any emu for this receiver
Information exchange on receiver software, including updates, problems and fine tuning.
Old 25-07-2005   #1
m.a.s.75's Avatar
it seess on the receiver nextwave but i can not find him in the list of products for nextwave
nothing else only next wave writes on him and it is fta receiver that i"m shoor
any help
[img]http://www.*****.co.uk/attachment.php?attachmentid=11195&stc=1&thumb=1[/img]
m.a.s.75 is offline   Reply With Quote
Old 26-07-2005   #2
My System: Opentel 3500 FL, LNB 0.6 dB, 60 cm Fe
Check http://www.satellite-heaven.de/ or http://sat-receiver-world.com/pi5033...categoryId=270 for the list of Nextwave receivers.
IjonT is offline   Reply With Quote
Old 26-07-2005   #3
m.a.s.75's Avatar
Red face
but i can not find it ...
on the photos there i can not find him
some friend sed that it could probebly be junio receiver
did you heard about this receivers ... but i"m confused begause onthe receiver sees nextwave fta and nothing els
what should i do??? my friend
Old 26-07-2005   #4
If the warranty of your receiver expired already, you could open it and try to find some description on the circuit board.
Old 26-07-2005   #5
Your STB is from Frontier. I`ve added your pic and some infos at my website.
1st link in 2nd post. Use the links at my site, look in uploads for yumatu or sab and you will find s/w for that chinese stuff.
Where do you bought this stb, in Turkey?
xyz19 is offline   Reply With Quote
Old 26-07-2005   #6
Anatolia correspondent
My System: GoldMaster 7400 CIM 2MB with Kaon board 12.03.a5. Technomate 1000, Technomate 5200 USB. Two 80cm offset dishes.
any help
http://www.*****.co.uk/attachment.ph...&stc=1&thumb=1
This receiver seems to be directed at Turkish and possibly French / Belgian markets. I looked at a few Turkish forums and one says that Nextwave is a YUMATU receiver. (That might not be true for all models, though). There are emus for yumatu on various Turkish sites - but you must first learn which model you have.
Have a look at the photos on the YUMATU website here:
http://www.yumatu.com.tr/index_eng.html
Artist 2004 is offline   Reply With Quote
Old 26-07-2005   #7
Just seen xyz19's message which covers most of my points and more. First time I've seen satellite-heaven.de website : excellent work!
Old 26-07-2005   #8
any help
m.a.s.75: can you speak Turkish? There's a lot of support on Turkish forums for Nextwave / Yumatu receivers. If you need help to find download pages let me know - but first learn which model you have.
Old 26-07-2005   #9
m.a.s.75's Avatar
Unhappy
i received my receiver as a gift
i don’t know where is from
So what should i cheek to be shore not to harm my receiver during the emu installation?
thnx my friends you are the great gang
yes m8s my receiver is like the one on the (Yumatu) web but then the same like the one on satellite-heaven.de/ (SAB)....so how can i chek h/w IS IT THE YUMATU or SAB ?
Old 27-07-2005   #10
Which Yumatu model?
Which SAB model?
Old 27-07-2005   #11
m.a.s.75's Avatar
Unhappy
YUMACU MX-700 FTA or
Nextvision S-5000 FTA or meybe
Frontier DV-928
in receiver meny sees ]]
model 550 d
s/w ver vgd 3.2.0 c
h/w ver vgd 1.0.0
loader ver. TP Loader 1.0.6
manufacturer
STB_V3.OA
Old 27-07-2005   #12
these models are all the same: yumatu mx series, dsn 6100/7300, sab/nextvision5000 and many other models.
you need the loader cpuprade 1.06 or 1.07 and the binfile. perhaps you must change your bootloader.(no idea)
i give you no guaranty for these infos. you must know what you do.
Old 27-07-2005   #13
m.a.s.75's Avatar
so where can i find this loader 1.0.6
where are the bin files for download
i previosly workt on humax,samsung,dreambox,strong 6355,quadro,kaon receivers so now i need only for shoor info about this receiver model and web to download stuff ...
thnx m8s
Old 27-07-2005   #14
visit "tnt-2 depot" (receiver--->yumatu--->mx series), there is all you need. or other uploadsites and boards (turkish, or other) .
Old 27-07-2005   #15
m.a.s.75's Avatar
yes i can probably go there but how can i determin which model of h/w is for ...?
Old 27-07-2005   #16
m.a.s.75's Avatar
Talking
193-216-415 icq mesinger
MARKOSARKO@HOTMAIL.COM MSN MESANGER
PLEASE CALL ME
ps.
Artist 2004 you two m8
thnx
i see now some m8 published my photo on www.satellite-heaven hehhehe
Old 27-07-2005   #17
I think that all of these "frontier" stb`s like yumatu mx are the same. the different is just the front panel.
Try it or let it be. It`s your decision. I do not have these stb`s and can`t say more about it as I did.
Is it OK for you with the picture at my site or do you have a problem with it?
Old 27-07-2005   #18
Frontier DV-928
model 550 d
s/w ver vgd 3.2.0 c
h/w ver vgd 1.0.0
manufacturer
STB_V3.OA
You can download the TP loader 1.0.6 here:
http://www.uydukurdu.com/showthread.php?t=5631
Open the page, scroll down to the end, you will see the files listed.
But as xyz says - it's at your own risk as we are not familiar with your receiver.... and I do not know yet if your receiver can receive an emu...
The nearest emu I've found is here:
http://www.ozmena.com/showthread.php?t=33031
Scroll down to YUMATU MX SERiSi (FTA-CI)
The first file TURKEY-SW3.2.75-ORJ-POLSATFİX.zip
is close to your software version. But the small print under it says "use loader 1.0.7! If I find anything better I'll let you know.
This site says the same. See first message.
http://www.turkeyforum.com/satforum/...d.php?t=112836
Note: it's very risky to use the wrong file to flash your receiver - I understand that sometimes you can't use your receiver afterwards
Old 27-07-2005   #19
m.a.s.75's Avatar
thnx Artist 2004 for your sencire help
thnx a 100000000
hope we can be in tuch
xyz19" i'm glade to be from help finding a new clone m8.. for you no problem for the photo my friend ...cheers
Old 27-07-2005   #20
m.a.s.75's Avatar
http://www.turkeyforum.com/satforum/...d.php?t=115104
what are dey seying
my meny is like the one on photohttp://img207.exs.cx/img207/5628/10015195uz.th.jpg
beck of the receiver is like the lestone 3
http://img96.exs.cx/img96/5466/10015686qr.th.jpg
Old 27-07-2005   #21
what are dey seying
From the turkeyforum link:
Your menu is from the MX series 2MB version, not the X series 1MB version.
The photo of the back is the 5500 - 7500 series.
But it can't be both!
Please have another look at your receiver: does it have 2 connectors to the left of the scarts or 4 like this?:
http://img207.exs.cx/my.php?loc=img2...10015010mk.jpg
Old 28-07-2005   #22
m.a.s.75's Avatar
starting menu on my receiver
http://img292.imageshack.us/img292/2...ure80th.th.jpg
back on my receiver
http://www.yumatu.com.tr/urunresim/mx%20700%20b.jpg
front of my receiver
info from inside menu
___________________________________
MODEL 550 D
S/W VGD 3.2.0 C
H/W VGD 1.0.0
LOADER ver. TP Loader 1.0.6
manufacturer STB_V3.0A
it looks like this so ....
5500 i gess...???
Old 29-07-2005   #23
m.a.s.75's Avatar
i maneg to find soft. for my receiver
so now is working just fine with the EMU onboard
thnx to all
cheers
Old 30-07-2005   #24
thnx to all
cheers
Excellent! I'm glad we were able to help.
Old 30-07-2005   #25
m.a.s.75's Avatar
Red face Emu For Vestel 3600 Fta ???
VESTEL 3600 FTA DVB 4 V.2 ONLY ONE LNB IN CONNECTOR
http://img32.imageshack.us/img32/902...ure81qz.th.jpg
http://www.satellite-heaven.de/Recei...3600%20FTA.jpg
http://www.satelitska-tv.com/img/tes...fta/slika3.jpg ANY EMU for this receiver ....
emu, receiver
[IMG] code is Off
Similar Threads
2 dishes: Add 2nd receiver, UHF TV and FM Artist 2004 Multi-receiver/TV systems - Domestic only 8 11-03-2007 09:14 PM
Samsung dead. PLZ HELP!!! Zebo Receiver software, international Section 9 16-02-2006 12:05 AM
Matrix Reloaded How To by AHAC rolfw Matrix Reloaded, Revolutions and CAS interface 52 27-12-2005 12:02 PM
receiver query Eutelsat Hotbird dcjag Digital systems 3 03-10-2003 03:48 PM
IFA 2003 Berlin exhibition report net1 Digital systems 0 01-10-2003 08:02 PM
