable (doubtful)
Llew is offline   Reply With Quote
Old 17-04-2005   #5
rolfw's Avatar
Real name: Rolf
Ah, is it not a null modem type then Llew?
Rolf
Old 17-04-2005   #6
Llew's Avatar
That's true Rolf. You need one for STB - STB S/W Xfer though. I assume Skip Channel wants a STB-PC cable.
Old 17-04-2005   #7
Indeed you're right Llew, STB-PC I want - not STB-STB.
Old 17-04-2005   #8
Llew's Avatar
There you go then. If you don't have a Maplin's near you, their online ordering/delivery is fast.
Old 17-04-2005   #9
Maplins cost: £12.48, Vision Satellite (via Ebay): £15.50
I think I'll go for the latter. It's 3 squid more from VS but it's definately the cable for the receiver and although the CD and info that comes with it is stuff I could probably find (or have already found) on my own, it's a little bit of extra support.
buy, cable, fortec, rs232 or serial
[IMG] code is Off
Similar Threads
HDTV Primer spiney High Definition Receivers transmissions, satellite and Terrestrial 0 16-01-2006 12:42 PM
International News 3rd December net1 Daily Satellite and Broadcast industry News 0 03-12-2003 09:01 PM
Digital cable in Slovakia net1 Daily Satellite and Broadcast industry News 0 12-10-2003 07:15 PM
Hackers masquerade as Best Buy to steal credit-card details net1 Computer Discussion 0 23-06-2003 07:57 PM
Coax w hole The Meeting Place 6 12-10-2001 07:32 AM
