What lead to connect my receiver to PC.Information exchange on receiver software, including updates, problems and fine tuning. | |
| | #1 | |||
| Regular Member Join Date: 19-05-2005
My System: what does that standa for? |
Hello there! I'd like to know how I can connect my receiver to the computer to install the softwere needed to get the viaccess codes. WHich cable shall I buy? My computer is very old and do not have USB port. My monitor has an USB port but not my CPU. Thank you very much! Fernanda
| | #2 | |||
| Specialist Contributor Join Date: 04-12-2004 Location: Mariana Trench - Pacific Ocean
My System: Vista- DreamBox 7020Si Nabilo Darkstar II -7025+ Black Hole 0.11 - DM8000 BlackHole 0.11 |
MOst decoders require a null modem serial cable, which is a serial cable with female female 9pin ports. Most times the pin connection is as follows 2---->3 3---->2 5---->5 BUT..... your decoder may be different from MOST decoders...therefore I suggest you look at your instruction manual. The connection to PC should be detailed there. Hope it helps | |||
| connect, lead, receiver |
Similar Threads | ||||
| 2 dishes: Add 2nd receiver, UHF TV and FM | Artist 2004 | Multi-receiver/TV systems - Domestic only | 8 | 11-03-2007 09:14 PM |
| Connect Two Dishes To One Receiver | rhondda | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 1 | 19-02-2006 03:57 PM |
| Samsung dead. PLZ HELP!!! | Zebo | Receiver software, international Section | 9 | 16-02-2006 12:05 AM |
| Matrix Reloaded How To by AHAC | rolfw | Matrix Reloaded, Revolutions and CAS interface | 52 | 27-12-2005 12:02 PM |
| IFA 2003 Berlin exhibition report | net1 | Digital systems | 0 | 01-10-2003 08:02 PM |
