Strong STR 4355 EVO ..plz plz HELP
Information exchange on receiver software, including updates, problems and fine tuning.
Old 11-07-2005   #1
My System: Receiver
Hi Forum,
i am absolutly new in things like Sat Receiver and here in Forum. I have some Problems with my STRONG STR 4355 EVO and i hope anyone can help me or have some informations about my Problem. I hope i am right here :-)
Here are my questions:
1. What for Software i need to upload Keys
2. What for keys i need for Strong str 4355 evo
3. Need i a Firmware update before uploading keyfiles
Thanks a lot & Greets
BadGuy
BadGuy is offline   Reply With Quote
Old 12-07-2005   #2
lula member
tapfit2004's Avatar
My System: humax 5400 fortecstar sl65 quali tv ir 4 digiboxes dragon cam funcard7 sm3d12 motor wavefrontier t90 90cm dish 1m dish
third question first, yes you do need to update the firmware from the original strong firmware before you can enter keys.
the newest firmware i could find was from 16th april 2004, but when i uploaded it into my 4355evo it worked ok (only a few channels as most have either changed encription or changed keys).
the keys can be found in the keys section of this site.
you can enter the keys manually into the receiver after uploading this firmware
below is the firmware and loader files i used on my 4355. just plug out your receiver, connect it to your computer via null modem cable, click on the dos batch file and turn your receiver back on. the program will take a few minutes and do not stop it half way through or turn off the power or you can do damage to the receiver. i have used this program with no problems and it tested ok, but i cant be held responsible if it does not work for you. all i can say is it worked for me. hope this helps.
Software flash removed. If it opens some channels it must have keys in it - this is against our rules.Please just post a link to it instead. Analoguesat
Gigfy
tapfit2004 is offline   Reply With Quote
Old 12-07-2005   #3
My System: Receiver
thanks for the Information, could you send a link for the files ?
I cant see the files here..
Thanks & Greets
Old 14-07-2005   #4
lula member
tapfit2004's Avatar
sorry about the file i thought it was ok to load it here, is there anywhere on this site i could upload it as i cant find the site which i downloaded it from.
i found another site
h**p://www.croteam-sat.org/
i have not tried any of the patches here but it lists a good few more up to date than the one i have.
ps i hope this does not break the rules as it is not a live link as far as i know.
Gigfy
Old 15-07-2005   #5
lula member
tapfit2004's Avatar
i have tried the latest patch from the site above and it worked no problem, the patch is from may 2005 so its nearly up to date.
Gigfy
Old 10-11-2006   #6
My System: Liberty CI9800 P2-600Mhz
Str 4356 Pvr
HI guys
In have Strong STR4356PVR
Do you have any SW for it to make it a EMU one? if not is the SW for 4355 any good for mine?
thanx in advance for any help
regards
Sami
sniali is offline   Reply With Quote
4355, evo, plz, str, strong
[IMG] code is Off
Similar Threads
strong 4355 evo channel list tapfit2004 Receiver software, international Section 0 20-05-2005 08:52 PM
Strong 4355 query compaq Receiver software, international Section 0 31-12-2004 03:06 PM
Any Info for Strong Str 4355 khaled26 Keys and Key editing 0 24-11-2004 06:32 PM
Strong 4355 LISA201259 Receiver software, international Section 1 26-04-2004 05:17 PM
Strong 4355 rx with Matrix cam neil.fisher Digital systems 0 05-02-2004 06:26 PM
