StarSat 200CI+ Nagra key updation problem on PolsatInformation exchange on receiver software, including updates, problems and fine tuning. | |
| On Road to.....nirvana? Join Date: 26-02-2005 Location: Middle Earth
My System: DB 7025 & StarSat SR-X 200 CI Plus | hi all, I have the following set up : HW : StarSat 200CI+ HW version : 7 Model ID : 224 SW version : 12.69.1 (latest from satsw.net) I noticed that while updating Nagra Keys of POLSAT(7001), the following error occurs : After updating the keys read like this: 00 : AA XX XX XX XX XX XX XX 01 : YY XX XX XX XX XX XX XX and the channels disappear. I noticed that the actual value of the key AA should be AA + 1 and YY actually YY + 1 (ie if both keys change) eg. if your STB updated it to 45, then actually it should be 46. (I manually made the change and it works fine) If you have this problem, use your calculator in HEX mode, add 1 to values of AA and YY and manually input the results and it should work till this is fixed. It worked for me so am sharing this tip with everyone. I feel that this could be a bug in the firmware and through this forum would appeal to the developers(satsw.net) to kindly consider fixing this in the next firmware version. TIA, SRAGOO | ||
| 200ci, key, nagra, polsat, problem, starsat, updation |
Similar Threads | ||||
| NOW you can turn your receive super to ultra enter here | jack0 | Receiver software, international Section | 364 | 17-11-2008 12:26 PM |
| LNb problem | Gizmo2000 | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 4 | 15-09-2003 09:12 AM |
| is this a diseqc problem | doggy | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 14 | 05-09-2003 02:44 AM |
| sony idtv problem | RESCO | Terrestrial Television, Digital and Analogue | 2 | 04-09-2003 10:42 AM |
| Aston to Diseq poitioner problem | BazelAd | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 4 | 20-08-2003 07:21 PM |
