Fortec Star 5100 Diamond Problems
Information exchange on receiver software, including updates, problems and fine tuning.
Old 28-08-2005   #1
My System: Sky Digital using a Panasonic DSB31 receiver, Hotbird using a FSCI 5100 Diamond twin CI recevier.
Hello
I've got a Fortec Star 5100 Diamond, i reset the unit back to the factory settings and then updated it with the latest software. After updating the box would only switch on and show -61- on the display, i can't access anything on the box i tried re-flashing the box but nothing. It's as if the box is 'brain dead'
Any ideas on on what i could do to fix it or is it toast?
Thanks,
Mark
mark_k is offline   Reply With Quote
Old 29-08-2005   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
I suspect it's showing the boot version (6.1). Make sure you're loading the correct software application for your model. Other than that, I can't really speculate on what the problem might be, other than a flash memory failure.
Llew is offline   Reply With Quote
Old 29-08-2005   #3
Thanks Llew, looks like it probably is a memory failure. I'll give it another go at loading the software app otherwise a new box is in order
5100, diamond, fortec, problems, star
[IMG] code is Off
Similar Threads
Fortec Star 5100 Plus software samsat Receiver software, international Section 46 27-02-2009 12:36 PM
plaza 3300 or Fortec star 5100 samsat Receiver software, international Section 2 13-11-2007 11:10 PM
Fortec Star 5100 Diamond queries markhunter99 Digital systems 0 29-03-2005 03:46 PM
Fortec Star 5400 marmal Receiver software, international Section 7 20-12-2004 04:15 PM
Fortec Star 5100 Diamond J.M.OUTTEN Digital systems 0 22-10-2004 10:12 PM
