Sun Create 8800 and 8800CI Rockchang
Information exchange on receiver software, including updates, problems and fine tuning.
Old 18-09-2005   #1
In Rockchang's site dvb-nease.net I found SW for SC6800 and i put it in 8800 non CI ,it works fine ,but when i've tried to put it into 8800 CI It worked ,but the programmes cant be found ,in spite of the full signal. Any of the others SW on this page could'nt help me to revive the receiver(it worked before i did the change) In its initial SW was menu for the CI ,which is not present now.
Dear Rockchang ,please if you have another SW for these receivers or Flash dump for the SC8800CI (it has JTAG connector and I have the interface) Please send it to ropepowersoftyahoo.com Thanks!
Rope is offline   Reply With Quote
Old 19-09-2005   #2
rockchang's Avatar
My System: hp7800---perfect arion-1700 clone receiver! + coolsat 4000pro + pansat 2500a + starsat sr-x200ci + infinity usb+cas interface 2+matrix reloaded
Talking
dear rope,
you cant use 6800 software on 8800ci because they have different tuner inside.
but dont worry, just a software upgrade can fix the problem,
try ci software on 8800ci.
btw, do u have huapu 7800 receiver?
if u have huapu 7800 remote control, i can send u an emu software for 8800ci.
good luck!
rockchang is offline   Reply With Quote
Old 20-09-2005   #3
Thank's a lot Rockchang ,yes I do have Huapu too. Please send me that SW to try it .I'll try the 6800CI also and Ill write about.
Old 20-09-2005   #4
rockchang's Avatar
Talking
dear rope,
try 8800emu
good luck!
8800, 8800ci, create, rockchang, sun
[IMG] code is Off
