Help For Humax 5400z Plss....
Information exchange on receiver software, including updates, problems and fine tuning.
Old 27-05-2005   #1
My System: hotbird
Angry Help For Humax 5400z Plss....
I need help for my Humax 5400z. I went to Polsat channel and trying to update the key using ram editor but still not working, then I tried to turn it off at the back and turn it on. My receiver is not working now, when I tried to turn it on the message is H2.07 then rA , then three small dots and it start blinking, oh my God did I broke it, PLS PLS HELP!!!
mannyjo is offline   Reply With Quote
Old 29-05-2005   #2
My System: Satellite & Computer User
Thumbs up
Do not worry.
Propably you delete all your channel.
Try to download your hannels file( if you saved before) to your humax 5400 USING Formula V3 program
I tried this method before when I got 3 dots,, and it works.
I found this method at site: humaxdigital.com.
As below:
Q. There is only 3 dots blinking on front panel .the receiver doesn't work at all.
A. Try to download the latest software again.
You can get it at the "Support" section
If it failed, try to download a null channel data by using Formula V3
1. You will need to download the Formula V3 program
2. After downloading this program please unzip it and install on your PC.
3. Start up the program.
4. Click on the CONFIG menu and set for (your model).
5. Click on the NEW button and a blank channel list will appear.
6. Click on the DOWNLOAD DATA button.
7. Switch receiver on and download should begin.
Asoor is offline   Reply With Quote
Old 30-05-2005   #3
Your channel settings have become corrupted. You can also use xoak or humbox to load new channel list. use hot 5.1 for autoupdate on polsat
McDude is offline   Reply With Quote
Old 15-06-2005   #4
My System: satellite&computers
my recevir humann a1_venus pls iwant soft were
ckmuthu is offline   Reply With Quote
Old 16-06-2005   #5
satellite freak
skull's Avatar
My System: 4x100 cm televe's dishes,with echostar quad lnb's, INNOVATIVE I.P, humax, echolink fta and kaon receivers. super jack h2h motor.
the best site for latest humax toh files is www.uploadfly.com ur receiver is ok just put the software agin and the channel data is also not gone in my opinion just ur receiver is stucked put he software again and wait untile the download is complete and the receiver is turned off and on again other wise u will have the same problem again
skull is offline   Reply With Quote
5400z, humax, plss
[IMG] code is Off
Similar Threads
Humax 5400Z/ LOADER 3.1!!!!!??????PLEASE HELP!!!! joshuatronic Receiver software, international Section 0 07-09-2005 12:18 PM
Humax 5400z patch wolsty Receiver software, international Section 20 13-10-2004 12:55 AM
Humax 5400z patched? alanwaddle72 Digital systems 8 08-10-2004 06:47 PM
Humax 5100 or Humax 5400z internetbasic2000 Digital systems 9 28-05-2004 03:04 PM
Humax 5400z Reference Satellite wolsty DISH SETUP: Single sat, Multi-Sat & Motorised systems 12 25-02-2004 11:54 PM
