Kaon Receiver For Dish TvInformation exchange on receiver software, including updates, problems and fine tuning. | |
| | #26 | ||
| Bandit Queen Join Date: 19-08-2004
My System: Satellite Blood |
Dear Lokesh, Please try ......... Step 1 Equipment to prepared EA. Same model (ex, CI model .CI model, PVR model .PVR model…) RS-232 Cable (Same as you used in ZENEGA) REMOCON HOST STB: STB from which new software, or new channels is upgraded. SLAVE STB: STB to which new software is upgraded. You should copy from HOST to SLAVE STB. Step 2 Power OFF the SLAVE STB. Step 3 Code power (Master S/W on Back Panel) OFF and then ON your HOST STB. Press successive FP [EXIT], [EXIT], [EXIT], RCU [MUTE] key within 3 second. (FPmeans front panel, RCU means remote controller.) Then STB will reset automatically, and turned on as HOST STB mode. Step 4 Connect your HOST STB and SLAVE STB by RS-232 Cable. Step 5 Power on the SLAVE STB, then SET to SET Upgrade starts automatically. (Front panel displays the status of upgrade process, like as Dn00, Up00, End…) Step 6 If no action on front panel, then please turn OFF the SLAVE STB and ON again. Step 7 Even several times of retries of Step 6, if there is no action, Please retry from step 2. Please don’t power off, when upgrade is on processing. STB could be damaged. On upgrade mode, power key is not available. If there is any problem on upgrading software, then contact with www.KaonMedia.com. | ||
| | #27 | ||
| Regular Member Join Date: 23-03-2004
| I tried these but no result further transmission between stb and pc shows the following message( please put ur lnb wires int receivers connected) Statusbar2 : Reading the Smartcard PMT PMT Processing Set ECM(0) PMT PMT Processing Set ECM(0) dynamic_check : sdt 13, 13 dynamic_check : nit 11, 11 PMT PMT Processing Set ECM(0) dynamic_check : sdt 15, 15 dynamic_check : nit 12, 1 PMT PMT Processing Set ECM(0) dynamic_check : sdt 13, 13 PMT PMT Processing Set ECM(0) dynamic_check : sdt 15, 15 PMT PMT Processing Set ECM(0) dynamic_check : sdt 13, 13 PMT PMT Processing Set ECM(0) dynamic_check : sdt 15, 15 PMT PMT Processing Set ECM(0) rst_ad PMT PMT Processing Set ECM(0) dynamic_check : sdt 13, 13 PMT PMT Processing Set ECM(0) PMT PMT Processing Set ECM(0) PMT PMT Processing Set ECM(0) dynamic_check : sdt 15, 15 PMT PMT Processing Set ECM(1) ECM(81) : 84 ECM=>CARD : 84 acc_status = 0 dynamic_check : sdt dynamic_check : nit 11, 11 ECM(80) : 90 ECM=>CARD : 90 acc_status = 0 PMT PMT Processing Set ECM(1) ECM(80) : 99 ECM=>CARD : 99 acc_status = 0 ECM(81) : 100 ECM=>CARD : 100 acc_status = 0 ECM(80) : 110 ECM=>CARD : 110 acc_status = 0 ECM(81) : 120 ECM=>CARD : 120 acc_status = 0 Statusbar2 : Reading the Smartcard PMT PMT Processing Set ECM(1) ECM(80) : 156 ECM=>CARD : 156 acc_status = 0 ECM(81) : 160 ECM=>CARD : 160 acc_status = 0 ECM(80) : 170 ECM=>CARD : 170 acc_status = 0 ECM(81) : 180 ECM=>CARD : 180 acc_status = 0 ECM(80) : 220 ECM=>CARD : 220 acc_status = 0 ECM(81) : 230 ECM=>CARD : 230 acc_status = 0 ECM(80) : 240 ECM=>CARD : 240 acc_status = 0 ECM(81) : 250 ECM=>CARD : 250 acc_status = 0 | ||
| | #28 | ||
| friends, I cannot continue with experimenting with my Kaon receiver unless I get a backup software. I need it urgently. please provide some help for the software which can take backup of all my receivers firmware and data. thanks. | ||
| | #29 | ||
| what language is this. Can any one convert this to simple english. this site contains a lot of help about my kaon receiver. I need it urgently. thanks. ابتدادرحالی که هنوزرسیوررابه برق نزده ایم آن رابه وسیله کابلrs232 به کامپیوترمتصل می سازیم ولودررااجرامی کنیم برای دریافت لودرازطریق لینک زیراقدام به دانلودلودرمی کنیم http://www.kaonmedia.com خب سپس آخرین پچ رانیزدرلودرفرامی خوانیم برای دریافت آخرین پچ هم ازلینک زیراستفاده می کنیم http://www.la-cafetera.com/kaon.htm پس ازدانلودلودروآخرین وجدیدترین پچ بایددقیقابه طریقه زیرعمل نمائیم نکته مهم دراین مرحله مابه فایلfirmware مواجه خواهیم شدوبایدبدانیم این فایل چسیت وازکجاآمده است اگربه خاطرداشته باشیم برخی ازکانالهای تلویزیونی ازرسیوربه خاطراینکه کاربران خودراواداربه خریدکارت نمایندازfirmware استفاده می کردندتاخریداران رسیورمجبورشوندبرای دیدن کانالهای کارتی خشاب وکارت موردنظرخودراکه قابلیت بازگشاهی رمزبه اصطلاحseca ویاnegra و.....خریداری نماینداماخوشبختانه امروزه این سیستم کددهی کاملاهک شده وازخرج مردم برای دیدن کانالهای کارتی کاسته است خب حالادیگرکاملامتوجه شدیم این فایل چرابه همراه این پچ ارائه شده است بنابراین درقسمتopenfirm فایلfirm رافرامی خوانیم ودرادامه فایل بافرمتbin راواردخواهیم کردسپس برروی گزینهopen کلیک می کنیم حالاشمادرقسمت بالای لودرمشخصات نرم افزاروسخت افزارخودرامشاهده می کنیدودرقسمت پایین نیزبااین گزینه هامواجه خواهیم شد (upgrade mode) File open ok New version binary File open ok New version binary یعنی هردوفایل فراخوانده شده ازسوی شماموردتاییدقرارگرفته است بنابراین رسیوررابه برق زده وبادکمه جلوی آن کهstandby است روشن می نماییم دراین لحظه درصدپیشرفت برای آپگریت نمایان خواهدشدودراین فاصله یک چای یاقهوه بنوشیدفقط به خاطرداشته باشیدخاموش بودن رسیوردراین مرحله هیچ خیری به شمانخواهدرساندودرتمامی مدت آپگریت رسیورشمابایدحتماروشن باشد تبریک عرض می کنم شماموفق به آپگریت رسیورخودشدید وامادرآخرکاربایدیک سری ازکدهارانیزبه صورت دستی واردنمائیم تابتوانیم کانالهای کارتی بیشتری رامشاهده کنیم زیراسیستم کددهی نگراویژن به صورت اتوماتیک بازشده وانجام وظیفه خواهندکردتنهاایرادآنهادیربازشدن کانالهااست چگونه کدهای دستی راواردنماییم؟ خیلی راحت ابتداکنترل رابرداشته وبررویexit فشارمی دهیم وسپس دکمه سبزرامی فشاریم ودرادامه برای ورود1 باردکمه زرد2 باردکمه آبی2 باردکمه سبز2 باردکمه قرمزوحالادرپایان1 بارمنورافشارخواهیم داداگردکمه هارادرست زده باشیدهم اکنون بایددرسیستم کددهی25 رقمی قراگرفته باشیم ودرادامه کدهای دستی راواردخواهیم کرد نوشته شده توسطrezasabet هرگونه استفاده فقط باذکرمنبع ونام سایت مجاز می باشد | ||
| | #30 | ||
| Regular Member Join Date: 21-08-2004 Location: Nepal
My System: ONE SDS( STAR DIGITAL SERVICE) & ONE DISH TV. |
Kaon is functionality of the Euroloader, if any one have Euroloader please provide in this form immediately. | ||
| | #31 | ||
| Member Join Date: 14-01-2005
| What's problems with my lover indians. If you have authorized receiver and have edit function in Kaon receiver then why you waste your own time and others to ask again and again for loader. whats it need so important and what's u want more and wahts' experiments you want to do with it.. See and enjoy with the available software . Is you do special work through this LOADER , do it Mr. vivek why did u ask or beg in this forum all the time although you have good contacts in Dish TV with SOB ( Ajay arora) and others in technical department. Ask them to give Loader if you need very urgent. and Mr. Lokesh why you give lengthy research in this forum. You could not hack Zeneja till today instead of 100 postings and now u waste time on Kaon Do that which is special , do not write post and post as you do in Zenega so be constructive | ||
| | #32 | ||
| Mr gupta2005 Its very simple to give advice to others. If you r so brillient then why don't u come forward with some great results. If u r satisfied with your package and payment, then please relax in your drawing room and enjoy Dishtv. Why r u here if u r happy and satisfied. I think you r wasting your time. thanks..... | ||
| | #33 | |||
| Regular Member Join Date: 28-03-2005
My System: SERVICE |
This is too much.........Why you are wasting your time. | |||
| | #34 | ||
| Khan I am Gupta not TOm Robert ok - correct yourseldf and do not name the members of dish Team like Vivek, tom, lokesh, and othyers . these are inner pepole of Dish TV. understand TR Khan Now Star Dth has to be started so wait for best hopes. then we see how this dish TV goes up its sale which moto is only cheating as Foxtell said. Please face reality and not try to run away from that. this is the fact | ||
| | #36 | ||
| Mr. Gupta, please don't say that I am a DISHTV man. U don't know a single word about me, u even don't know who I am and from where I am? I hope that DISHTV people has a lot of work to do then to just post in this forum. And please don't spoil my Image or any one else image without knowing his or her details. As u have said that DISHTV is cheat. If u associate us with DISHTV then we will be cheaters in everyone' eyes. So please think before u post. | ||
| | #37 | ||
| Mr. Lokesh Ok, You are not a Dish Man. You say that Dish TV people are very busy. They have no time to read and write in this forum. Actually Dish TV India has nothing to do except how to cheat their customers and tease the customers. Despite they improve their service in respect of sound quality and picture quality and channels, they waste their time in such things and You mean to that we all are in this forum “ Allu ke Pathae hein” who waste our time in this forum . We have much free time than Dish Tv people. think before u post Close the discussion on baseless things and if you and other have any productive thing show on the forum . Please not dictate story of your software in detail. Dear Lokest : Every rough and factual thing pains everyone . so Bear it please with patient. | ||
| | #38 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Please keep on topic, which is discussion of using Kaon receivers with Dish TV - personal accusations will result in the thread being closed. | ||
| | #43 | |||
| Looking New Channels Join Date: 10-07-2004 Location: HARYANA-INDIA
My System: Zenega with Old S/W, 90 cm Ku dish towards NSS 6, 5 feet C-band dish towards Asia 3S |
| | #44 | |||
| Member Join Date: 20-08-2005 Location: INDIA
My System: DISHTV INDIA | hi iam new to dish tv and i want to buy dish tv package can i guide me that is it providind kaon reciever in india i live in india near raipur so pls help thanks my email sourabh19us@gmail.com
| | #45 | |||
| Regular Member Join Date: 03-02-2004
what is the use of this patch ? | |||
| | #46 | ||
| Regular Member Join Date: 30-07-2004
Don't try to change the original software. No software is available for KAON 100 MCO supplied by Dish TV. It is exclusively made for Dish TV. Even if you contact manufacturers, they will direct you to Dish TV. If you have problem, contact the local dealer. By changing the original software, I have spoiled my STB. What ever software available does not suit.It is not even identifying free channels even though the input of frequencies are correct.More over it is not supporting Conax view card. | ||
| | #47 | ||
| Member Join Date: 12-10-2004
Ok guys for quite long i was just watching your post and none of u are smart enough for hacking conax system so pls excuse me for what i say, first of all u cant change software for your kaon its pre arrange by dish tv for their own protection so just forget the idea of patching it will not work as they are really smart people, for all to the secret information is its nagra tunneled conax so u cant use your card to any other boxes wont work to get the keys which is 20 and 21 then u need jtag which u can easily can google how to read the chip with jtag and u get box id which is very most heart of your card or just can say its your master key for your own card if u can suceed this then its easy to have conax mosc this info is more then or the eyes are watching on this post marry xmas | ||
| | #48 | |||
| Specialist Contributor Join Date: 10-03-2005 Location: Kasaragod,Kerala,South India.
My System: Sat:Insat 4 B and NSS 6 Platform:DD Direct+ STB:Eurobox 9700+CI System:Celeron D 2.8 GHz,Fedora Core 6 and Windows Vista Home Premium Edition. |
Wish all the Members A HAppy XMas and New Year | |||
Imagination is more important than knowledge... Albert Einstein | ||||
| | #49 | ||
| Member Join Date: 02-02-2006 Location: India
My System: KAON KSC100 MCO CONAX embeded CAS 2 CI slot 8' dish with universal KU LNBF directed towards NSS6 |
Hi friends, Initially when I bought KAON KSC100 MCO receiver from dish Tv package, I was able to select other satellite from existing 50 satellite list using main Menu and factory reset. Now I find only NSS6 by repeating same installation procedure. Help me how can I find other satellites in installation Menu? | ||
| | #50 | ||
| s it possible to get the old software of KAON KSC-100MCO receiver ? it has ben upgraded but i want to see dd direct channels for free , is that possible ? now my receiver firmware version is V2.13-1.40 but i want to watch the dd direct plus channels for free , is that possible ? | ||
| dish, kaon, receiver |
Similar Threads | ||||
| 2 dishes: Add 2nd receiver, UHF TV and FM | Artist 2004 | Multi-receiver/TV systems - Domestic only | 8 | 11-03-2007 09:14 PM |
| Samsung dead. PLZ HELP!!! | Zebo | Receiver software, international Section | 9 | 16-02-2006 12:05 AM |
| Matrix Reloaded How To by AHAC | rolfw | Matrix Reloaded, Revolutions and CAS interface | 52 | 27-12-2005 12:02 PM |
| IFA 2003 Berlin exhibition report | net1 | Digital systems | 0 | 01-10-2003 08:02 PM |
