Professional help needed
Information exchange on receiver software, including updates, problems and fine tuning.
Old 25-04-2005   #1
My System: SR-X200CI PLUS
I have a StartSat SR-X200CI plus.
I upgraded it from there site, and i updated the keyscode with the latest file they have. and my version is now:
Model ID: E224
H/W: 7.00
S/W: 12.68
But i can't open Multivision, What shall i do???
Please do not ignore this thread
Rabba is offline   Reply With Quote
Old 25-04-2005   #2
Model ID: E224
H/W: 7.00
S/W: 12.68
You should go to your STB and check under VIACESS if the id & keys are right as I had the same problem (using the same model, H/W & S/W). When I added manually the id 01500 and two lines of latest keys under id 01500 08: and 01500 18:. If the two lines are already there then just check if the keys are right.
Good luck!
Cheers,
NEKI
Neki is offline   Reply With Quote
Old 25-04-2005   #3
Judas Priest
d122k7trb's Avatar
Real name: Arbi Minassian
My System: star-sat SR-X5D Receiver Premium X LNB 120" Dish Computer system: AMD Atlon XP 64 x2 6400+ Black Edition 4GB DDR2 Bus 800 RAM MB: Asus Crosshair 750 GB Seagate Barracuda 32 MB cache 22" LCD Widescreen Samsung 226BW SB Platinum Pro.
Talking
You mean you upgrade your receiver onsite + upgrading the hex codes. One was enough.
Anyway, what is done, is done.
You've to pay attn!!!!!! to your receiver version
<<Edit>>_http://www.satdw.com/downloads/SR-X200CI.zip
<<Edit>>_http://www.satdw.com/downloads/SR-X200CI_V7.zip
then one of them should be your software to download and upgrade.
at last you've to edit some hex codes.
http://www.satsat.net/showthread.php?t=1572
pay attantion to the Photoes. If you could only read the persion language, the life could be more interesting and realistic.
No live links to files please
d122k7trb is offline   Reply With Quote
Old 25-04-2005   #4
DeepDiver's Avatar
My System: Vista- DreamBox 7020Si Nabilo Darkstar II -7025+ Black Hole 0.11 - DM8000 BlackHole 0.11
Follow the steps of this post to solve your problem http://www.satellites.co.uk/php-bin/...8&postcount=11
DeepDiver is offline   Reply With Quote
needed, professional
[IMG] code is Off
Similar Threads
Windows XP Professional Edition problems wolsty Computer Discussion 14 06-10-2003 09:38 PM
Professional cannabis factory found on industrial estate net1 The Meeting Place 0 13-09-2003 10:07 PM
David Blaine - Above The Below- feed needed Shahid Transponders & channels 1 07-09-2003 08:37 PM
Free wallpaper/i,ages. WAP needed ! Shahid Mobile phone/GSM chat 0 31-08-2003 11:26 PM
Subsidies needed to meet digital deadline net1 Terrestrial Television, Digital and Analogue 0 27-08-2003 06:04 PM
