RS232 help please
Information exchange on receiver software, including updates, problems and fine tuning.
Old 18-09-2005   #1
nilefish's Avatar
My System: DB 500 S,Strong 4622, Viasat Denmark card and receiver, Moteck 2100 Motor, Triax1.1 dish, infinty programmer, cas interface2.
Angry RS232 help please
I have just got my TM 7755 receiver , I tried to connectet to my PC using RS232 nul modem , I know how to download the firmware ect but my PC can not detect the new hardware , do I need any software or driver ? any ideas to let this cable work?
Many Thanks
nilefish is offline   Reply With Quote
Old 18-09-2005   #2
My System: 85cm dish twin lnb fortec star receiver stab HH120 motor
nilefish,
Have you gone into control panel, add new hardware?
REBEL is offline   Reply With Quote
Old 18-09-2005   #3
Lancelot's Avatar
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W
...And thou were the truest friend to thy lover that ever bestrad horse..."
So what is it you are trying to do if not a firmware upload ??
L>
Support our Advertisers
I've got an inferiority complex, but it's not a very good one.
Lancelot is offline   Reply With Quote
Old 18-09-2005   #4
BGonaSTICK's Avatar
I imagine you will have to obtain a small loader app.
Normally you run this on the PC with the cable connected but the receiver disconnected from the mains.
Then you switch on the STB when instructed and the fimware flashing process commences.
MAKE SURE you have the correct firmware, and that you read the loader instructions properly before you get started, or you may toast your new toy.
STICK
Old 18-09-2005   #5
Lancelot's Avatar
L.
Old 18-09-2005   #6
nilefish's Avatar
Thanks alot guys for helping I run the PC with the cable connected and I got the right firmware flashing but the message - close a port or STB on- appear - I don't know what the STB stands for could you please explain more
Old 18-09-2005   #7
Ding Dang Doo
gameboy's Avatar
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life!
STB - Set Top Box (Receiver)
Only he who does nothing, does nothing wrong.
gameboy is offline   Reply With Quote
Old 18-09-2005   #8
nilefish's Avatar
I keep getting this message
Check COM port please wait
cannot open COM port.. close a COM port or STB power on
I connect the cable to the PC and the receiver and the power is off ..??????
Old 18-09-2005   #9
Lancelot's Avatar
Have you set the com port to COM1 in the loader software and made sure that your computer is not trying to use COM1 for something else ?
L.
Old 18-09-2005   #10
nilefish's Avatar
I came to this part ..no proplem with the port , but nothing happened no downlaod started and I don't know the instructions as this point to put the power on ? or keep the power off
Cheers
Old 18-09-2005   #11
Lancelot's Avatar
You generally start with the power off and apply it when prompted to do so by the software.
L.
rs232
[IMG] code is Off
Similar Threads
RS232 cable diagram for Technosat T-888 kav4 Receiver software, international Section 1 17-03-2009 01:42 PM
CardSharing Cliente Ouralis por puerto Rs232 popiman Ferguson 10 02-09-2006 01:08 AM
Cabo RS232 Hazard K-Box 5 21-04-2006 11:03 PM
RS232 on my SAT reciever leonardwolk The Meeting Place 3 08-10-2002 05:52 PM
