TopField TF 3000
Information exchange on receiver software, including updates, problems and fine tuning.
Old 31-07-2005   #1
My System: Topfield tf3000fi
TopField TF 3000
hi i have TopFeild TF 3000 FI, and i don't know how to enter the edit code menu, so i can change the keys. i think i must enter secrect codes by remote control, can anyone help me !?
hunter_hunter is offline   Reply With Quote
Old 31-07-2005   #2
Try this
1)menu
2)press 121 without pressing ok
nissan is offline   Reply With Quote
Old 31-07-2005   #3
thanxx
Originally Posted by nissan
Try this
1)menu
thanxxxx it worked
thanxxxxxxxxxxxxxxxxxxxxxxxxxxx again
Old 02-08-2005   #4
My System: 4.5 meters dish with motor 64 east to 43 west
hi i have TopFeild TF 3000 FEi, and i don't know how to enter the edit code menu, so i can change the keys. i think i must enter secrect codes by remote control, can anyone help me !? thanks
ciao Sipione.
I believe that for TF 3000FI is:
1)menu
sipione is offline   Reply With Quote
Old 02-08-2005   #5
Unhappy Help for TopFeild 3000FEi
ciao Sipione.
1)menu
Old 13-08-2005   #6
My System: -
I have a Topfield 3000FEi and menu -> 121 doesn't seem to do anything.
Has any had success finding the edit menu with the 3000 FEi?
-ry
kultary is offline   Reply With Quote
Old 10-10-2005   #7
Question Topfield TF300Fi Secret Menu HELP
Hi I Have a Topfield TF300FI. How & where Do I enter this 121??
I have Also Loaded the Latest Firmware. Does this make any Difference??
Do I have to Go to System Menu? or Something Like this?
Can Someone Please Show me or tell me STEP by STEP Procedure, as I turn the Satellite Receiver on?
I've been trying for months
Many Thanks.
spookie is offline   Reply With Quote
Old 10-10-2005   #8
Anatolia correspondent
My System: GoldMaster 7400 CIM 2MB with Kaon board 12.03.a5. Technomate 1000, Technomate 5200 USB. Two 80cm offset dishes.
I've found step by step instructions on a Turkish web site, but in Turkish. Watch this space - I'll post again after I've translated it.
Artist 2004 is offline   Reply With Quote
Old 11-10-2005   #9
Hi are you able to supply the Web Address here?
Thanks.
Old 11-10-2005   #10
thanxxxx it worked
Hi, Just wondering what Firmware Version you used when youdid this CODE??
I'm using the Latest Firmware. Maybe theLatest Firmware doesn't allow this to happen eh?
Cheers.
Old 11-10-2005   #11
Topfield: Manual Key Entry procedure
You can only enter keys if your receiver has been loaded with an emulator (emu) program. If you have been able to watch encrypted channels at any time without a key card inserted, then you already have an emu. In any case, if you haven't downloaded the latest emu version for a month or two, then you should because some keys don't work without it.
I translated the following from a post on a Turkish forum. Thank you to ozmena.com My Turkish isn't great, and I don't have a Topfield myself, so if you find the following inaccurate please post corrections.
===== Topfield Key Entry =====
Press Menu on the remote controller.
Choose "System Settings" (Or something equivalent) and press 121 to bring up a new menu item EDIT CODE. Select EDIT CODE and press OK.
Remote controller functions:
Red button: (Change CAS Type)
Green button: (Add): Enter new key
Yellow button: (Delete): Delete a key
Blue button: (Change code): Edit a key
Press red button on the remote controller to get list of encryption system types and select which one you want:
Vi*ccess
Irdet*
S*ca
N*gravision
==== New Key Entry ====
Press green button (ADD). This opens a screen where we can use numeric characters 0-9, alpha characters A-F, DEL and OK.
The format of the key has three fields:
Provider (_ _ _ _ _ _) 6 digits,
Index (_ _) 2 digits,
Code Data ( _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ ) 8 pairs of characters
Use either the remote control or pick characters from the screen to enter the key.
==== Example ====
To enter P*lsat keys for the first time.
Assuming that we have obtained the following information from a key file for two keys:
Quote:
P*lSat Cyfr*wy 13°EAST HOTBIRD
Ident
HEX: 7101
DEC: 113 001
Key 00
HEX : 6F F0 6F 47 E9 57 D3 C8
DEC : 111 240 111 071 233 087 211 200
Key 01
HEX : BD 42 2C 6A D2 B5 8C 24
DEC : 189 066 044 106 210 181 140 036
1- Press green button (ADD), to open new window.
2- Enter 007101 in the Provider field.
3- Enter 00 in the Index field, or 01 for the other key.
4- In the Code Data field enter the Hex alpha numeric codes.
5- Select OK from the menu to save the key.
6- Repeat for the other key.
==== To Change a Key ====
Using the P*lsat example above:
Press the blue button (Change Code). Scroll through the list of keys until you find the keys with Provider 007101. Select the key that has 00 in the Index field. Then use the same procedure as above, to over-write the data in the Code Data field.
Make sure you don't change the Provider or Index fields.
3000, topfield
[IMG] code is Off
Similar Threads
Need help with Topfield 3000 CIP Pro atomicsushi Receiver software, international Section 1 19-03-2006 07:44 PM
HELP Matrix and Topfield 3000 CIP PRO gonzo5 Matrix Reloaded, Revolutions and CAS interface 0 31-08-2004 12:49 PM
Topfield Tf 3000 Fi blackviper Receiver software, international Section 0 12-08-2004 06:31 AM
topfield 4000 or 5000 ? papako Digital systems 2 09-03-2004 06:19 PM
